POV-Ray : Newsgroups : povray.off-topic : Data recovery Server Time
7 Apr 2026 10:57:12 EDT (-0400)
  Data recovery (Message 69 to 78 of 128)
Subject: Re: Data recovery
Date: 1 Sep 2008 05:29:42
Message: <48bbb606$1@news.povray.org>
>> Games don't have to be complex to be fun. (Tetris, anyone?) They *do*
>> however need to be sufficiently devoid of irritating features like being
>> hard to control or hard to see.
> Agreed. Wonder why some phones come with games like golf (HUH??) instead
> of
> snake or tetris or something like that.
I prefer the slower games where you don't need to be able to press 4 keys in
1 second to stay alive (tetris!).  Maybe I need bigger keys on my phone, and
does any phone actually allow you to press more than one key simultaneously?
Date: 1 Sep 2008 08:35:00
Message: <web.48bbe038d89d321b80197cfe0@news.povray.org>
>     Gah, I feel for you!
>      (Hope you are well).
>        ~Steve~
more than 4 years) and one on XP. Early on (after my first HD crash which
each on a single physical drive, which means I use the primary partition (C)
for the OS, drivers and programs, and the other partitions (D,E,F) for all work
and data (NEVER saving to "MyDocuments" or "Desktop"). The hard drives are much
In the (very likely) case my OS eventually crashes, I can reinstall or upgrade
without touching the other partitions so there is no loss of data.
This has worked for me for a very long time now, so I generally recommend this
approach. I has certain other advantages, like "defragmentation" is usually a
quick process as you usually only have to run it on the system drive. If I run
partition it installs programs to.
The reason I have 4 partitions is... well, the original idea was one for OS, one
for games, one for sound editing, one for 3D work, everybody has their own
preference.
USB drives are very handy when moving data from one location to another, I just
to update them though...
relatively cheap and making backups is fast and easy... good for lazy and
unorganized people like me.
Hildur
Date: 1 Sep 2008 08:41:32
Message: <48bbe2fc$1@news.povray.org>
I do this.
I mean, *now* I have multiple seperate physical HDs so it's kind of
unavoidable having seperate logical volumes. But I did it back when I
only had one drive too. Makes reinstalling the OS that much easier
without losing work. (If anything on my PC could be considered "work".)
I also have a big folder containing the installers for every program
I've ever downloaded, so I can reinstall them all quickly without having
to redownload them. (OTOH, I typically end up downloading a newer
version anyway, so I'm not sure who I'm kidding...)
http://blog.orphi.me.uk/
Date: 1 Sep 2008 09:00:00
Message: <web.48bbe68cd89d321b80197cfe0@news.povray.org>
-Ditto-
Date: 1 Sep 2008 09:22:03
Message: <48bbec7b@news.povray.org>
> -Ditto-
I gave up doing that a few years ago.  Nowadays I don't install anything
after the OS until I need it, then I download the latest version and
install.  Usually faster than searching through CDs anyway ;-)
Date: 1 Sep 2008 09:32:30
Message: <48bbeeee@news.povray.org>
>> -Ditto-
No no, I keep the installers *on my HD*. ;-) It would take far too many
CDs... (Do you know how big 3Dmark is?? How about WinXP SP3?)
Date: 1 Sep 2008 09:48:51
Message: <48bbf2c3$1@news.povray.org>
Oh ok, my hard drive wasn't big enough before to do that ;-)  I download too
much junk, install it, use it a bit then uninstall it...  But yeh, I have
loads of CDs and DVDs full of old versions of certain programs that I
probably should get around to throwing away some day.
Date: 1 Sep 2008 10:48:35
Message: <48bc00c3$1@news.povray.org>
Darren New wrote:
> I didn't want to be definite.
Me neither ;).
> I *have* seen hard drives designed to
> replace memory sticks in high-end cameras.  (Compact Flash-shaped hard
> drives, I think?)
Yep, they do exist. But then, it would be pretty hard to fit even 1,8"
hard disk to CF-slot - it's easy to have 3,5" HD mounted in little case
with the USB-interface.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 10:53:00
Message: <48bc01cc@news.povray.org>
No, it isn't. With RAID you can combine several HDs to one logical
volume, which even can hold if one of the disks break down.
Yep, that's true and very reasonable. You should also RAID the
work-partition and take scheduled backups ;).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 11:04:59
Message: <48bc049b@news.povray.org>
Or just mount the separate volume as a subdirectory of the system
volume. :-)
Note you can also make "my documents" and "desktop" (and a bunch of
other system-defined folders) point to anywhere you want, including
other drives.
