POV-Ray : Newsgroups : povray.off-topic : Processor speed Server Time
5 Apr 2026 07:01:13 EDT (-0400)
  Processor speed (Message 21 to 23 of 23)
Subject: Re: Processor speed
Date: 31 Oct 2008 14:21:34
Message: <490b4cae$1@news.povray.org>
>> How wide is a typical cache line?
> Warp said 32 bytes. I thought that was way smaller than I remembered,
> but I went and variously tracked it down, and indeed, most of the modern
> machines seem to have 32-byte cache lines.  I think they used to be
> wider, like 128 bytes, but maybe I'm misremembering, or thinking of
> mainframes, or something.
Right. So just to make sure I understand this... you're saying the cache
is managed in chunks of 32 bytes at a time? Like, if you fetch 1 byte of
data from memory, 32 bytes will be loaded into the least recently used
cache line? (Or whatever the cache policy is.)
Are the cache lines aligned in any sort of way? (I'm wondering if it
grabs 32 bytes at the nearest 32-byte boundary or not.)
http://blog.orphi.me.uk/
Date: 31 Oct 2008 15:59:14
Message: <490b6392$1@news.povray.org>
That's how I understand it. I believe it's more accurate to say that the
bus between the memory and the registers is actually 32-bytes wide. I
may be mistaken in that, tho.
I'm also pretty certain it is on 32-byte boundaries. Otherwise, the
addressing logic winds up being slower than the time you save caching stuff.
Date: 31 Oct 2008 17:55:04
Message: <490b7eb8@news.povray.org>
  You should read this article series if you want to know everything there
is to know about memory and cache:
http://lwn.net/Articles/250967/
