POV-Ray : Newsgroups : povray.off-topic : Simply CGI Server Time
16 May 2026 13:08:20 EDT (-0400)
  Simply CGI (Message 16 to 25 of 25)
Subject: Re: Simply CGI
Date: 13 Sep 2008 08:57:03
Message: <48cbb89f@news.povray.org>
Orchid XP v8 a écrit :
>> Or better still, launch shttpd with the appropriate option telling it
>> that .exe are CGI files:
>> shttpd -cgi_ext "exe"
> Also tried that and it didn't work.
> The hack above does, however, work.
OK, so that's one more reason for me to keep running Linux I guess,
where it works fine and starts instantaneously :-)
Maybe you should throw a note to the author though, perhaps the
behaviour on Windows is not what's intended...
Vincent
Date: 13 Sep 2008 08:58:17
Message: <48cbb8e9$1@news.povray.org>
Warp wrote:
>   You got a web server and you didn't install it? How can that work?
You put the executable file in a directory, double-click it, and it
runs. Nothing to install, nothing to uninstall afterwards. And only a
few hundred KB too. Which is basically what I was looking for...
http://blog.orphi.me.uk/
Date: 13 Sep 2008 09:01:21
Message: <48cbb9a1$1@news.povray.org>
So you've installed it. OTOH you haven't needed to configure it or your
system.
John
"Eppur si muove" - Galileo Galilei
Date: 13 Sep 2008 09:57:47
Message: <48cbc6db@news.povray.org>
  We clearly have completely different definitions of "installing a
program".
Date: 13 Sep 2008 10:14:47
Message: <48cbcad7$1@news.povray.org>
> program".
Yes.
To me, if you can use a program just by running it, that's not
"installing" it.
If, however, you have to insert DLLs into particular folders, create
registry keys and configure environment variables, that's "installing"
something.
The former means you can just drop the binary only (say) a USB flash
drive and use it anywhere. The latter means that you have to do some
setup (and probably removal) at every PC.
Date: 13 Sep 2008 11:00:21
Message: <48cbd584@news.povray.org>
> > program".
> Yes.
  My definition of "installing" is clear and unambiguous. Your definition
is rather fuzzy.
> "installing" it.
> something.
  What if it doesn't install DLLs but creates registy keys and configures
environment variables? Is it then installing? What if it doesn't configure
environment variables? Is it still installing? What if it installs DLLs
but doesn't create a registry key?
  But you didn't "drop the binary only a USB flash drive" (whatever that
may mean). You installed it in your system.
Date: 15 Sep 2008 07:07:16
Message: <48ce41e4@news.povray.org>
I've used thttpd in a number of embedded systems. Seems to do the job well
and is a single executable.
-- Chris
Date: 19 Sep 2008 15:14:38
Message: <48d3fa1e$1@news.povray.org>
Orchid XP v8 wrote:
> I had a look here this morning. Sadly, almost everything requires you to
> "install" it before you can use it. I was hoping for a single executable
> solution.
http://www.tcl.tk/software/tclhttpd/
The TclHttpd Starkit distribution includes the server code, the required
TclLib modules, and a sample document tree in a single file for easy
deployment. Just run the starkit with the TclKit interpreter. It takes
all the same command line arguments as bin/httpd.tcl. Using the sdx tool
that wraps and unwraps Starkits, you can assemble your own custom
TclHttpd application Starkit.
Date: 25 Sep 2008 05:45:34
Message: <48db5dbe$1@news.povray.org>
Orchid XP v8 wrote:
> OK, *finally*...
> Create a small file called Foo.cgi that simply contains the line
>   #!Foo.exe
> and *at last* the server does what I want it to!
Now I'm confused! I just tried this at work... and it fails. WTF?
Date: 25 Sep 2008 05:57:07
Message: <48db6073@news.povray.org>
Unfortunately, I can't find a precompiled Windows binary anywhere...
