POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
4 Jul 2026 15:41:18 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 31 to 40 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 24 Oct 2008 00:42:50
Message: <4901524a$1@news.povray.org>
On Thu, 23 Oct 2008 23:34:55 -0200, Nicolas Alvarez wrote:
> Jim Henderson wrote:
>> On Thu, 23 Oct 2008 18:15:04 -0200, nemesis wrote:
>>> Hmm, playing dirty, huh?  Is it just the case of the 3D video cards or
>>> also other kinds of hardware?...
>> Divio is one that I've had to deal with; they manufacture (or
>> manufactured) the CCD chip in some of the older Logitech Quickcams.  I
>> happen to own one of those.
>> Divio refuses to open the spec, so the only Linux driver effort (which
>> is now dead, AFAIK) is a development of the 'nw802' and 'nw8xx' drivers
>> done entirely through reverse engineering using a USB sniffer.
> I read a blog about someone trying to reverse engineer the iPhone USB
> protocol with a USB sniffer. They figured out a few basic things, then
> noticed most of the interesting stuff was ENCRYPTED, and the project got
> into a halt.
Yeah, that's another one.  I also have limited ability to connect my
Blackberry to my Linux system - I can charge the battery, but that's
about it.  I know there are some apps that should let me back it up (like
with the BB desktop on Windows), but I've not worked through setting that
up yet.
The Divio chip reverse-engineering effort was nearly complete, I really
don't understand why the project ground to a halt.  The biggest issue I
had was the brightness control didn't work well - but I was actually able
to get a picture from it (and video).
Jim
Date: 24 Oct 2008 00:47:07
Message: <4901534b@news.povray.org>
>> Real money comes from hardware sales, though; supporting (or allowing
>> others to write support for) more platforms = more product sales.
> Yes. That's why (for example) Sun gives away Java.
Yes, and I'm happier now that the JDK is mostly ported to openJDK - that
means 64-bit Java plugin for FF on Linux now.
> However, that doesn't hold true when the device drivers include much of
> the innovation in the hardware. As soon as you explain exactly how it
> works, someone else can rip off your design.  See, for example, "PC
> Clone".
True, but at the same time, that information being reverse-engineered by
Compaq really opened up the PC market; it also commoditized (or helped
commoditize) PC hardware and reduced the costs so most people could
afford one.  Or two.  Or ten. ;-)
Which in turn has moved PC sales from a low-volume high-margin sales
model to a low-margin high-volume sales model.  Seems to have worked out
fairly well for most PC manufacturers.
Eventually, clean room reverse-engineering would expose those internals
anyways, and arguably the type of process Compaq followed isn't something
IBM could have sued over - the guys developing the Compaq BIOS were
working entirely from specs drawn up by the guys who were looking at how
the BIOS worked.
Jim
Date: 24 Oct 2008 00:50:26
Message: <49015412@news.povray.org>
>> Oh, that's not Grub, that's SYSLINUX - Grub is hard-disk only to the
>> best of my knowledge.
> OK. Whatever. Obviously it would have been a PITA to install Linux there
> even if I could get it to boot.
Well, yeah - I was just confused because you were saying GRUB, but
because that doesn't work on removable media (and isn't designed for
that).  I was hoping I hadn't missed something with GRUB development. ;-)
>>> Maybe. I don't have any trouble using Windows' bootloader to load
>>> GRUB. You just have to set it up right. It's pretty trivial.
>> Yup.  But it's not something that I've ever seen automated by the Linux
>> installers.
> No, because they can't write to NTFS partitions.
ntfs-3g can write safely to NTFS partitions.  I almost said it didn't
matter, but forgot that with Windows you do have to modify boot.ini for
that purpose.
> So they can't modify
> the Windows boot menu to accomidate Linux. So they clobber the Windows
> boot sector with the GRUB boot sector.  Which, honestly, wouldn't be all
> *that* awful, if they actually followed the rules for booting,which is
> to say, boot the partition marked "active".  If they did that, you could
> boot back and forth between Windows and Linux without being at the
> console.
Yeah, it's really kinda - well, expected, I guess - that MS behaves that
way about how the system boots.  They want to be the only OS there, so
they just play like they are.  They should stop doing that, maybe they
will with Windows 7?
Jim
Date: 24 Oct 2008 10:13:02
Message: <4901d7ee@news.povray.org>
Jim Henderson escreveu:
>> console.
I'll eat my underwears if they do. :D
Date: 24 Oct 2008 12:14:50
Message: <4901f47a$1@news.povray.org>
I think the pheonix bios did more than Compaq did. The hardware was all
very well documented by IBM before the clones started coming out, as was
the BIOS. People didn't used to try to hide that sort of thing. :-) IBM
wanted people building cards for it, just like Apple did for the
Apple ][.
Yep yep.
I dunno about that. Worked well for, say, manufacturing plants in China.
I don't know that it worked well for people actually selling the end
product.
> the BIOS worked.
Yeah. Except I think you're confusing Phoenix with Compaq. Compaq made
the hardware. Phoenix cloned the BIOS first.  (Unless I'm misremembering
something.)
And yes, IBM *did* sue over it. That's why Phoenix followed the
clean-room approach to start with. The original IBMs came with a
complete commented source listing of the BIOS when you bought them.
(Well, maybe it was an extra packet, part of the assembler or something,
but it was an off-the-shelf purchase.)
Date: 24 Oct 2008 12:23:06
Message: <4901f66a$1@news.povray.org>
In matters Linux, always assume I don't know more than you do. :-)
>>> installers.
Yes, but since (as I understand it) you need a copy of ntfs.sys on your
Linux partition to make that work, Linux first has to already be booted
and capable of mounting the right drive and finding ntfs.sys to copy it.
I guess you could do it, but it certainly sounds ... messy. :-)
> that purpose.
That's the rub.
Dude, it's been that was since the IBM XT came out.  The very first hard
drive, before you could have more than 4 partitions, had a boot sector
that would boot off the "active partition". That's what it's *for*.
Yes, MS's boot sector follows the standard that's been around for a
decade longer than Linux has. GRUB's doesn't. What do you think MS is
doing wrong here?
Doing what? I have no problem at all telling Windows to boot Linux on
the next go, simply by changing the active partition to be partition 2
instead of partition 1.  Once I get into Linux, I can reconfigure GRUB
to default to booting Windows. But after that, I can never get back into
Linux again, because Windows can't change GRUB's configuration, so if I
set the active partition to the GRUB partition, it'll still boot Windows.
Now who is the only OS that'll boot?
If GRUB's boot sector actually loaded the boot sector off the active
partition, just like ever other boot sector written in the history of
hard drives on IBM computers and their clones, you could remotely switch
back and forth by using the same procedure that's worked since day 0 on
the IBM AT. Sadly, the Linux developers want to be the only OS that can
be booted, so they didn't bother to follow the standard. ;-)
Date: 24 Oct 2008 12:53:15
Message: <4901fd7b$1@news.povray.org>
>>> console.
>> that way about how the system boots.  They want to be the only OS
>> there, so they just play like they are.  They should stop doing that,
>> maybe they will with Windows 7?
If they do what? Fix their MBR code so it boots the active partition, so
you don't have to boot Windows to change what operating system boots if
it by default already boots Windows?
Date: 24 Oct 2008 12:58:37
Message: <4901febd$1@news.povray.org>
> that purpose.
To be clear, you have to modify boot.ini to add a new option to the
Windows boot menu choice. But you do *NOT* have to modify boot.ini to
boot something instead of Windows. You just change the active partition.
You can boot off a MS-DOS floppy and change yourself from booting
Windows to booting Linux or Solaris or whatever else you might have there.
Unfortunately, since GRUB doesn't follow the rules that have been in
place for 25+ years, this doesn't work with GRUB. Used to work with
LILO, but apparently GRUB's per-partition boot loader requires GRUB's
MBR to work right, according to some informal tests I just did.
Um, no. They behave exactly the opposite. MS's boot sector will boot
whatever partition is marked "active".  Remember that MS has been making
multiple OSes for a long time. You've always been able to multi-boot off
MS operating systems.
Solaris was the OS that wiped out your partition table, on the grounds
that you couldn't possibly want Windows *and* Solaris both. And GRUB is
apparently incapable of booting from its own partition without the help
of its own MBR, which doesn't pay any attention to the active flag.
Date: 24 Oct 2008 14:33:41
Message: <49021505$1@news.povray.org>
Darren New escreveu:
>> They want to be the only OS there, so they just play like they are.
>> They should stop doing that, maybe they will with Windows 7?
How do a layman do that?  But then again, a layman won't install Linux
anyway...
Date: 24 Oct 2008 14:35:57
Message: <4902158d$1@news.povray.org>
> place for 25+ years
We're all about to have SSDs default on PCs and you're talking about 25+
years ancient tech and standards?  How about using tapes to install
Microsoft DOS right now? ;)
