POV-Ray : Newsgroups : povray.off-topic : Very interesting... Server Time
16 May 2026 15:16:34 EDT (-0400)
  Very interesting... (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Very interesting...
Date: 31 Jul 2008 11:36:13
Message: <4891dbed$1@news.povray.org>
Invisible wrote:
> BTW, how come this never happens with, say, designing cars?
Actually, it does.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 31 Jul 2008 11:36:23
Message: <4891dbf7$1@news.povray.org>
triple_r wrote:
> Assuming you fit into the professional programmer category, are you rewarded for
> producing fast, effective results that meet requirements, or for well-written
> code?
Both.
If I can produce fast results that aren't ugly, I do so. Otherwise,
generally speaking, I produce fast ugly rather than eventually clean.
But that's because I work for start-up companies that are much more
interested in getting customers so they can get money instead of large
established companies that can afford to take more time.
Were I working for Amazon, for example, I'd expect I'd write prettier
code. When I'm coding for myself, I write prettier code. When I'm coding
example code, I write prettier code.
The two problems are these:
(1) You don't always know it's ugly when you write it. You may not
realize this bit you're creating here and passing to there is going to
wind up being needed all over the place, so you don't at first make a
specialized data structure for it. Or you may have the same code in
three or four places before you realize it really should be a library
function. In other words, in exploring the requirements and implementing
them, you learn what parts can be made more meta and hence less ugly. Of
course, if the requirements are poor, this happens way more often. This
includes if the program is evolving quickly, such as is common in startups.
(2) Ugliness depends on both program size and complexity and the number
of people working on the code. If I have a 20-line program to read a CSV
file, extract three of the columns, and output the SQL required to
populate the database table it represents, trying to use metaprogramming
to select those three columns instead of just having three identical
lines cut-and-pasted with the column name changed is probably more more
ugly. If I'm the only person working on the code and I'm smart, there
can be a whole boatload of ugly in there that doesn't interfere with me
improving it because I can remember it all.
> Not that they're mutually exclusive, but this ugly code has to come from
> somewhere, and I can't imagine you're told to fix every mess you come across.  I
> can see pressure from above promoting very poor practices that produce short
> term gains and long term losses.
Indeed. Generally, I wind up fixing ugly when it gets to be more effort
to work around the ugly than it does to fix the ugly. I had one
situation (long, long ago) where the report generation code was so ugly
I told the boss it would take 2 weeks to rewrite it as a data-driven
routine and three to move the last column to be the first column.
Sometimes you fix ugly incrementally. The third or fourth time you
copy-paste a few lines of code, you figure out if it makes sense to turn
it into a subroutine somewhere. When you have the same routine in
several programs, you move it from the program-specific library to the
general library. Etc.
Of course, the best way is to never write the ugly code in the first
place. With enough experience and je ne sais quoi, you eventually learn
where the ugly is going to creep in if you don't do it right here. You
learn that you should (for example) always take the time to create a
business-object layer[1] and to always use templates[2] for output.
Other ugliness is harder to catch.
[1] Business-object layer: a layer of code between the raw database rows
and the application that implements an OO-like layer that talks database
on the bottom end and application-logic on the top end. Not to be
confused with DAO or "active records". For example, a set of routines to
access "the product catalog", even if that's stored in multiple tables
and has different properties for different objects in the catalog.
[2] Never let the UI people edit your code. Even if it's PHP.
Date: 31 Jul 2008 11:46:40
Message: <4891de60@news.povray.org>
Hell yeah. Usually I write a program, eventually get it to almost-work,
and then realise that the way I structured it was totally stupid and
there's actually a far better way to do the job. Delete, start again.
Depending on program complexity, it can take a few iterations to get
this right.
It seems to be that, regardless of which programming language you use,
figuring out the best way to divide the problem into abstractions is
absolutely *critical* to writing clean, efficient, maintainable code.
And it's often not very obvious which way *is* the best until you try to
actually "do it".
I have no experience of working with other programmers. The only group
programming project I've ever been involved with was at uni - and I was
the only person in the group who knew how to program.
Program complexity I can agree with... ;-)
This seems like it's only common sense.
http://blog.orphi.me.uk/
Date: 31 Jul 2008 11:53:08
Message: <4891dfe4$1@news.povray.org>
Of course it does.
http://www.ausbcomp.com/~bbott/cars/carhist.htm
At this point, automobile design is more akin to moving from Word 2003
to Word 2007.
Plus, I guess you never really worked on any of the older cars from the
60's and 70's? Vacuum hoses to twist the distributor cap around to
change the spark plug timing based on how hard you pressed the pedal?
I also expect there's a whole lot more ugly inside the design of the car
than you see from outside. "Gee, I guess we'll have to multiplex the
signals for the electric windows with the signals for the 'door open'
warning light on the dash, since if we run *two* wires through the joint
between door and body, the door won't close easily."
In any case, software is far, far more complex than anything mechanical.
That's why when things get really complicated, you start adding
computers to the cars.
Date: 31 Jul 2008 12:12:41
Message: <4891e479$1@news.povray.org>
> this right.
Exactly. I think I did this about 5 times with LOME before I settled on
how to implement that. (Including trying it in 3 different languages
before I realized one with OO and some sort of automated memory
management would be best.)
> actually "do it".
Yep. That's where the experience comes in. And the natural ability to
recognise the abstractions in things.
>> effort to work around the ugly than it does to fix the ugly.
You would be surprised. I've had people do things like pass the number
of columns wide that the printer report should be in index zero of a
floating point array indexed by customer age, just so they wouldn't have
to spend 20 minutes to recompile other parts of the program when they
changed what variables are shared between programs.
Date: 31 Jul 2008 16:25:37
Message: <48921fc1$1@news.povray.org>
>> to actually "do it".
Experience.
It's like Chess or Go - the rules is simple, but the tactics and
strategy to play well come only with practice and experience.
GAAAAAH! >_< IT BURNS! IT BURNS ME!! MAKE IT STOP!!!! GAH, I WANT TO
CLAW OUT MY OWN EYEBALLS!!1!!eleven
Date: 31 Jul 2008 16:37:57
Message: <489222a5$1@news.povray.org>
The stupid is leaping up off the page and burrowing into my brain!</Dilbert>
Date: 31 Jul 2008 18:30:00
Message: <web.48923c602b2c0b34ef2b9ba40@news.povray.org>
Sounds familiar.  The job came down to a lot of signal processing, and I had a
coworker who needed to improve his programming ability, so he decided to write
a Sudoku solver on his own time.  Of course you need to keep track of which
numbers are possible, so in each square for 1-9 a '1' represented a possible
number while a '0' mean that possibility was ruled out.  Why not?  Makes sense.
 But we need to store that data, so lets have '1' correspond to a 1, '10'
correspond to a 2, '100' to 3, and so on up to 10^8.  Just add 'em up.  (so
1100 == 3 and 4 possible.)  Oh, and let's just store that as a real number
since we'll be doing all those log10's anyway.  I was unable to convince him
otherwise, which probably reflects more badly upon me than him, but at least no
one else ever had to see it, and at least I think he used double precision...
 - Ricky
Date: 8 Aug 2008 19:48:08
Message: <489cdb38$1@news.povray.org>
Wait... are you saying that he implemented a bitmap, but in decimal, and
stored it as a float?
Gah!!!
...Chambers
Date: 8 Aug 2008 22:05:00
Message: <web.489cfa412b2c0b34ef2b9ba40@news.povray.org>
> Gah!!!
On reading that back, it really wasn't as clear as it was in my head--I should
work on that--but you got it!  Gah is right.  1100 (base 2) => 1100 (base 10)
=> 1100.0.  To get the information back out, you just do a log10, subtract the
largest power of ten, and repeat until you have all the information!  Not to
say I haven't done some dumb things in my day, but *that*...
 - Ricky
