![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> Mueen Nawaz <m.n### [at] ieee org> wrote:
> IMO there's the danger in such generic filtering that it will sometimes
> filter something which is *not* an ad, and might be relevant to the contents
> of the website.
Hasn't happened yet. Perhaps I did block non-ads, but they weren't
important enough for me to realize.
> I prefer using adblock on a site-by-site basis. In other words, whenever
> there's an obnoxious ad that bothers my concentration, I block images from
> that url+path.
I used to do it on a site basis, but it didn't work well for me. I
don't want to merely remove ads from sites I visit often. I want to
remove them from as many sites as possible, including a site I've never
seen that I may visit today.
Inoculatte: To take coffee intravenously when you are running late.
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mueen Nawaz nous illumina en ce 2008-09-19 11:27 -->
>> contents
>> of the website.
>> whenever
>> from
>> that url+path.
With adblock, you can use "*" as a wildcard. So, I want to block some add? I
right-click the offending add and sélect block... In the dialog that show up, I
replace most of the string by a single *. Hit the return key and close. Voilà, I
see about 12+ ads disapear at once :) And if I encounter add by that server
anywhere else, they to, are blocked.
Some of the blocking strings are: "*doubleclick*", "*adbrite*", "*adserve*",...
or something like "<some site URL>/banner/*" if I want to remove the banners but
not the rest of the content.
You know you've been raytracing too long when you look at waterfalls, dust,
rain, snow, etc, and think: "If only I had a fractalized, vector based
particle-system modeler with collision detection!"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Alain wrote:
> There is a FlashBlock addon available. I have it. It's one of those
> "can't live without" things, side by side with the addblock addon.
I have a flash-block! On my WinXP laptop, the privileged account can see
flash, and the non-administrator account doesn't show it. I haven't
quite figured that out. I even tried granting privs to the usual
account, installing flash, and revoking the privs, and it still doesn't
work. (Hmmm... I'll have to see if it works if I try it with the privs
turned on.)
Any ideas?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> turned on.)
> Any ideas?
FLASH! OHHH! KING OF THE IMPOSSIBLE!
(Er... sorry about that.)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> True. But turning off "load images" and "load Java" and "load
> JavaScript" stops them from appearing. So I'm guessing the options are
> just badly named.
You said half of the pages are made with JS, so I'd guess disabling JS
would disable those adverts.
I have pretty simple solution myself - I don't have flash player installed.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
