POV-Ray : Newsgroups : povray.off-topic : Coolest thing EVER! Server Time
16 May 2026 19:13:39 EDT (-0400)
  Coolest thing EVER! (Message 51 to 60 of 112)
Subject: Re: Coolest thing EVER!
Date: 1 Sep 2008 11:13:08
Message: <48bc0684$1@news.povray.org>
Gail wrote:
> Then, of course, there's Hyper-V built into Server 2008.
Which, according to Hype(tm) is Ultimately New Technology Innovation By
Microsoft(R), since it uses the Brand-New Never-Before-Seen hypervisor
technology (which is, still according to the same Hype(tm), pretty much
similar as in Xen and AFAIK with ESXi, but apparently they don't count,
since Innovating Sells).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 11:20:54
Message: <48bc0856$1@news.povray.org>
Gail wrote:
> Indeed. The problem with multiple SQL instances in VMs is IO. You can
> allocate CPUs and memory to specific VMs, but there's still a single IO
> channel, and SQL database tend to be IO bound more often than CPU or
> memory.
With Xen you can allocate whole disks or RAID-arrays or whatever and
amount X of RAM to be used straightly by the VM. In my experience the
lag is mostly unnoticeable (yes, it probably will be more noticeable
with DB-server, which I'm not running on VMs (well, there are MySQL
installations on at least 2 VM's, but they're really small DBs), but
depending on DB-size etc the saved cost of another HW can possibly give
you even better HW for that one machine to have better IOs for the DB,
it's not purely black and white).
Then again, MS surely don't want to support Xen, while they're working
on HyperV - no wonder SQL Server ain't supported on such
competitor-software ;).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 11:21:56
Message: <48bc0894@news.povray.org>
"Eero Ahonen" <aer### [at] removethiszbxtnetinvalid> wrote in message
news:48bc0684$1@news.povray.org...
No one ever suggested that MS's marketing dept was 'honest'. I've heard a
couple of MS developers complaining about the massaged facts the marketing
dept was pushing.
Date: 1 Sep 2008 11:22:57
Message: <48bc08d1$1@news.povray.org>
Darren New wrote:
> How many machine instructions do you think it takes to execute an
> interpreter for a machine instruction?
How about, hmm, "A LOT"?
The IA32 instruction set is a twisted tangle with no reason or rhyme to
it. The op-codes follow no particular pattern. The instruction lengths
very widely. What with MMX, 3D NOW!, SSE, SSE2 and so on, there's dozens
of registers of all different shapes and sizes. And we haven't even
talked about all the emulation required for the I/O devices...
> A hundred maybe, but a million?
Last time I checked, the IA32 instruction set is *very* complex. I doubt
it's got any simpler since then...
http://blog.orphi.me.uk/
Date: 1 Sep 2008 11:24:45
Message: <48bc093d@news.povray.org>
>> I've heard of plenty of VMs that run on Linux, but I wasn't aware that
>> any free ones existed for Windoze.
> Go to microsoft.com and do a search. :-)
Yeah, if I had *wanted* to find one, this would be the first stage.
However, as I said, I assumed that any VM would be absurdly slow and
therefore unusable, so I didn't bother looking for one. (Not to mention
that it's not immediately obvious just how useful these things are until
you've played with one...)
Date: 1 Sep 2008 11:26:51
Message: <48bc09bb$1@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> Presumably that requires *very* specialised hardware though?
> Yes, but nowadays it's built into all the CPUs already. You couldn't do
> something like this on, say, a 68000 or an 8086.
So when you say "works on any reasonably modern PC", what you *actually*
mean is "works on any brand new bleeding-edge PC"?
For example, it wouldn't work on the Pentium-III server in my server
room. (?)
Date: 1 Sep 2008 11:28:42
Message: <48bc0a2a$1@news.povray.org>
> a couple of MS developers complaining about the massaged facts the
> marketing dept was pushing.
One might argue that if MS were to be "honest" about their products,
they'd never sell any because they all suck so much...
...especially if that "one" happens to be a Linux advocate. ;-)
Date: 1 Sep 2008 11:37:45
Message: <48bc0c49@news.povray.org>
Darren New wrote:
> I've been thinking of playing with some virtual machine technology, but
> I wasn't aware there was one under Windows that would run Linux. Which
> virtual machine are you running here? (I.e., what's the Windows software?)
	And I'll give another nod to VirtualBox. It's free, and running Windows
on it was a breeze. I assume the same is the case the other way round.
	Haven't used VMWare products. They're more well known, though.
Computer Lie #1: You'll never use all that disk space.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 1 Sep 2008 11:37:54
Message: <48bc0c52@news.povray.org>
news:48bc0856$1@news.povray.org...
but
No, it's not.
In my experience though, the majority of DB servers that have bottlenecks
have IO ones, even on physical machines. Virtualising those means needing
separate IO paths, separate physical raid arrays, etc or the virtuals will
compeate with one another for IO. I know that all the SQL MVPs who have
given an opinion on this have recommend not virtualising a production DB,
especially not a large one with lots of activity.
I'd happily virtualise a dev or test environment. Not happy about doing it
to a heavily-utilised prod server though. Not right now.
> Then again, MS surely don't want to support Xen, while they're working on
> HyperV - no wonder SQL Server ain't supported on such competitor-software
Well, VMWare's joined the SVVP
(http://www.windowsservercatalog.com/svvp.aspx?svvppage=svvp.htm), so
there'll have to be some level of support. How much remains to be seen.
SQL's not supported at all on existing MS virtualisation products (virtual
server, virtual PC) and it's not currently supported on Hyper-V (which has
been available for a month or so)
Date: 1 Sep 2008 11:51:33
Message: <48bc0f85@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48bc09bb$1@news.povray.org...
No, he means any modern PC.
> For example, it wouldn't work on the Pentium-III server in my server room.
Sure it would.
Virtual PC requires minimum a 400 MHz Pentium-compatible processor.
VMWare version 5 (previous version) requires a 400MHz processor from the
following list:
# Intel: Celeron, Pentium II, Pentium III, Pentium 4, Pentium M (including
computers with CentrinoT mobile technology), XeonT (including "Prestonia")
# AMDT: AthlonT, Athlon MP, Athlon XP, DuronT, OpteronT
