POV-Ray : Newsgroups : povray.off-topic : Back to the future Server Time
17 May 2026 00:17:21 EDT (-0400)
  Back to the future (Message 71 to 80 of 234)
Subject: Re: Back to the future [100K]
Date: 23 Jul 2008 14:18:09
Message: <488775e1@news.povray.org>
>> Well CDs use the obscure rate of 44.1 kHz. Not 44 kHz, but 44.1 kHz.
>> Apparently this is due to some historical reasoning that I forget now.
> http://en.wikipedia.org/wiki/Red_Book_(audio_CD_standard)#Technical_details
> http://en.wikipedia.org/wiki/PCM_adaptor#How_a_PCM_adaptor_works
...so it's derived from old PAL video timings? :-D
(Kinda like the way many old 8-bit home computers have different CPU
speed depending on whether it's PAL or NTSC...)
http://blog.orphi.me.uk/
Date: 23 Jul 2008 14:46:22
Message: <48877CBA.3040500@hotmail.com>
On 23-Jul-08 10:02, Invisible wrote:
> andrel wrote:
>> The Amiga was the de facto standard for television quality
>> broadcasting, as many have also mentioned.
> Really? De facto? I mean, I know it was used by a few people, but I
> didn't think it had reached the level of "standard". (But obviously, I
> don't work in TV.)
At that time no other machine came close to broadcast quality nor was
there hardware genlock support on another machine (at least for an
affordable prize), so anybody who did anything with TV used one. Just as
the Mac was the standard for DTP and (I think) the Atari for MIDI.
Date: 23 Jul 2008 15:05:35
Message: <488780fe@news.povray.org>
  Not CPU speed, screen refresh rate.
  The screen refresh rate in PAL areas is 50 FPS because the frequency
of the alternate current from the wall socket is 50 Hz. In NTSC areas
the frequency is 60 Hz, and thus the screen refresh rate is 60 FPS.
Date: 23 Jul 2008 15:26:26
Message: <488785e2$1@news.povray.org>
>> don't work in TV.)
Heh. Well OK. Personally my Amiga was my introduction to MIDI. ;-)
As an aside: It's amazing how music suddenly sounds "professional" when
played using a sequencer, so that by definition it has perfect timing.
Date: 23 Jul 2008 15:28:46
Message: <4887866e$1@news.povray.org>
http://en.wikipedia.org/wiki/C64
"CPU: MOS Technology 6510 @ 1.02 MHz (NTSC) / 0.985 MHz (PAL)"
I'm guessing the variance is due to the need of the video subsystem to
access the framebuffer at a specific rate, hence the RAM data bus needs
to be an integral multiple of the scanrate or something...
Subject: Re: More futures
Date: 23 Jul 2008 15:38:14
Message: <488788a6$1@news.povray.org>
Orchid XP v8 wrote:
> And then there was AMOS (AMiga OS). I forget how many different editions
> were produced - AMOS, Easy AMOS, AMOS Professional, etc. In spite of the
> name, it wasn't actually an OS at all. It was a a programming language.
> When you buy AMOS Professional, what you get is
> - An interpretter for the AMOS language.
> - An extensive IDE.
> - A set of multimedia tools inclusing almost everything but the kitchen
> sink, *all* written in AMOS itself.
> - No less than *seven disks* stacked full of multimedia files and demo
> programs.
> Technically, AMOS is just another dialect of BASIC. It doesn't have line
> numbers, does have GOTO and GOSUB, and has procedures and functions,
> uses "$" and "#" to distinguish variable datatypes, and IIRC has local
> variables if you want them. The core language is no more powerful than
> that.
> However, it has VERY strong multimedia capabilities. If you imagine the
> most feature-encrusted lump of software possible, AMOS was like that,
> but with bells on.
...so basically, AMOS was a programming language that utterly *sucked*,
together with an absolutely kick-arse set of multimedia tools and with
killer easy of use. Kind of like VB I guess...
At the time, BASIC was the most powerful programming language I knew.
And boy did I love AMOS! Never got a huge amount *done* with it, but I
spent countless hours tinkering. Looking back on it, it truly was the
most feature-encrusted lump of lead imaginable! Occasionally it would
even malfunction slightly - nearly unheard of for commercial software.
(In fairness, it worked better once I got a harddrive.)
I do still sometimes miss the flexibility of just being able to say
"PLOT 7, 3, 11" and write a pixel to the screen. It's *way* more
complicated than that these days. Kinda puts you off writing anything
graphical...
Date: 23 Jul 2008 16:00:19
Message: <48878E0E.4040200@hotmail.com>
>>> I don't work in TV.)
>> as the Mac was the standard for DTP and (I think) the Atari for MIDI.
Yes, but you are not a professional musician.
See, that's what I mean, professionals never use perfect timing. ;)
Date: 23 Jul 2008 20:50:08
Message: <4887d1bf@news.povray.org>
Phil Cook wrote:
> And lo on Wed, 23 Jul 2008 08:50:07 +0100, scott <sco### [at] scottcom> did
> spake, saying:
>>> The real point is more that on a PC, just switching from one window to
>>> another always seemed to take forever, whereas on an Amiga it was
>>> instantaneous unless the machine was under heavy load.
>> Yeh, I remember my friend had a 33 MHz PC, and just closing a window it
>> took several seconds for his desktop wallpaper to repaint itself, slowly
>> scanning down the screen line-by-line.
> Another obvious case of False Memory Syndrome.
I definitely remember Windows 98 slowly redrawing the desktop as if it was
raytracing the damned wallpaper, while the hard disk made horrible
insane-seeking noises.
But I'm sure that was due to using more RAM than I should on a low-on-RAM
machine.
Date: 23 Jul 2008 22:59:14
Message: <4887f002$1@news.povray.org>
>> The Amiga was the de facto standard for television quality broadcasting,
> Really? De facto? I mean, I know it was used by a few people, but I didn't
> think it had reached the level of "standard". (But obviously, I don't work
> in TV.)
http://en.wikipedia.org/wiki/Video_Toaster
Subject: Re: Back to the future [~200KBbu]
Date: 23 Jul 2008 23:27:42
Message: <4887f6ae$1@news.povray.org>
Orchid XP v8 wrote:
> Sabrina Kilian wrote:
>> In effect, the computer doesn't boost the blue channel, it uses a
>> damned "nonlinear colourspace transformations".
> My point is still that you can't reover what isn't there any more.
Right, but the information is still there, and so it is recoverable.
