POV-Ray : Newsgroups : povray.off-topic : GPU rendering Server Time
16 May 2026 13:53:03 EDT (-0400)
  GPU rendering (Message 1 to 10 of 34)
Subject: GPU rendering
Date: 17 Jul 2008 14:11:00
Message: <487f8b34@news.povray.org>
OK, so for anybody who knows about such things... Would it be feasible
to render an Iterated Function System image using a GPU? And would it be
any faster than using the CPU?
http://blog.orphi.me.uk/
Subject: Re: GPU rendering
Date: 17 Jul 2008 15:09:26
Message: <487f98e5@news.povray.org>
  From the little I know, Pixel Shader Model 3 supports branching and
looping, so I assume it might be possible to create a pixel shader which
colors pixels according to an iterated function system.
  However, if I'm not completely mistaken, pixel shaders are calculated
on a specific pixel and cannot re-use previous calculations from other
pixels which have been calculated with a pixel shader (because else it
would make parallelizing pixel shaders extremely difficult, if not
impossible). Thus you are limited to making a pixel shader routine
which is calculated on a per-pixel basis, without input from other
pixels.
  I assume that this means that you cannot create a pixel shader which
jumps around the screen and draws pixels here and there, as most IFS
fractals do. You are limited to calculate on single pixels, like for
example how the basic Mandelbrot set is calculated.
  Assuming it is indeed possible to implement some IFS fractals with
pixel shaders, then it may indeed be much faster than with the CPU.
That's because modern display cards can run a fair amount of shaders
in parallel.
Date: 17 Jul 2008 16:26:03
Message: <487faadb$1@news.povray.org>
> pixels.
That seems like a reasonable assessment to me.
I wonder if you could attempt this using the Copy Game rather than the
Chaos Game? That is, start with a white screen, apply each
transformation to it seperately, merge the frame buffers back together,
and then repeat. Do this enough times and the shape on the screen is
guaranteed to converge to the attractor of the system. If you implement
the "merging" state correctly, you can even get density information.
The fatal problem with this method is that it utterly fails if the
entire attractor does not fit on the screen. For attractors involving,
say, infinitely long lines, this method can never work properly.
Also, how about random number generation? Is this "easy" to do on a GPU?
Could you do something like rendering millions of tiny semi-transparent
polygons of roughly 1-pixel size?
Does a GPU provide any way to procedurally render texture bitmaps that
might allow a histogram to be built?
Asside from all that, presumably you'd have to go with some kind of
GPGPU solution such as CUDA. Again, I'm not sure how well the GPU memory
architecture is going to play with that; I haven't looked at the numbers.
> in parallel.
This was my feeling...
Date: 17 Jul 2008 16:43:23
Message: <487faeeb@news.povray.org>
  Even if pixel shaders didn't have some RNG available (I don't know if
they have), a simple linear congruential generator should be rather
trivial to implement.
  (OTOH that means that the LCG would have to store the seed somewhere
so that the next time the shader is called it can use it. Again, I don't
know if that's possible. There could well be parallelism problems with
that.)
  Why would you want to do that? There's no need. A pixel shader determines
the color of a screen pixel, so what else do you need? AFAIK, you don't even
need any polygons in order to fill the screen with the products of a pixel
shader (or you need at most one).
  (The idea of pixel shaders is that if they are attached to a polygon,
when that polygon is projected on screen, each of the pixels of this
projection is colored according to the shader. The shader has tons of
information available from that polygon and other data in order to
determine the color of the pixel.)
  If what you want to do is to fill the screen with data in progressive
steps, graphics cards support that. They have stencil buffers and other
similar techniques for additive drawing.
Date: 17 Jul 2008 21:34:07
Message: <487ff30f@news.povray.org>
As long as you can break down your function so that a single step is
performed on the entire screen at once, then you can.
Ie, you can do function f() on all pixels, store the output in a buffer,
and use that buffer as the input in the next step.
If you have to perform varying steps on individual pixels, you get
problems.  As in, if you go f() then g() then h() on one pixel, then
only g() and h() on its neighbor, then only f() and h() on a third, this
won't work.
The same instructions have to be run on the whole screen (well, the
whole polygon - for what you're asking about, I would just draw a quad
to the whole screen).
...Chambers
Date: 18 Jul 2008 01:55:09
Message: <4880303d$1@news.povray.org>
I haven't done any GPU programming myself, but from what I've gathered
from friends who have modern GPUs are essentially fully programmable
architectures these days, so you can use them to boost the speed of
computations which have seemingly little to do with actually displaying
things on the screen (for instance, I believe that folding@home can use
the GPU).
It probably depends on what graphics card you have as to weather or not
you can do this on it, but you might take a look at CUDA, a C compiler
revently released by nvidia that allows you to write things for the GPU:
http://www.nvidia.com/object/cuda_learn.html
You'll, of course, need to design your IFS algorithm so that it can be
run in a highly parallel manner, but unless I'm missing something that
should be pretty straightforward in this case (just run multiple
iterators simultaneously).  Of course, not having ever done this sort of
thing increases the chances that I'll have missed something :-)
Date: 18 Jul 2008 03:08:35
Message: <48804173$1@news.povray.org>
> OK, so for anybody who knows about such things... Would it be feasible to
> render an Iterated Function System image using a GPU? And would it be any
Yes, and yes it would be much faster.  Sometimes you need to think a bit
before implementing such a thing though...
I would run several points through the IFS in parallel.  Say, 2^16 points.
Create two 256x256 textures of floats, one to hold the X coordinates and one
to hold the Y coordinates of all your points.
Then write two pixel shaders, one to calculate the new X coordinate, and one
to create the new Y coordinate.
Then, for each pass, set the current X and Y textures and inputs, and render
to the newX texture.  Render again to the newY texture with the other pixel
shader.
Now, here comes the clever bit.  After you've generated the new XY textures,
you now run a *vertex* shader with 2^16 quads.  THe vertex shader looks up
the XY values from the texture for each quad and translates the quad to that
position.  You can then just use a fairly normal pixel shader to increment
the pixel value on the screen, or some off-screen texture.
It should run pretty fast, and don't forget you're doing 64k points in
parallel so it should outrun the CPU by a huge factor.
Date: 18 Jul 2008 03:25:56
Message: <48804584$1@news.povray.org>
Yeah, CUDA seems the obvious way to do this.
Unfortunately, only GeForce 8 and newer support this technology. I have
a GeForce 7900GT. :-(
(Also... I get the impression you need Vista for the GeForce 8 to work.)
There are 3 processes that need to happen.
1. A stream of coordinates needs to be generated.
2. A histogram of the coordinates needs to be constructed.
3. A non-linear mapping from histogram frequencies to colours is performed.
Step 2 looks to be the tricky one - but it shouldn't be *vastly*
difficult I think. The question is whether the histograms will fit into
the limited RAM on the card...
Date: 18 Jul 2008 03:28:41
Message: <48804629@news.povray.org>
This is the program. An IFS image is essentially a histogram plot. You
can't just compute each pixel's colour independently.
OOC, is it possible to use a GPU to copy and transform chunks of video
data? (E.g., rotate, scale, that kind of thing.)
Date: 18 Jul 2008 03:35:15
Message: <488047b3$1@news.povray.org>
> points. Create two 256x256 textures of floats, one to hold the X
> coordinates and one to hold the Y coordinates of all your points.
> one to create the new Y coordinate.
> render to the newX texture.  Render again to the newY texture with the
> other pixel shader.
> textures, you now run a *vertex* shader with 2^16 quads.  THe vertex
> shader looks up the XY values from the texture for each quad and
> translates the quad to that position.  You can then just use a fairly
> normal pixel shader to increment the pixel value on the screen, or some
> off-screen texture.
Uuhhh... any chance of some code? :-}
(Also... what's a vertex shader?)
Would it be possible to do all this using just, say, OpenGL? So far the
approaches I've considered would all require CUDA, which obviously works
*only* for certain GPUs.
