![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Kyle wrote:
> It's always more exciting to stick your tongue to it. ;-)
"Exciting" is one way to put it. :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott wrote:
> Fuses do not act fast enough to stop you getting a lethal dose of
> current. That's why RCD devices are used.
Maybe. Personally I'd prefer to avoid having to find out either way. ;-)
>> That worked for about 20 minutes, and then the ends unhooked.
>> Frustrated, my dad picked up the ends again... and then got up off the
>> floor and UNPLUGED THE HEATER before repeating this action. ;-)
> Luckily I guess the shock disconnected him from the supply before any
> serious damage was done.
Er, yeah.
The closest thing I've done it touch an electric fence. Jesus, no WONDER
the cattle stay the **** away from that thing! o_O
Of course, it isn't permanently live, it pulses. Was quite funny
watching the class idiot try this, actually. (This was on a different
day.) I walk up to the fence, briefly tap it, and loudly yell "oh, it's
not turned on". Class idiot saunters over and grips it. "Hey, no, it
isn't o-ho-HUGG!" Looked like somebody had just kicked him.
Ah, we really hated that guy...
> if, for some reason, the shock made him grip
> the ends tighter then he would have likely died. I have seen several
> people who "flick" the end of a wire to see if it is live or not. I
> think it's the amount of time as well as the current, plus how well you
> are connected to other stuff etc. PErsonally, I wouldn't want to risk it!
My dad has also been hit by lightning, FWIW.
Basically, the dude is unkillable! >:-D
(And I inherited his genes...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible <voi### [at] dev null> wrote:
> For example, that plug you use to plug normal equipment into the
> electricity grid. Apparently there's a name for it. It's called "BS
> 1363". (Memorable, eh?)
The model used here is http://en.wikipedia.org/wiki/Schuko
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I see. So you can't put your fingers behind the plug while plugging it
in without shearing your fingertips off. Well, that's another way to
solve that problem. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I see. So you can't put your fingers behind the plug while plugging it in
> without shearing your fingertips off. Well, that's another way to solve
> that problem. ;-)
I don't know about Finland, but here in Germany only higher power/earthed
equipment uses the Schuko plug, for lower powered stuff usually the Europlug
is used (which also fits into the Schuko sockets fine of course).
http://en.wikipedia.org/wiki/Europlug
You can buy multi-way mains extensions with sockets for combinations of
schuko and europlug, quite handy for eg an office because a lot of equipment
(phone chargers, laptop PSUs etc) uses Europlug and the sockets are much
smaller.
Also from that page above:
"It is, in principle, possible to insert a Europlug into a BS 1363 socket by
inserting another object (such as a screwdriver or key) into the earth hole
first."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> power/earthed equipment uses the Schuko plug, for lower powered stuff
> usually the Europlug is used (which also fits into the Schuko sockets
> fine of course).
Interesting. That looks rather like the plug you often find on electric
shavers here. (Some bathrooms have a suitable socket for such a thing.)
> equipment (phone chargers, laptop PSUs etc) uses Europlug and the
> sockets are much smaller.
Now, see, in the UK, *everything* comes with a single type of plug, and
*all* sockets are of a single type. (The only real exception being
shavers. And these invariably come with an adaptor plug.)
> socket by inserting another object (such as a screwdriver or key) into
> the earth hole first."
I am *so* not trying that! :-/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh I forgot, we also have this type in Germany too:
http://en.wikipedia.org/wiki/Image:CEE_7-17_plug.jpg
It is for higher current devices that don't need Earth (eg hairdryers), fits
in the Schuko socket but the plug is not as big.
It was an emergency, my laptop needed to be recharged!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> and *all* sockets are of a single type. (The only real exception being
Looks pretty much identical to me...
Um, noooo... the "emergency" is when you arrive at A&E with a heart that
isn't beating any more. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> being shavers. And these invariably come with an adaptor plug.)
Whereupon they connect you to a massive electrical kick. :-)
"Eppur si muove" - Galileo Galilei
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Massive and very carefully timed. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
