POV-Ray : Newsgroups : povray.off-topic : You lose some... Server Time
16 May 2026 09:46:44 EDT (-0400)
  You lose some... (Message 1 to 10 of 31)
Subject: You lose some...
Date: 4 Oct 2008 14:37:18
Message: <48e7b7de$1@news.povray.org>
Hmm, and I though everything was going so well. :-/
OK, any C++ experts have any idea why this code snippet causes my
program to crash at runtime?
   typedef std::vector<bool> Codeword;
   std::string codeword(const Codeword &c)
     std::string out;
     for (unsigned int i=0; i<c.size(); i++)
       if (c[i]) out.append("1"); else out.append("0");
     return out;
"Unhandled exception at 0x00414166 in Huffman01.exe: 0xC0000005: Access
violation reading location 0x00000004."
The code looks fine to me - but what I do know?
http://blog.orphi.me.uk/
Subject: Re: You lose some...
Date: 4 Oct 2008 15:51:54
Message: <48e7c95a@news.povray.org>
>      std::string out;
>      return out;
  I can't see anything wrong with it, and I tried it and there was
nothing wrong with it. The error must be somewhere else.
  If you are running it in linux, try running it using valgrind (if you
don't have it, install it; it's essential). In other words:
valgrind ./yourprogram
  If will tell you if you have some out-of-bounds access or memory leaks.
Date: 4 Oct 2008 16:09:39
Message: <48e7cd83$1@news.povray.org>
Right. So maybe I'm passing it a reference to something that doesn't
exist anymore then?
M$ Visual Studio is telling me something is wrong, but it isn't telling
me much beyond that. (I probably need to figure out how to work the
debugger first...)
Date: 4 Oct 2008 16:47:23
Message: <48e7d65b@news.povray.org>
> exist anymore then?
  Without seeing the whole program it's impossible to tell.
  Btw, have you been using the at() function rather than operator [] like
I have been suggesting?
> debugger first...)
  Just compile in debug mode and run the debugger (F5).
  However, the Visual Studio debugger won't tell you if you have, for
example, a memory leak. The place where the program crashes (which will
be shown by the debugger) is not necessarily the place where the bug is.
It might be able to tell you if you are writing out of bounds or accessing
freed memory, but not necessarily. Valgrind will be able to do that.
Unfortunately, AFAIK, valgrind is not available for Windows or VS projects,
so you'll have to do the testing in linux.
  (Profilers like valgrind which support VS programs in Windows exist,
but I know of no free one.)
Date: 4 Oct 2008 18:27:56
Message: <48e7edec$1@news.povray.org>
True; sometimes you have to step carefully through the program to see what
it's doing and figure out where your memory management is going wrong. In
this case though, the error is
Access violation reading location 0x00000004 means it's very likely you're
dereferencing a NULL pointer somewhere, because of how close 4 is to 0. (The
program is taking a NULL pointer, treating it as a struct or class of some
sort, and trying to get the member that is 4 bytes into it.) So, if you just
hit F5 and run the program as usual, it will tell you right where it is when
it crashes by pointing at the line. You can also look at the call stack pane
to see how it got there. It will probably be easy to see what the NULL
pointer is.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 4 Oct 2008 18:31:23
Message: <48e7eebb@news.povray.org>
This isn't the cause of your crash, but I recommend not squishing your code
together like that. Keep each statement on a separate line and use brackets
around anything that's not a single simple statement:
    for ( unsigned int i = 0; i < c.size(); i++ )
        if ( c[i] )
            out.append( "1" );
        else
            out.append( "0" );
Also put spaces around your operators like "=", "+" and "<". Readable code
is superior to short code.
 - Slime
Date: 5 Oct 2008 00:42:08
Message: <48e845a0$1@news.povray.org>
>         if ( c[i] )
>             out.append( "1" );
>         else
>             out.append( "0" );
If he wants brevity he could also code it like this:
  for (int i = 0; i < c.size(); i++)
    out.append(c[i] ? "1" : "0");
which is just as valid and avoids running the if/else together.
-- Chris
Date: 5 Oct 2008 05:17:59
Message: <48e88647$1@news.povray.org>
Yeah, seems plausible. (Except that I'm not using pointers anywhere,
only references.)
> So, if you just
> pointer is.
It's somewhere inside vector.cpp. (And the code makes *no sense* to me
at all. The comments mumble something about copy constructors though...)
Now if I could somehow figure out which part of *my* code is calling the
failing routine, and with what arguments, I'd have a shot...
Subject: Some code
Date: 5 Oct 2008 05:28:31
Message: <48e888bf$1@news.povray.org>
Well, the program isn't that large, so just for a giggle I'll include it
here. The compiler claims there's nothing wrong with it, but clearly
there is. I can't wait to see how many different kinds of mistake I've
made... :-}
#include <iostream>
#include <vector>
#include <string>
typedef char Symbol;
   std::string out;
   return out;
class SymbolInfo
public:
   Symbol symbol;
   double prob;
   Codeword code;
   SymbolInfo(Symbol s, double pr) : code()
     symbol = s;
     prob = pr;
   void prefix(const bool p)
     code.push_back(p);
class Tree
public:
   Tree(SymbolInfo& s) : symbols()
     symbols.push_back(s);
     prob = s.prob;
   void join(const Tree& tree)
     for (unsigned int i=0; i<symbols.size(); i++)
       symbols[i].prefix(false);
     for (unsigned int i=0; i<tree.symbols.size(); i++)
       SymbolInfo s = tree.symbols[i];
       s.prefix(true);
       prob += s.prob;
   const Codeword& lookup(const Symbol key)
       if (symbols[i].symbol == key) return symbols[i].code;
   const double Prob() {return prob;}
private:
   std::vector<SymbolInfo> symbols;
   double prob;
const Tree& build_tree(std::vector<SymbolInfo> info)
   std::vector<Tree> trees;
   for (unsigned int i=0; i<info.size(); i++)
     Tree t(info[i]);
     trees.push_back(t);
   while (trees.size() > 1)
     int index = 0;
     for (unsigned int i = 1; i<trees.size(); i++)
       if (trees[i].Prob() < trees[index].Prob()) index = i;
     Tree t0 = trees[index];
     trees.erase(trees.begin() + index);
     index = 0;
     Tree t1 = trees[index];
     t0.join(t1);
     trees.push_back(t0);
   return trees[0];
int main()
   SymbolInfo A('A', 0.5);
   SymbolInfo B('B', 0.25);
   SymbolInfo C('C', 0.125);
   SymbolInfo D('D', 0.125);
   symbols.push_back(A);
   symbols.push_back(B);
   symbols.push_back(C);
   symbols.push_back(D);
   Tree t = build_tree(symbols);
   std::cout << "A: " << codeword(t.lookup('A')) << std::endl;
   std::cout << "B: " << codeword(t.lookup('B')) << std::endl;
   std::cout << "C: " << codeword(t.lookup('C')) << std::endl;
   std::cout << "D: " << codeword(t.lookup('D')) << std::endl;
Date: 5 Oct 2008 05:43:27
Message: <48e88c3f@news.povray.org>
> It's somewhere inside vector.cpp. (And the code makes *no sense* to me at
Yeah, the STL code provided with visual studio is very unreadable.
You need to find the call stack window. It will give you a list of the
functions that called each other to get where the code is currently
executing. It should be one of the tabs along the bottom when debugging, or
you might have to look through the menus (under "window" or "debug") to turn
it on. Then you can double click on each level of function call and see what
its local variables' values are.
 - Slime
