POV-Ray : Newsgroups : povray.off-topic : You lose some... Server Time
16 May 2026 13:51:29 EDT (-0400)
  You lose some... (Message 21 to 30 of 31)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: You lose some...
Date: 5 Oct 2008 09:35:28
Message: <48E8C2ED.3070400@hotmail.com>
On 05-Oct-08 6:42, Chris Cason wrote:
> Slime wrote:
>>>     for (unsigned int i=0; i<c.size(); i++)
>>>       if (c[i]) out.append("1"); else out.append("0");
>> This isn't the cause of your crash, but I recommend not squishing your code
>> together like that. Keep each statement on a separate line and use brackets
>> around anything that's not a single simple statement:
>>     for ( unsigned int i = 0; i < c.size(); i++ )
>>         if ( c[i] )
>>             out.append( "1" );
>>         else
>>             out.append( "0" );
> If he wants brevity he could also code it like this:
>   for (int i = 0; i < c.size(); i++)
>     out.append(c[i] ? "1" : "0");
> which is just as valid and avoids running the if/else together.
Didn't we code that more like out.append("0" + c[i]) just to confuse the
readers?
Date: 5 Oct 2008 09:51:11
Message: <op.uij0rkwh7bxctx@e6600>
On Sun, 05 Oct 2008 15:36:45 +0200, andrel <a_l### [at] hotmailcom>
> readers?
Nitpick: It has to be '0', not "0".
You could also do it like this:
	out += c[i]["01"];
If you were in a particularly foul mood, you could write it like this:
	out += c??(i??)??("01"??);
FE
Date: 5 Oct 2008 09:51:41
Message: <48E8C6BB.4040202@hotmail.com>
>>> your code together like that. Keep each statement on a separate line
>>> and use brackets around anything that's not a single simple statement:
>>>         if ( c[i] )
>>>             out.append( "1" );
>>>         else
>>>             out.append( "0" );
> readers?
Been a long time since I actually did write sufficient amount of C. :( I
think I meant the character constant '0' and not the string "0".
Date: 5 Oct 2008 09:54:55
Message: <48E8C77C.9060509@hotmail.com>
>> the readers?
Yeah I remembered too late.
>     out += c[i]["01"];
Is that C or C++?
what += does??(that??)??("Mean"??)
Date: 5 Oct 2008 10:03:35
Message: <op.uij1b8k97bxctx@e6600>
On Sun, 05 Oct 2008 15:56:12 +0200, andrel <a_l### [at] hotmailcom>
>>     out += c[i]["01"];
> Is that C or C++?
Either.
??( is an alternative token for [. Similarly for ??) and ].
FE
Date: 5 Oct 2008 10:38:24
Message: <48E8D1AE.7020501@hotmail.com>
I don't remember that one. I seem to have dislocated my k&r and bjarne
books and I seem not to be able to find that on the web either. Are you
sure that that isn't just a compiler/hardware specific hack?
Date: 5 Oct 2008 11:12:44
Message: <48e8d96c@news.povray.org>
http://en.wikipedia.org/wiki/C_trigraph
Date: 5 Oct 2008 11:18:35
Message: <op.uij4s9vt7bxctx@e6600>
On Sun, 05 Oct 2008 16:39:42 +0200, andrel <a_l### [at] hotmailcom>
Yes, I am sure. They are called trigraphs and are listed in section 2.3 of
the C++ standard.
Strictly speaking, they are not actually alternative tokens. They are
substituted before any other processing of the source.
There is a set of actual alternative tokens though. They are sometimes
called digraphs. You could thus write:
	out += c<:i:><:"01":>;
FE
Date: 5 Oct 2008 11:46:46
Message: <48E8E1B4.3050004@hotmail.com>
Thanks warp and frederick. This wiki page still keeps me wondering when
these trigraphs were introduced. Must be before the 1994 digraphs (which
is indeed long after my sort of formal training in C).
I could not find them with google. searching for ??) did not give any
result. Any of the google wizards know what I should have asked? (Apart
from trigraph, because that was the term I didn't know, otherwise I
would not be looking)
Date: 5 Oct 2008 12:22:55
Message: <op.uij7sgtx7bxctx@e6600>
On Sun, 05 Oct 2008 17:48:04 +0200, andrel <a_l### [at] hotmailcom>
wrote:
> This wiki page still keeps me wondering when these trigraphs were
> introduced. Must be before the 1994 digraphs (which is indeed long after
Late eighties I think.
FE
