POV-Ray : Newsgroups : povray.off-topic : A silly little toy (~200 kb) Server Time
27 Jun 2026 20:00:41 EDT (-0400)
  A silly little toy (~200 kb) (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: A silly little toy (~200 kb)
Date: 15 Oct 2008 14:54:37
Message: <48f63c6d$1@news.povray.org>
nemesis wrote:
> Everyone loves to design languages.  Parsec?
Yeah, Parsec. ;-)
http://blog.orphi.me.uk/
Date: 15 Oct 2008 14:56:50
Message: <48f63cf2$1@news.povray.org>
Nicolas Alvarez wrote:
> Will it solve simple stuff like "x + 1 = 3" in version 1.5? :)
Probably not.
Logic programming systems like this are more targetted at questions like
"if Sue is Helen's mother and Helen is Jamie's mother, is James related
to Helen?" and similar.
Currently the thing has no way to store "facts" and no way to define new
predicate functions. Once I add that... I will have basically
reimplemented the Prolog programming language. o_O
(Go look that up on Wikipedia BTW.)
Date: 15 Oct 2008 16:18:50
Message: <48f6502a$1@news.povray.org>
Orchid XP v8 wrote:
> Oh, OK. It's actually all very readable on my screen; I guess it has a
> higher gamma or something.
I actually live where it's sunny during the daytime. ;-)
I have trouble with a lot of video games, too.
> Actually I made the prompt bright and the input + result dim. :-} Maybe
> I should reverse that?
Couldn't hurt.
> BTW, are you impressed that I got this to work? Somebody wrote a small
> Haskell library that invokes windows.h under Windoze or emits ANSI
> escape sequences on POSIX. Neat, eh? Also, notice the window title
> bar... ;-)
Yep. I'm impressed. :-)
> Since "+" isn't a valid token,
Ah.
> This is one of the irritating things about Parsec. It can silently fail
> to parse all of the input. Like, if some prefix of the input is a valid
> expression but the rest isn't, it returns just the prefix. (Obviously it
> depends how you structure your parser.) I must figure out how to fix
> that...
Doesn't it also return the rest of the unparsed string? So if that isn't
empty, something failed?
Date: 15 Oct 2008 16:43:42
Message: <48f655fe@news.povray.org>
Ah, OK. My office at work [where I coded this program] has no sunlight.
I don't even know if it's day or night or whatever. A bit like caving,
actually... random...
As for my bedroom at home... I just close the curtains when I want to
play HL2. ;-)
>> bar... ;-)
Heh. Actually I wrote a small library of my own that calls windows.h
directly. [You've seen the code, haven't you?] But somebody else came up
with a nice library that works on Windoze *and* POSIX, so now I'm using
that instead. So I really could compile my program for Linux or
something if I want.
> Ah.
>> fail to parse all of the input. Like, if some prefix of the input is a
>> valid expression but the rest isn't, it returns just the prefix.
>> (Obviously it depends how you structure your parser.) I must figure
>> out how to fix that...
Nope.
Remember, each "parser" can be combined with other parsers to make a
larger parser at any time. And it might be that the parser is only
*trying* to parse some prefix of the input.
I just asked about it, and some people recommended adding the "eof"
parser to the top-level parser. (This causes the parser to fail if the
entire input is not parsed. The error message is likely to be pretty
opaque though...)
BTW, have you tried making the parser deliberately fail? It doesn't just
crash the program, it actually reports a (moderately) friendly message
to the user. It even hilights where in your input it's upset - in case
you can't mentally work out where "column 28" is. Neat, eh? ;-)
Date: 16 Oct 2008 04:26:03
Message: <48f6fa9b$1@news.povray.org>
> Hey people, check it out: Attached to this post is a small program I
> wrote.
What does the result y <- #2 mean?
Try the two below:
@Element[x,{1,y}]
@Element[x,{y,1}]
The 2nd one contains the "y <- #2" result but the first one doesn't.
Also I agree with what Darren said, the dark blue used for the "<-" is a bit
too dark (visible, but hard to see, how about dark red instead?).
Date: 16 Oct 2008 04:34:31
Message: <48f6fc97$1@news.povray.org>
> Try the two below:
> @Element[x,{1,y}]
> @Element[x,{y,1}]
Consider the expression "?x: y = x". This is read as "there exists an x
such that y = x". What it "really" does is replace x with a unique
variable name (in this case, "#1").
The only reason you would do this is if you're running a recursive
predicate, so that successive recursions all get unique variable names.
Internally, all of the predefined functions except @Empty are recursive
and so use such variables.
Ordinarily, all these temporary variables either have nothing bound to
them, or are bound to a specific value. But occasionally they do show up
in the final result. In the example you give, "y <- #2" actually means
nothing at all, so the program should probably elide that. (It means
that y is equal to some temporary variable which itself doesn't have a
defined value, and hence y has no defined value - which would be the
same as the result set not mentioning y at all!)
See? This stuff is harder than it looks! ;-)
> bit too dark (visible, but hard to see, how about dark red instead?).
Hmm, yes, that *is* a little dark...
Date: 16 Oct 2008 08:26:56
Message: <48f73310$1@news.povray.org>
> Yeah, Parsec. ;-)
Wanna see the code?
Subject: Build #70 (bugfixes)
Date: 16 Oct 2008 08:56:03
Message: <48f739e3@news.povray.org>
Here it is, people: build #70.
Changes since the last released version:
- Fixed: Parser used to silently ignore invalid parts of the input, as
long as some prefix of it is a valid expression. (E.g., "x = 1 + 1"
would silently parse 'successfully' as "x = 1".) You should now get an
error message instead.
- Changed "<-" from dark blue to dark cyan. (On my system, that shows up
significantly brighter.)
Download 'logic.exe.dat' (183 KB)
Subject: Build #86 (user-defined functions)
Date: 16 Oct 2008 11:47:00
Message: <48f761f4@news.povray.org>
Well that didn't last long! Here's build #86. (I promise there won't be
any more for a while yet...)
Changes:
- The predicate "?x: a = x & b = x" now yields "a <- b" as you'd expect.
(It's a hack, so it doesn't always work.)
- Fixed a very evil bug where calling functions with certain variable
names as arguments would cause bizare malfunctions. (Basically the
variable names used inside the function clashing with the arguments
passed in. This *should* be fixed now...)
- Functions are no longer hard-wired into the program; you can define
your own! The Library.txt file (it must be called exactly that) contains
the definitions. If this file doesn't exist or is not parsable,
currently the situation isn't handled terribly gracefully.
I've included the hard-wired functions, but feel free to add your own!
Download 'logic.exe.dat' (189 KB) Download 'us-ascii' (1 KB)
Date: 16 Oct 2008 13:46:10
Message: <48f77de2$1@news.povray.org>
> (or does it already...?)
Actually... if you encode "numbers" as lists of 1s of the appropriate
length, then the @Join[] function essentially implements addition and
subtraction! o_O
@Join[{1, 1}, {1, 1}, z]
z <- {1, 1, 1, 1}
@Join[{1, 1, 1}, y, {1, 1, 1, 1, 1}]
y <- {1, 1}
etc.
Obviously this isn't an especially intuitive or efficient way to work,
but hey - Peano integers FTW! :-D
