POV-Ray : Newsgroups : povray.off-topic : Games programmers Server Time
3 Jul 2026 15:48:39 EDT (-0400)
  Games programmers (Message 70 to 79 of 179)
Subject: Re: Games programmers
Date: 12 Sep 2008 03:55:36
Message: <48ca2078$1@news.povray.org>
>> I prefer the Eiffel way, where the compiler looks at your program and
>> automatically decides which things can be bound statically (with all the
>> optimisations that follow), and which things actually require dynamic
>> binding.
>   That's incompatible with precompiled and dynamically loadable libraries.
It's certainly incompatible with dynamic loading. I don't see a problem
with precompiled code though. (Provided the precompiled code isn't just
a blob of executable data but actually contains enough metadata.)
>   I have always wondered why so many "fancy" languages seem to completely
> disregard the idea of dynamically loadable libraries.
Because it's a tricky thing to get right? IDK.
Certainly the Java guys love to scream and shout about how easy this is
in Java. Which is amusing, because actually it *isn't* especially easy.
You still have to write a heap of code yourself to make this possible...
As an aside... does anybody here know anything about how Windoze DLLs
actually work?
>> Does it actually build a seperate copy of the function for each data
>> type, or just build one generic version that works with all of them?
>   How could it use one generic function for all possible data types,
> given that the data types can have different sizes and even have completely
> different implementations for their operators, etc?
Plain ordinary OOP manages to do this without difficulty. (Argue
amoungst yourselves about how *efficient* it is, but it works.)
>   One common misconception people have about templates is that they
> increase the size of the executable because the functions are created
> for each used type. However, this is only true in some cases.
>   If they were template functions, however, the ones which are never
> called are never instantiated.
>   Inlining can also help reducing the size of the executable, besides
> making the program faster.
>   The great thing about templates is that the compiler is able to optimize
> the code on a per-type basis.
...so templates are like a kind of less-stupid macro expansion system?
(Everybody *talks* about how great templates are, or how much templates
suck, but few people ever say what they *are*.)
>>>   Yes, debug checks are nice. They are nicer if you can turn them off
>>> for a final release.
>> There is certainly something to be said for that.
>> The problem is that, certainly with C anyway, there's no switch to turn
>> it ON in the first place. :-(
>   It depends on the compiler. Some compilers do insert checks in debug
> mode.
Mmm, OK. Well my only experience with writing C is Borland's C compiler
for MS-DOS. (Actually, that's a lie. It was a C++ compiler, but we only
wrote C.)
http://blog.orphi.me.uk/
Date: 12 Sep 2008 04:16:07
Message: <48ca2547$1@news.povray.org>
>> Haskell is a small, simple, logical language. C++ is a huge, messy,
>> complex language. I don't see how learning an easy language should enable
>> me to learn a hard language.
> Heh, Haskell looks complicated and hard to learn to me.
Well, I guess there are probably people who look at something like
   x = (-b +- Sqrt(b^2 - 4ac)/2a
and go "OH MY GOD! That looks SO complicated!" But actually, if you know
a little algebra, you discover that this contraption is actually quite
straight forward.
> I just think that if you have the brain
> to understand all of the constructs Haskell provides and why they're cool or
> interesting, you have the capability to do the same with any other language,
> especially a commonly used one.
Yes - because "commonly used" = "it's very easy". Oh, wait... :-P
>> I already *know* Java. ;-)
> Oh; aren't there Java programming jobs around?
My problem is that I'm not finding *any* programming jobs, for *any*
language. (Or rather, I can find a few jobs with titles like "senior
systems architect" and "lead developer", but I'm not finding anything
like "trainee programmer" or "graduate Java developer".)
>>> Why don't you put the time into it?
>> What makes you think I haven't?
> The fact that you haven't learned C++ yet. =)
FWIW, I also failed to learn Latin. And that's *supposed* to be easy!
> Well, aside from having a good debugger, you just need to be honest with
> yourself about what parts of your program you do or don't understand.
Well that's just it. It's not like I have any resources telling me how
to actually program in C++. I just sort of have to take a guess. Oddly
enough, that doesn't work very well.
> And of course, getting started is always hard. It took me at least two
> attempts (separated by learning other languages like JavaScript and VB) to
> learn C++.
Ah, VB... That *other* language I completely failed to learn.
>> As I say, the trouble is that if your program doesn't work, there is no
>> way you can ever find out why.
> Honestly, binary search with prints works in a lot of cases. If you know
> what the program is supposed to do, then you can identify the places it does
> something wrong.
Like I said, printing stuff out is usually the bit that won't work.
(Although I gather C++ at least managed to fix this part.)
>> (Especially if you're using something like OpenGL. It's an extremely
>> complicated API, and unless you pay money it's not possible to get hold of
>> useful documentation.)
> OpenGL can be difficult because if you do something wrong it will sometimes
> silently fail. And yeah, it's hard to get good documentation (I learned it
> by taking a class), but it's fun once you can use it so it may be worth
> buying a book on.
Possibly a dump question, but... can you actually call a C interface
from C++? At any rate, presumably you can completely forget Warp's
"don't use pointers" rule if you want to talk to OpenGL - or any other
API designed for C. ;-)
> Ultimately my point is this: I think you *can* learn it, and if you're
> looking for a good programming job, I think you have a lot to gain by doing
> so.
Hmm. A good Haskell programmer and a very bad C++ programmer. Which one
would you hire?
Date: 12 Sep 2008 04:44:54
Message: <48CA2C4D.1000408@hotmail.com>
>>> enable me to learn a hard language.
unbalanced parentheses in line 10
> straight forward.
Although very well known and easy I managed to have a proposition in my
thesis on this formula. Which, I admit, no one could understand unless
they knew what was not in my thesis (we are talking about an audience of
approximately just below one). ;)
>> I just think that if you have the brain to understand all of the
>> constructs Haskell provides and why they're cool or interesting, you
>> have the capability to do the same with any other language, especially
Some people study physics because they have not such a good memory, but
can remember if it makes sense. OTOH some people study medicine because
they can remember things but you don't have to understand (most of) it.
More people are studying medicine than physics, but that does not imply
that I could.
I did not contribute to this thread, because I had the feeling this
subject was beaten to death already. I case you forgot, I still think
that you should have stayed in research.
who told you that? Or is that because it can't be hard if they did it
already two thousand years ago?
Date: 12 Sep 2008 04:48:41
Message: <48ca2ce8@news.povray.org>
  At the cost of increased memory consumption (by a rather large factor)
and decreased performance. Plus it's difficult to make it work for native
types (at least with any kind of efficiency).
  I suppose you could think of them like that. Of course it's not the
whole story.
  (One example of templates being different from preprocessor macros
is that when you instantate a template function or class, it creates
an actual type, with a type name which the linker will see. Preprocessor
macros don't do that.)
> > mode.
> wrote C.)
  For example Visual C++ adds lots of checks into the compiled code in
debug mode (for example iterator range checks, vector bounds checks, etc).
  Not every memory error can be caught with it, though. But then you can
use a good profiler for the rest.
Date: 12 Sep 2008 04:55:28
Message: <48ca2e80@news.povray.org>
> straight forward.
  I wouldn't call this straightforward:
fibs = 0 : 1 : zipWith (+) fibs (tail fibs)
  Short? Yes. Clever? Yes. Easy for a non-haskell-programmer
non-mathematically-oriented person to understand? No.
  (The curious thing about that is that it's easy to convince a layman
that it works, but the more (procedural) programming you know, the harder
it will be to understand *why* it works (and isn't, for example, an infinite
recursion that never terminates, as there doesn't seem to be any kind of
termination condition). Also understanding why it procudes the correct
result may be difficult.)
> from C++?
  That's the whole idea.
  I don't recall OpenGL requiring that many pointers either. Just tons
of straight function calls.
Date: 12 Sep 2008 06:02:14
Message: <48ca3e26@news.povray.org>
>> At any rate, presumably you can completely forget Warp's "don't use
>> pointers" rule if you want to talk to OpenGL - or any other API
>> designed for C. ;-)
OpenGL returns lots of IDs for all kinds of stuff, but they are more like
handles.
Date: 12 Sep 2008 06:05:46
Message: <48ca3efa$1@news.povray.org>
OK, well how about this:
   while (TRUE) { cont = (*cont)(); }
I wouldn't exactly call that straightfoward either. It's not *actually*
complicated, but it sure *looks* pretty baffling.
Alternatively,
   while(*v++ = *s++);
I mean, what THE HELL...?
Mmm, actually... yes, doesn't it tend to refer to thing by numerical
indecies rather than actual pointers?
Date: 12 Sep 2008 06:58:31
Message: <48ca4b57@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48ca3efa$1@news.povray.org...
>   while(*v++ = *s++);
I doubt that's the recommended way of copying an array any longer
Date: 12 Sep 2008 07:18:36
Message: <48ca500c@news.povray.org>
>>   while(*v++ = *s++);
I doubt that was *ever* the "recommended" way. And yet I, a person who
doesn't know C very well, am aware of this example. What does that tell
you? ;-)
Date: 12 Sep 2008 08:11:30
Message: <48CA5CB9.9030301@hotmail.com>
>>   while(*v++ = *s++);
A nice example of language design inspired by hardware (and vice versa).
May result in very fast code.
I don't think it is a problem as long as the string is known to be null
terminated. Don't put it in a library though. These are bound to be used
by people who have never heard of the concept of preconditions. Or
yourself in a weak moment after midnight.
