POV-Ray : Newsgroups : povray.off-topic : Aren't complexity classes fun? Server Time
16 May 2026 15:16:48 EDT (-0400)
  Aren't complexity classes fun? (Message 11 to 20 of 20)
Subject: Re: Aren't complexity classes fun?
Date: 31 Jul 2008 07:43:13
Message: <4891a551$1@news.povray.org>
Gail Shaw wrote:
> Sorry, that cam out a little snarkier than I intended.
> Taking SQL Server as an example (so I can give specific numbers), if an
> index does not contain all the columns required, the break point for use the
> index or scan the table is around 1% of the table. If the index does contain
> all the columns, then the index will be used whether 1 row is required or
> the entire table.
> It's not hard to demonstrate.
Ah, right.
I was thinking of something like "you have a bunch of invoices, indexed
by invoice number. You want to do something to all the invoices who's
numbers are less than 999,999,999". In which case, after you've found
the index nodes that tell you where those table rows are, you still need
to seek to them and load them. If you're processing a high enough
percentage of the rows in the table, just sequentially scanning the
table is going to wind up faster because sequential I/O is faster, and
reading only the table rather than table + index is less data to
transfer too.
I hadn't considered the possibility of the entire table data being in
the index itself. That would move the tipping point somewhat...
http://blog.orphi.me.uk/
Date: 31 Jul 2008 07:50:39
Message: <4891a70f@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4891a551$1@news.povray.org...
Not the entire table, just the columns required by the query in question.
Say the index table has 15 columns and the query that is looking for all
invoice numbers <  999,999,999 needs to return the date, the address and the
customer name, then an index on InvoiceNumber, Date, Address, CustName is
called a covering index, as it covers this particular query.
If an index is not covering, then, as I mentioned before, the tipping point
isn't most of the table (at least for SQL Server), it's somewhere around 1%
Date: 31 Jul 2008 08:14:28
Message: <4891aca4@news.povray.org>
Right, that's the other point I overlooked - you might not actually want
every single column in the table for a given query.
So, now that we've got all that out of the way, I'm sure you'll agree
with me that there are times when you do *not* want to use an index,
even if there is one. ;-)
Date: 31 Jul 2008 08:33:06
Message: <4891b102@news.povray.org>
news:4891aca4@news.povray.org...
<g> No.
Dunno about Oracle, but in SQL Server it's possible (and recommended) to
make the table into an index that contains, at the leaf levels, all of the
data in the table. It's called the clustered index.
I will agree that there are times when you want to scan an index, rather
than doing a seek on it.
Date: 31 Jul 2008 08:33:46
Message: <4891b12a$1@news.povray.org>
> <g> No.
Oracle provides an "index-organised table" which sounds like it's
similar. I don't know about "recommended" though - it seems to be more
for special situations.
I still think if you have a huge table with an index in just one field,
full-scanning the table would be faster than an index scan if you're
processing a very large percentage of the table's rows. But apparently
that's just me. :-}
BTW, what does "<g>" mean? I always thought it was short for "Gail" or
something, but that doesn't make much sense...
Date: 31 Jul 2008 08:40:54
Message: <4891b2d6@news.povray.org>
news:4891b12a$1@news.povray.org...
> that's just me. :-}
Ah, but read again. The clustered inde (or index-organised table) is an
index that has ALL of the data at the leaf level of the index. In essence,
it is the table.
So, if the index is the table, and you scan all the leaf pages of the index
Short hand for <grin>
Date: 31 Jul 2008 11:13:02
Message: <4891d67e$1@news.povray.org>
That's funky. Every time I ask an expert what a "clustered index" is, I
get a different definition. And I don't think they're compatible but
differing descriptions of the same concept.
I'd been told a clustered index is one in which the rows in the table
date are in physically the same order as the rows in the index. And that
that's why you can only have one clustered index for a table.
Date: 31 Jul 2008 11:26:26
Message: <4891d9a2@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4891d67e$1@news.povray.org...
Mostly correct.
The clustered index is the table. The leaf levels of the cluster are the
actual data pages and they are stored physically in the order of the
clustering key. The index's b-tree is built above those pages.
A scan of the clustered index is a scan of the data pages of the table.
With a clustered index, the clustering key is the row's 'address' and is
used in all other indexes to indicate the row's location if a lookup is
necessary (to retrieve additional columns)
There's a fairly decent diagram here - :
http://msdn.microsoft.com/en-us/library/ms177443.aspx
Does thet help at all, or have I just muddied the water more?
Bear in mind, I'm talking specifically for MS SQL Server. If other database
products have something with the same name, the physical implementation may
be different
Date: 31 Jul 2008 12:08:05
Message: <4891e365$1@news.povray.org>
> clustering key.
Oh, OK. I guess that makes sense, once I realize that there *is* no
"table data" outside the index.
That's a fairly good picture of a B-tree. :-)
It helps. I guess I just wasn't thinking it through. Thanks for
clarifying that.
Date: 31 Jul 2008 12:16:32
Message: <4891e560@news.povray.org>
news:4891e365$1@news.povray.org...
Yup. Look at that and the one for the nonclustered indexes (link's at the
bottom of the page) and compare what's at the leaf level
> clarifying that.
Pleasure. There are a lot  of full time SQL Server people who have little to
no clue what a clustered index is.
