POV-Ray : Newsgroups : povray.off-topic : Linux really costs a _lot_ more than $40 Server Time
5 Jul 2026 10:31:56 EDT (-0400)
  Linux really costs a _lot_ more than $40 (Message 141 to 150 of 189)
Subject: Re: Linux really costs a _lot_ more than $40
Date: 18 Nov 2008 13:14:34
Message: <4923060a$1@news.povray.org>
Darren New wrote:
> I think I'm just f'ing unlucky. I seem to run into every weird problem
> that no other Linux user ever has trouble with. Must be my morphogenic
> field or something.
I dare to challenge you with couple of really weird problems:
1) I have a Alphaserver ES40 as a toy. I installed Gentoo Linux on it
via very weird problem - keyboard didn't work on the local console. It
works on Debian's install CD, but not Gentoo's. I changed the kernel on
the install CD etc etc etc, but nothing helped. Eventually I created a
install-CD with DHCP client enabled, root passwd unscrambled and SSHD
enabled, so I could do the installation over the network.
2) I have Sun Netra X1, which I though I'd install as a firewall (it's a
cute 1U system, would make a nice firewall). I managed to install Gentoo
Linux on it, RAID-1 -setup etc. But after installing almost everything
and configuring the system I suddenly couldn't anymore copy files to
local disks over network. Scp, Rsync, simple cp from/to NFS, wget.. No,
just couldn't do it. I could transfer data nicely over network with no
problem to two directions, I could copy files from USB-stick to HD's,
but the path from NICs to HD just failed. No error, no reason, nothing -
the file just never appeared at the filesystem. I never actually solved
this.
-Aero
Date: 19 Nov 2008 19:00:01
Message: <4924a881$1@news.povray.org>
On Mon, 17 Nov 2008 14:27:01 -0800, Darren New wrote:
> Jim Henderson wrote:
>> That would probably make more sense.  Or make it configurable via a GPO
>> but have the defaults be sane for the home user.
> Actually, it's kind of weird to me that you can turn off the computer
> from a remote login without a UAC prompt, but you can't (say) change the
> clock.  Strange.
> And it still takes two UAC prompts to change "advanced" power management
> settings. (Or maybe a different number if you're actually at the console
> and not logged in remotely? It's a bit weird, IIRC.)
That does seem unusual, yeah.  In both cases....
>>> Yah. You can do this just by logging in as administrator, for example.
>>> Then you get no prompts at all.
>> On Vista?
> On my version, yes. Or go into Local Policies and set it up how you
> like. But on mine, by default, UAC is set to allow the actual
> "Administrator" account anything. (You have to actually turn on the
> ability to log in as administrator.)
Ah, now I remember - I was logged in as the "owner" created during the
OEM setup process, not as administrator.
> Note I'm not talking "Member of the Administrators group", but the one
> actually called "Administrator".
Yup.
>> Right click the panel and select "Add to panel" - then filter to
>> "Menu".  :-)
> Ah, thank you.  Yes, as I say, I probably could have solved it, but
> since the problem happened as I booted back from a full restore, I
> figured it was easier than actually trying to figure it out just then
> and there.
Glad to help out. :-)
>> I use the updater applet which is really clear.
> The thing in the "system tray" area? I never liked that. For one, it
> would take a long time every time you logged in to check for updates,
> preventing you from actually doing any package management or logging out
> cleanly or whatever. (As I said, probably fixed now that they don't suck
> down manifests every time.)
On 10.x it did take a long time to check for updates and would bury the
processor as well.  My experience with it in 11.0 has been pretty good -
I do wish they differentiated between a read-only access to the database,
though, so you could launch package management while it was checking for
updates.  It's a database, after all, it should be capable of allowing
multiple processes to access it for read-only access.
>> thing is, Mono wasn't ready for prime time yet,
> This is a complaint? ;-)
Well, like I said below:
>> and using your updater app to showcase a new technology is just mind-
>> bogglingly stupid IMNSHO) and replaced it with packagekit.  I've found
>> that to be MUCH better.
> Cool. Maybe I'll turn it back on, when I get another job doing linux
> stuff.
Jim
Date: 19 Nov 2008 21:48:58
Message: <4924d01a$1@news.povray.org>
Good to know.
The linux file system isn't transactional, so you can't really work it
that way. It isn't a database - it's a bunch of files, at least as I
understand it.
That was unwarranted sarcasm, as in "isn't all of Linux not ready for
prime time?" :-)
Date: 21 Nov 2008 13:10:37
Message: <4926f99d@news.povray.org>
> Good to know.
>> database, though, so you could launch package management while it was
>> checking for updates.  It's a database, after all, it should be capable
>> of allowing multiple processes to access it for read-only access.
> understand it.
Yes, but the information for RPM is stored in a database - or rather a
series of databases - implemented using Berkeley DB (on my system,
version 8).
> prime time?" :-)
Oh, I see.  Thhhhpt. ;-)
Jim
Date: 21 Nov 2008 13:37:50
Message: <4926fffe$1@news.povray.org>
> version 8).
I guess if all the information you need to make that decision is stored
in a transactional database, yah, you should be able to do that sort of
thing. But then you wouldn't need a read-only version.
The problem with ACID is too many people stop too soon, thinking (for
example) that "Consistent" means if the internal structure of the
database storage isn't screwed up means that the database is consistent.
If you upgrade GCC from 2.3 to 2.4, and the /usr/bin/gcc file gets
rewritten and then you crash out before committing the package manager,
or you have permissions to write to libgcc and overwrite it but fail to
upgrade /usr/bin/gcc properly, you have an inconsistency.
Out of curiousity, how do the package managers work when the packages
are distributed over the network? If /usr/bin is a NFS mount, for
example, does package management still work? Or are you back to
tiptoeing around trying to figure out every file a package will touch?
Can clients upgrade things, or do you have to try to lock it down at the
NFS server?
Date: 21 Nov 2008 15:37:56
Message: <49271c24$1@news.povray.org>
>> version 8).
Yeah, and that sort of thing can happen - though the filesystem layer (on
top of the actual filesystem at the kernel level - not sure what it's
specifically called, probably some sort of abstraction layer) deals in
inodes rather than files.  It's entirely possible to nuke a file that's
open, along with its parent hierarchy; did that by mistake a few weeks
ago when running pdfcrack before Eero suggested an alternative approach
to my issue.  I even replaced the deleted directory with a second
extracted copy of the source archive and a second copy of the PDF in
question - but looking at the kernel level, the inodes are different.
> NFS server?
You know, I've never actually looked into that - I know in my Unix
experience that mounting a remote /var partition wasn't uncommon,
particularly with diskless workstations (obviously).  I may have to ask
that question of some of the internal development folks.
Jim
Date: 21 Nov 2008 16:40:47
Message: <49272adf$1@news.povray.org>
I'm just saying that if you have (say) an executable and three related
dynamically-linked .so files, or you have a .so and a .h file, there's
no way in Linux to ensure that you can update them consistently, as far
as I know. (I learn Linux tricks by telling people Linux can't do
something, and then people correct me. ;-)
Date: 21 Nov 2008 23:03:26
Message: <4927848e$1@news.povray.org>
>> (on top of the actual filesystem at the kernel level - not sure what
>> it's specifically called, probably some sort of abstraction layer)
>> deals in inodes rather than files.
I'm not quite sure what you mean by "ensure that you can update them
consistently" - since a file that's open can be overwritten or deleted
because of the nature of that filesystem abstraction layer, why would you
not be able to update it consistently?
Jim
Date: 22 Nov 2008 12:46:35
Message: <4928457b$1@news.povray.org>
> why would you not be able to update it consistently?
You write the .h file. While trying to write the .so file, you
A) don't have permissions to do so,
B) find that it's open by someone else as a shared text segment,
C) run out of disk space,
D) have your process killed,
E) have the power fail,
Date: 23 Nov 2008 00:03:38
Message: <4928e42a$1@news.povray.org>
> You write the .h file. While trying to write the .so file, you A) don't
The updater requires root rights to run, so it has permissions to do that.
I don't believe that would matter, again, it's the inode that's open, and
when the file is overwritten a new inode is created and the old one is
destroyed.
That would create other problems as well - as would running out of system
filehandles (which is interesting to watch on *nix systems - I wrote a
program to malloc() all the memory in a system once when in college - was
to get students off of workstations when they were playing the local MUD
if there were students who had actual work to do and there were no
machines available.  Once the malloc() program ran they couldn't even run
ps to find out what happened - just had to stop-A the system and reboot.
Interesting to watch on the Sun SLC Diskless workstations, because they'd
swap over the network to the server in the server room - which is
invariably where we ran it from, so we could see all the disk activity.
Yeah, those could happen and could introduce problems - so you just
reinstall the packages and that makes things consistent.  Come to think,
I've had to do that once or twice.
Jim
