POV-Ray : Newsgroups : povray.off-topic : Back to the future Server Time
17 May 2026 20:44:18 EDT (-0400)
  Back to the future (Message 45 to 54 of 234)
Subject: Re: Back to the future
Date: 22 Jul 2008 21:44:55
Message: <48868d17@news.povray.org>
Orchid XP v8 wrote:
> Of course, using a point-and-click interface, it's not possible to do
> POV-Ray style tricks like positioning a sphere exactly at the end of a
> cylinder... the CLI has plus points! ;-)
Of course that's possible with a point-and-click interface. I never used any
remotely-decent modeller, but I'm sure Google SketchUp lets you do that.
(in my opinion, the CLI *still* has plus points; but you're wrong about that
specific feature)
Date: 22 Jul 2008 22:21:00
Message: <4886958c$1@news.povray.org>
Mike Raiford wrote:
> Invisible wrote:
>> With enough preprocessing, an AGA Amiga can basically display 24-bit
>> graphics. It just has to be encoded cleaverly. Recall that at this
>> point in history, PCs were still lumbering around with EGA or maybe,
>> if you're lucky, VGA. Ooo, 16 colours. Wow. :-P
> What? Back in 1990 I had a PC with a VGA and it could display 256 (out
> of 262,144) colors at 320x200. It was a Paradise card, so it could
> actually do 256 at 640x480, 16 at 800x600. Of course, sound was
It was only 91 or 92 and I had some card with an Oak chip that could do
24bit SVGA up to 1024x768.  It didn't actually have enough memory for
that, so you *had* to go with a lower bit depth at that resolution, but
still :)
And it had all those fancy bit-blitting modes, as well.  I read through
the specs once, and was astounded at all the things they thought to add in.
Of course, my Sound Blaster was the one that had two OPL chips for
better synthesis.
And my CPU was a measly little 486sx... When I finally upgraded to an
FPU, I was astounded to see POV-Ray trace the RSOCP with double digit PPS :)
Anyway, I think the only real problem with performance in PCs is the
non-standardization.  Every Amiga XXX had the exact same performance
characteristics.  Every PC was different, and had different bottlenecks.
  As a result, some programs would run well on one PC and not another,
and other programs would be the exact opposite.  Just like today ;)
...Chambers
Subject: Re: Back to the future [100K]
Date: 23 Jul 2008 03:17:22
Message: <4886db02$1@news.povray.org>
> Well... it looks fine to me, that's all I'm saying. ;-)
But "fine" is nowhere near what you see in real life.  While there is still
an obvious gap between real life and what you can reproduce, there will no
doubt be improvements in the future.
> OK, well that's pretty weird. I wonder why they suddenly changed it to 48
> kHz then...?
Well don't forget, that there was nothing widespread before DVD that
recorded films in a digital format.  For some reason 48 kHz was pretty
standard in the music recording industry, even after CD came along with it's
lower sampler rate.  I guess in the film industry they stuck with 48 kHz (as
films were obviously never put onto CDs), but then when DVD came along it
made sense to have a 48 kHz soundtrack if everything was recorded at 48 kHz
anyway.
Date: 23 Jul 2008 03:22:29
Message: <4886dc35@news.povray.org>
> cylinder...
Of course it is.  You can even tell it that the sphere is referenced to that
point on the cylinder, and to make the radii equal.  So when you change the
cylinder length or radius, the sphere changes position and radius to match.
You've never really used a modeller have you?
Subject: Re: More futures
Date: 23 Jul 2008 03:26:15
Message: <4886dd17$1@news.povray.org>
> For comparison, the excellent Flashback got 97%.
Oh I loved flashback, I think it was one of the first games that I actually
spent a long continuous amount of time playing until I finished it.  But I
got stuck right at the end (I think I said that before in here and someone
told me what I missed).
Date: 23 Jul 2008 03:50:08
Message: <4886e2b0$1@news.povray.org>
> The real point is more that on a PC, just switching from one window to
> another always seemed to take forever, whereas on an Amiga it was
> instantaneous unless the machine was under heavy load.
Yeh, I remember my friend had a 33 MHz PC, and just closing a window it took
several seconds for his desktop wallpaper to repaint itself, slowly scanning
down the screen line-by-line.  I think the difference was, that Windows was
always designed to use the hard disc as additional RAM, whereas the Acorn
was specifically designed not to do this.  Of course it meant you sometimes
had to quit applications if you ran out of RAM, but it also meant that you
never got slowed down by the OS thrashing the hard disc.  In fact, if you
didn't want anything extra loaded at startup, the hard disc wouldn't be
accessed at all.
They also ported some really cool vector art package that was originally
written for the Acorn (I think it was called Artworks on the Acorn and Xara
on the PC).  At some computer show I went to they had both packages running
on a latest Acorn and PC at the time, and of course the Acorn was something
like 8x faster at drawing complex shapes with lots of graduated fills and
transparency.  It had fininshed drawing the entire picture, while the PC was
still drawing the background fills.
Date: 23 Jul 2008 04:02:44
Message: <4886e5a4$1@news.povray.org>
andrel wrote:
> The Amiga was the de facto standard for television quality broadcasting,
> as many have also mentioned.
Really? De facto? I mean, I know it was used by a few people, but I
didn't think it had reached the level of "standard". (But obviously, I
don't work in TV.)
http://blog.orphi.me.uk/
Date: 23 Jul 2008 04:06:56
Message: <4886e6a0$1@news.povray.org>
Chambers wrote:
> Every Amiga XXX had the exact same performance characteristics.
In a way, this ended up being the Amiga's doom; as soon as you modify an
Amiga in any way, lots of software breaks (most especially games). Don't
get me wrong, the software that follows the rules works just fine - but
why ask the OS to do something when you already "know" what the hardware is?
Date: 23 Jul 2008 04:08:45
Message: <4886e70d$1@news.povray.org>
>> 48 kHz then...?
> it's lower sampler rate.  I guess in the film industry they stuck with
> 48 kHz (as films were obviously never put onto CDs), but then when DVD
> came along it made sense to have a 48 kHz soundtrack if everything was
> recorded at 48 kHz anyway.
Well CDs use the obscure rate of 44.1 kHz. Not 44 kHz, but 44.1 kHz.
Apparently this is due to some historical reasoning that I forget now. I
guess DVD uses 48 kHz for a similar reason...
Date: 23 Jul 2008 04:12:17
Message: <4886e7e1$1@news.povray.org>
Nicolas Alvarez wrote:
> I can see banding in grayscale POV-Ray renders. I checked with an image
> editor and there is no color level skipped. So I see the difference between
> rgb(42,42,42) and rgb(43,43,43).
Hooookay then... Apparently I'm blind. :-P
(Now my laptop? That only has 12-bit display with hardware dithering. Do
you have ANY IDEA how ANNOYING that is??)
