POV-Ray : Newsgroups : povray.off-topic : Games programmers Server Time
4 Jul 2026 12:10:22 EDT (-0400)
  Games programmers (Message 81 to 90 of 179)
Subject: Re: Games programmers
Date: 12 Sep 2008 09:12:15
Message: <48ca6aaf@news.povray.org>
andrel <a_l### [at] hotmailcom> wrote:
> >>   while(*v++ = *s++);
> >> I mean, what THE HELL...?
> A nice example of language design inspired by hardware (and vice versa).
> May result in very fast code.
  Actually a memcpy() call would probably be faster (at least if you know
the amount of data to copy).
Date: 12 Sep 2008 09:22:24
Message: <48ca6d10@news.povray.org>
>> I wouldn't exactly call that straightfoward either. It's not *actually*
>> complicated, but it sure *looks* pretty baffling.
>   But the haskell code is normal, regular haskell. Your C example is
> not code any sane person would write.
Mmm, and you think any sane Haskell programmer would implement the
Fibonaci numbers that way in a real program? It's an interesting
teaching example, but seriously, if you *want* Fibonacci numbers for
some reason, there is a simple, well-known O(1) algorithm for that.
>> Alternatively,
>>    while(*v++ = *s++);
>   At least it's easy to understand what it does (and why it works) when
> it's explained. The haskell example isn't.
Really? I mean, it's a little perplexing that the computer is actually
able to unravel it without getting stuck, but once you understand what
the machine is doing internally, it's not so hard.
http://blog.orphi.me.uk/
Date: 12 Sep 2008 09:32:04
Message: <48CA6F9B.2000506@hotmail.com>
>>> *actually* complicated, but it sure *looks* pretty baffling.
>>> Alternatively,
>>>    while(*v++ = *s++);
You mean that you not only understands how it works, but it even helped
you understand how compilers work?
Date: 12 Sep 2008 09:35:35
Message: <op.uhdeq50gc3xi7v@news.povray.org>
And lo on Fri, 12 Sep 2008 09:16:07 +0100, Invisible <voi### [at] devnull> did
spake, saying:
>>> Haskell is a small, simple, logical language. C++ is a huge, messy,
>>> complex language. I don't see how learning an easy language should
>>> enable me to learn a hard language.
>>  Heh, Haskell looks complicated and hard to learn to me.
> Well, I guess there are probably people who look at something like
>    x = (-b +- Sqrt(b^2 - 4ac)/2a
> and go "OH MY GOD! That looks SO complicated!" But actually, if you know
> a little algebra, you discover that this contraption is actually quite
> straight forward.
But look at the knowledge you need for that. We'll assume that the basics
are covered = + - x ÷ and that you recognise the x, a, b, and c parts of
the equation. First up we get - how can you start with a - symbol, what am
I subtracting b from? Next is a ±; okay you hopefully recognise that it's
a + and a - combined, but how do I add and subtract at the same time? Then
we get a √ um okay the shape of that gives no clue unless you just know
it. Then ² which we might know as shorthand for b x b as many times as the
number. Then we get an 4ac, is that a new character; you know a-z, aa-az,
etc? You have to know that it's shorthand for 4 x a x c. Then finally you
get a / or just one big line which you need to recognise as a ÷.
Spell out all the assumed shorthand plus symbols there and you can see why
it could legitimately be considered complicated.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 12 Sep 2008 09:37:05
Message: <48ca7081$1@news.povray.org>
Well I mean *notionally*, the way Haskell executes is fairly simple. In
the case of the magic tail-chasing fibs definition, fibs starts out as a
list where some list cells are defined, and some haven't been computed
yet. And the ones that haven't been computed yet refer to the ones that
have. (If it were the other way round, you WOULD have a problem.) As you
ask for list cells, they get computed, one by one, until you get the one
you want.
It's a nice example of how lazy evaluation allows you to program in
unusual ways, but it's probably not terrifically practical unless you
only need a handful of Fibonacci numbers.
Date: 12 Sep 2008 09:37:50
Message: <48ca70ae@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48ca500c@news.povray.org...
>>>   while(*v++ = *s++);
>> I doubt that's the recommended way of copying an array any longer
> I doubt that was *ever* the "recommended" way. And yet I, a person who
> doesn't know C very well, am aware of this example. What does that tell
> you? ;-)
That you're looking for examples of why the language is incomprehensible.
That you had a bad lecturer/textbook at university
That you're reading up on why C++ is bad and what constructs are known to
cause problems.
Taking the example to my prefered language, I'd say that 80% of people who
have worked much with SQL can and will use cursors, yet every expert in SQL
will tell people to never use them
Does that mean that SQL is incomprehensible to the average person and a
language that's easy to break things in?
Date: 12 Sep 2008 09:57:10
Message: <48ca7536$1@news.povray.org>
>> tell you? ;-)
Doesn't take much looking, does it?
> That you had a bad lecturer/textbook at university.
The long and short is, I spent several months at college using C, and I
always round it excrusiatingly difficult to get any of the programs to
work properly. Unfortunately that's just the way C is designed; nothing
is checked, the programmer is assumed to know exactly what they're
doing, and if the programmer does something wrong... well that's just
too bad.
I'm sure this makes the compiler much easier to implement, and no doubt
it contributes to the efficiency and flexibility of the language, but...
I prefer having some kind of safety features in a programming langauge.
> to cause problems.
Actually... no.
> who have worked much with SQL can and will use cursors, yet every expert
> in SQL will tell people to never use them.
I guess it depends what you're trying to do. SQL certainly has a few
known flaws (default column orderings, anyone?), but in general it makes
it quite simple and easy to do most things.
In C, just concatinating two strings is an ugly, complex operation. In
fact, it seems to be easier to just write one string to stdout and then
write the other, rather than trying to actually concatinate them. The
language seems to make every tiny little operation really awkward and
difficult. No thanks...
Still, since I am the *only* person on the entire news server who thinks
this, I guess I should just let it go.
Date: 12 Sep 2008 09:58:36
Message: <48CA75D2.8010308@hotmail.com>
> spake, saying:
>> know a little algebra, you discover that this contraption is actually
>> quite straight forward.
> basics are covered = + - x ÷ and that you recognise the x, a, b, and c
> parts of the equation. First up we get - how can you start with a -
> symbol, what am I subtracting b from? Next is a ±; okay you hopefully
> recognise that it's a + and a - combined, but how do I add and subtract
> at the same time? Then we get a √ um okay the shape of that gives no
> clue unless you just know it. Then ² which we might know as shorthand
> for b x b as many times as the number. Then we get an 4ac, is that a new
> character; you know a-z, aa-az, etc? You have to know that it's
> shorthand for 4 x a x c. Then finally you get a / or just one big line
> why it could legitimately be considered complicated.
For me the most interesting thing is the ±, that one is quite rare in
highschool maths. Here, and I assume also elsewhere, it is pronounced as
'plus or minus'. Where the 'or' apparently means that we have to
consider one *and* the other. An obvious question is: 'How can it be
that an equation has more than one answer'? There is also the often
overlooked complication that formula manipulating normally consists of
equivalent transformations. Here we have something that isn't, it is
more of a bifurcation resulting in two separate formulas, neither of
which is equivalent to the original equation. It is not obvious how to
run this process in reverse. I think I learned that one later
separately, without being told the intimate connection to the ± in this
formula (or more precise the boolean thing hidden in there somewhere).
Date: 12 Sep 2008 10:01:02
Message: <48ca761e$1@news.povray.org>
Presumably *any* language will _look_ cryptic if you don't understand
it. The question is how easy it is or isn't to _learn_. ;-)
Date: 12 Sep 2008 10:16:06
Message: <48ca79a6$1@news.povray.org>
> Presumably *any* language will _look_ cryptic if you don't understand it.
I really don't understand why you find it so hard to learn C.
There are only a tiny number of core statements (like if, while, return etc)
and the syntax of them all is very similar.  How to write functions you just
have to learn, but that's the same for any language.  Writing mathematical
formulae is also very easy and similar to almost every other language (using
+ - / * etc).
If you want to get more advanced, then learn to handle arrays and what & and
* do (quite easy things to remember, not complex at all), and you're pretty
much set to understand 99.999% of C code out there - including things like
while(*v++ = *s++);
What's the problem?
