POV-Ray : Newsgroups : povray.off-topic : GPU rendering Server Time
5 Apr 2026 04:41:30 EDT (-0400)
  GPU rendering (Message 15 to 24 of 34)
Subject: Re: GPU rendering
Date: 18 Jul 2008 04:16:14
Message: <4880514e$1@news.povray.org>
>> OOC, is it possible to use a GPU to copy and transform chunks of video
>> data? (E.g., rotate, scale, that kind of thing.)
> Yes, you just draw a textured square wherever you want, using whatever
> you want as the texture (the result of a previous calculation?).
I was hoping you'd say something like that. :-)
Is it possible to take a chunk of the frame buffer and turn it into a
texture? Or would I have to render texture to texture and then make a
copy to the screen so I can see it?
> The only limitation is that you cannot render to a texture at the same
> time as using that texture as a source for drawing operations.
That won't be a problem.
http://blog.orphi.me.uk/
Date: 18 Jul 2008 04:19:40
Message: <4880521c@news.povray.org>
scott wrote:
>> Uuhhh... any chance of some code? :-}
> I don't have time to write anything working now, but I'm just having a
> look at something I have already that would be a good basis...  This is
> using DirectX 9 btw.
> Use CreateTexture() to create two new 256x256 textures with the format
> D3DFMT_R32F (that gives you a texture full of 32bit floats, as opposed
> to the more usual RGBA bytes).  Also create two temp textures.
> You can then lock the texture and write to it using CPU code, to set the
> initial values.
> I would create a big vertex buffer full of the 65k squares 1 unit big
> centered at the origin.  Also assign an x,y coordinate to each vertex of
> each square (this is so the vertex shader knows which square it is
> processing).
> Then, in the game loop, use the Direct3D call SetRenderTarget() to set
> the first temp texture as the render target, and run your pixel shader
> that calculates the new x coordinate.  DO the same for y.  If you have
> DX10 then you can render to multiple render targets in one shot, so
> could be faster.
> Pixel shader code would look something like:
>  float currentX , currentY;
>  currentX = tex2D( xCoordTexture , ps_in.textureCoordinate );
>  currentY = tex2D( yCoordTexture , ps_in.textureCoordinate );
>  < calculate new X coord here >
>  return newX;
>> (Also... what's a vertex shader?)
> OK, so then the next bit, to actually draw all those points somewhere.
> The vertex shader is what "normally" converts your mesh from model space
> into screen space that is then used by the pixel shader to know where to
> draw each pixel.  Usually it just multiplies by a big matrix, but we can
> do whatever we want in it.
> I'm going to look up the X,Y coordinates from those textures, using the
> XY coordinates we set in the vertex buffer above, remember?
>  currentX = tex2D( xCoordTexture , vs_in.xCoordinate );
>  currentY = tex2D( yCoordTexture , vs_in.yCoordinate );
>  vs_out.Pos.x = vs_in.Pos.x + vs_in.x + currentX;
>  vs_out.Pos.y = vs_in.Pos.y + vs_in.y + currentX;
>  return vs_out;
> It returns each vertex of each square shifted to the position defined by
> the coordinates in the xy texture.
> The pixel shader used to draw those squares would then do something
> really simple, like just increment the colour at that coordinate by 1.
> Or if you want to get really clever you could make the square a bit
> bigger (so it covers say 9 pixels) and do some antialiasing by hand in
> the pixel shader.
>> Would it be possible to do all this using just, say, OpenGL?
> Yes.  But I don't know any of the syntax, sorry.
Ah, OK. Well I have a Haskell binding to OpenGL, but not for DirectX.
So the exact function calls you're talking about won't help me, but it
gives me some idea what I'm trying to do...
Date: 18 Jul 2008 04:24:33
Message: <48805341$1@news.povray.org>
> texture?
You can, but it's a bit long-winded and slow.
> Or would I have to render texture to texture and then make a copy to the
Yes, that's what is normally done.  Also gives you the advantage that you
can do funky things with the pixel shader you use to write the texture to
the screen, like using colour look up tables, motion blur, bloom, edge
detection, etc etc.
Date: 18 Jul 2008 04:25:38
Message: <48805382$1@news.povray.org>
I would try and find some very simple demos of pixel and vertex shaders
written in OpenGL first and get them working.  IIRC they are called
something else in OpenGL too, just to make matters more confusing.
Date: 18 Jul 2008 04:52:07
Message: <488059b7$1@news.povray.org>
OpenGL apparently calls a pixel shader a "fragment shader".
I found a small program that allows you to type in GLSL source code and
see it applied to a mesh object. Should help me get to know the
language, but won't help much with rendering a texture of floats. ;-)
The "other" fun thing is that shaders were introduced in OpenGL 2.0, for
which no language spec is available online. You have to buy the book for
that. But having a look at the Haskell OpenGL bindings, I think I see
how it's supposed to work...
Date: 18 Jul 2008 14:42:03
Message: <4880e3fb@news.povray.org>
Orchid XP v8 wrote:
> There are 3 processes that need to happen.
> 1. A stream of coordinates needs to be generated.
> 2. A histogram of the coordinates needs to be constructed.
> 3. A non-linear mapping from histogram frequencies to colours is performed.
> Step 2 looks to be the tricky one - but it shouldn't be *vastly*
> difficult I think. The question is whether the histograms will fit into
> the limited RAM on the card...
I'd think that memory wouldn't be a problem here, as 256MB is enough to
store a reasonably large histogram.
Date: 18 Jul 2008 16:09:39
Message: <4880f883$1@news.povray.org>
The *only* reason I increased the RAM in my system from 1 GB to 3 GB was
to handle rendering high resolution IFS images. ;-)
OTOH, I'm talking about resolutions high enough for Zazzle...
Date: 19 Jul 2008 19:58:52
Message: <48827fbc@news.povray.org>
That's not true, you can download the spec for both GL2 and the GLSL for
free (they're separate documents, though).
...Chambers
Date: 20 Jul 2008 17:26:05
Message: <4883ad6d@news.povray.org>
Orchid XP v8 wrote:
> (Also... I get the impression you need Vista for the GeForce 8 to work.)
I have a 8600 GT. Used to use it on Windows XP. Now running Linux.
(and many Compiz effects involving shaders, like transparency blur, indeed
get WAY more framerate than on my previous machine with a... GeForce 4?)
Date: 22 Jul 2008 14:15:41
Message: <488623cd$1@news.povray.org>
Oh, OK then.
