POV-Ray : Newsgroups : povray.off-topic : Strange GPU Server Time
5 Apr 2026 11:19:36 EDT (-0400)
  Strange GPU (Message 21 to 30 of 34)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Strange GPU
Date: 18 Aug 2008 15:53:12
Message: <48a9d328$1@news.povray.org>
Invisible wrote:
>> Try touching a VRAM chip (very briefly) while the game is running.
> Wouldn't simply having the case open radically alter the operating
> temperature of the components inside? ;-)
Also, I've read somewhere that that is a very bad thing to do. (Touch an
operating chip to check its temperature) it has something to do with
heat saturation at the point of contact and can cause a chip that was
operating within its parameters to actually overheat.
Of course, that's just hearsay...
Date: 18 Aug 2008 15:53:45
Message: <48a9d349@news.povray.org>
Invisible wrote:
> Ooo... Maybe I should use my IR thermometer? :-D
Now you're thinking :)
Date: 18 Aug 2008 16:58:23
Message: <48a9e26f@news.povray.org>
Chambers wrote:
> Very hot to touch, not so hot to run.  IIRC, most chips are fine up to
> 65-70C, and several can go higher w/o a problem.
My Pentium IV used to be at 72C constantly (full load; I never let a CPU
idle :P). According to specs, 75C is the limit.
Date: 19 Aug 2008 02:22:21
Message: <48aa669d$1@news.povray.org>
>> Compare it to your CPU temperature. I dunno about my GPU, but my CPU is
>> close to 55 just sitting idle.
Where is that temperature measured though?
Date: 19 Aug 2008 02:30:58
Message: <48aa68a2$1@news.povray.org>
I don't know. I assume it's an on-die heat sensor. AFAIK, most modern
CPUs have them, so that they can turn up the fan speed or go into lower
power states if the die temperature gets too high...
http://blog.orphi.me.uk/
Date: 23 Aug 2008 09:26:01
Message: <48b00fe9$1@news.povray.org>
>>> Apparently the nVidia control panel no longer tells you your GPU
>>> temperature; you have to download and install an additional tool.
>>> Anyway, having just stopped using the GPU, the temperature was
>> Try showing the temperature in parallel with running the GPU (eg 3D
>> game in a window), IIRC when I did those sorts of tests before, the
>> GPU temperature dropped rapidly very quickly (eg 10-15 degrees in just
>> a second after exiting a game).
OK, I was just playing TF2 and noticed a few stray polygons. (I.e., the
driver update hasn't fixed this.) When I quit the game, I opened up the
Next time I play TF2, I must remember to open the monitor *first*. ;-)
I wonder why it gets so much hotter running a real game (which is
optimised to run smoothly) than running a stress test (which is designed
to use up as much GPU resources as possible)...
Date: 25 Aug 2008 02:59:41
Message: <48b2585d$1@news.povray.org>
Can't you play TF2 in windowed mode?  Or download some game demo that can be
played in windowed mode.
I guess the stress test wasn't written very well, or without the knowledge
of your particular card.  Lots of things in the GPU can be the bottleneck, a
well-written stress test should work this out and adjust the test details so
that every part is almost at maximum throughput.  If it's not very well
written, then - for example - the vertex shader might be loaded at 100%
while the pixel shader and texture lookup units are sitting idle for 90% of
the time.
BTW what is the CPU load during the stress test and TF2?  Maybe that is
affecting the GPU temperatures?
Date: 25 Aug 2008 13:15:28
Message: <48b2e8b0@news.povray.org>
> can be played in windowed mode.
I guess I could - but it would be very hard to play it and enjoy it.
FWIW, last time I played, I did remember to start up the monitor. I've
Which sounds pretty damned hot to me, but hey...
>> designed to use up as much GPU resources as possible)...
> knowledge of your particular card.
Given that it's an nVidia GPU running a stress test written by nVidia,
you'd think so. ;-)
AMD Athlon64 X2 4200+ socket 939.
(When I built the system, everybody said that socket 939 was going to be
the future. Now it appears that actually it's AM2... oh well!)
Date: 25 Aug 2008 19:22:28
Message: <48b33eb4@news.povray.org>
That's the CPU model; and the load while playing the game? :)
Date: 26 Aug 2008 03:36:31
Message: <48b3b27f@news.povray.org>
I meant just so you could see the temperatures while playing.
