POV-Ray : Newsgroups : povray.off-topic : GPU rendering Server Time
12 May 2026 02:45:17 EDT (-0400)
  GPU rendering (Message 11 to 20 of 34)
Subject: Re: GPU rendering
Date: 18 Jul 2008 03:36:02
Message: <488047e2$1@news.povray.org>
Orchid XP v8 wrote:
> Yeah, CUDA seems the obvious way to do this.
> Unfortunately, only GeForce 8 and newer support this technology. I have
> a GeForce 7900GT. :-(
Also... I can't program in C to save my life. ESPECIALLY if it involves
floating point arithmetic...
http://blog.orphi.me.uk/
Date: 18 Jul 2008 03:55:56
Message: <48804c8c@news.povray.org>
Warp wrote:
> Orchid XP v8 <voi### [at] devnull> wrote:
>> Also, how about random number generation? Is this "easy" to do on a GPU?
>   Even if pixel shaders didn't have some RNG available (I don't know if
> they have), a simple linear congruential generator should be rather
> trivial to implement.
>   (OTOH that means that the LCG would have to store the seed somewhere
> so that the next time the shader is called it can use it. Again, I don't
> know if that's possible. There could well be parallelism problems with
> that.)
Yeah, that's going to be the fun part - getting each PRNG to produe a
different stream. Maybe it could be seeded from pixel coordinates or
something...
>> Could you do something like rendering millions of tiny semi-transparent
>> polygons of roughly 1-pixel size?
>   Why would you want to do that?
The idea being to scatter polygons around using a geometry shader,
rather than trying to implement the IFS as a pixel shader. I don't know
if it would work well though.
Date: 18 Jul 2008 04:01:00
Message: <48804dbc$1@news.povray.org>
> Uuhhh... any chance of some code? :-}
I don't have time to write anything working now, but I'm just having a look
at something I have already that would be a good basis...  This is using
DirectX 9 btw.
Use CreateTexture() to create two new 256x256 textures with the format
D3DFMT_R32F (that gives you a texture full of 32bit floats, as opposed to
the more usual RGBA bytes).  Also create two temp textures.
You can then lock the texture and write to it using CPU code, to set the
initial values.
I would create a big vertex buffer full of the 65k squares 1 unit big
centered at the origin.  Also assign an x,y coordinate to each vertex of
each square (this is so the vertex shader knows which square it is
processing).
Then, in the game loop, use the Direct3D call SetRenderTarget() to set the
first temp texture as the render target, and run your pixel shader that
calculates the new x coordinate.  DO the same for y.  If you have DX10 then
you can render to multiple render targets in one shot, so could be faster.
Pixel shader code would look something like:
  float currentX , currentY;
  currentX = tex2D( xCoordTexture , ps_in.textureCoordinate );
  currentY = tex2D( yCoordTexture , ps_in.textureCoordinate );
  < calculate new X coord here >
  return newX;
> (Also... what's a vertex shader?)
OK, so then the next bit, to actually draw all those points somewhere.  The
vertex shader is what "normally" converts your mesh from model space into
screen space that is then used by the pixel shader to know where to draw
each pixel.  Usually it just multiplies by a big matrix, but we can do
whatever we want in it.
I'm going to look up the X,Y coordinates from those textures, using the XY
coordinates we set in the vertex buffer above, remember?
  currentX = tex2D( xCoordTexture , vs_in.xCoordinate );
  currentY = tex2D( yCoordTexture , vs_in.yCoordinate );
  vs_out.Pos.x = vs_in.Pos.x + vs_in.x + currentX;
  vs_out.Pos.y = vs_in.Pos.y + vs_in.y + currentX;
  return vs_out;
It returns each vertex of each square shifted to the position defined by the
coordinates in the xy texture.
The pixel shader used to draw those squares would then do something really
simple, like just increment the colour at that coordinate by 1.  Or if you
want to get really clever you could make the square a bit bigger (so it
covers say 9 pixels) and do some antialiasing by hand in the pixel shader.
> Would it be possible to do all this using just, say, OpenGL?
Yes.  But I don't know any of the syntax, sorry.
Date: 18 Jul 2008 04:03:34
Message: <48804e56$1@news.povray.org>
> OOC, is it possible to use a GPU to copy and transform chunks of video
> data? (E.g., rotate, scale, that kind of thing.)
Yes, you just draw a textured square wherever you want, using whatever you
want as the texture (the result of a previous calculation?).
The only limitation is that you cannot render to a texture at the same time
as using that texture as a source for drawing operations.
Date: 18 Jul 2008 04:16:14
Message: <4880514e$1@news.povray.org>
> you want as the texture (the result of a previous calculation?).
I was hoping you'd say something like that. :-)
Is it possible to take a chunk of the frame buffer and turn it into a
texture? Or would I have to render texture to texture and then make a
copy to the screen so I can see it?
> time as using that texture as a source for drawing operations.
That won't be a problem.
Date: 18 Jul 2008 04:19:40
Message: <4880521c@news.povray.org>
> look at something I have already that would be a good basis...  This is
> using DirectX 9 btw.
> to the more usual RGBA bytes).  Also create two temp textures.
> initial values.
> processing).
> the first temp texture as the render target, and run your pixel shader
> that calculates the new x coordinate.  DO the same for y.  If you have
> DX10 then you can render to multiple render targets in one shot, so
> could be faster.
>  return newX;
> The vertex shader is what "normally" converts your mesh from model space
> into screen space that is then used by the pixel shader to know where to
> draw each pixel.  Usually it just multiplies by a big matrix, but we can
> do whatever we want in it.
> XY coordinates we set in the vertex buffer above, remember?
>  return vs_out;
> the coordinates in the xy texture.
> really simple, like just increment the colour at that coordinate by 1.
> Or if you want to get really clever you could make the square a bit
> bigger (so it covers say 9 pixels) and do some antialiasing by hand in
> the pixel shader.
Ah, OK. Well I have a Haskell binding to OpenGL, but not for DirectX.
So the exact function calls you're talking about won't help me, but it
gives me some idea what I'm trying to do...
Date: 18 Jul 2008 04:24:33
Message: <48805341$1@news.povray.org>
> texture?
You can, but it's a bit long-winded and slow.
> Or would I have to render texture to texture and then make a copy to the
Yes, that's what is normally done.  Also gives you the advantage that you
can do funky things with the pixel shader you use to write the texture to
the screen, like using colour look up tables, motion blur, bloom, edge
detection, etc etc.
Date: 18 Jul 2008 04:25:38
Message: <48805382$1@news.povray.org>
I would try and find some very simple demos of pixel and vertex shaders
written in OpenGL first and get them working.  IIRC they are called
something else in OpenGL too, just to make matters more confusing.
Date: 18 Jul 2008 04:52:07
Message: <488059b7$1@news.povray.org>
OpenGL apparently calls a pixel shader a "fragment shader".
I found a small program that allows you to type in GLSL source code and
see it applied to a mesh object. Should help me get to know the
language, but won't help much with rendering a texture of floats. ;-)
The "other" fun thing is that shaders were introduced in OpenGL 2.0, for
which no language spec is available online. You have to buy the book for
that. But having a look at the Haskell OpenGL bindings, I think I see
how it's supposed to work...
Date: 18 Jul 2008 14:42:03
Message: <4880e3fb@news.povray.org>
Orchid XP v8 wrote:
> There are 3 processes that need to happen.
> 1. A stream of coordinates needs to be generated.
> 2. A histogram of the coordinates needs to be constructed.
> 3. A non-linear mapping from histogram frequencies to colours is performed.
> Step 2 looks to be the tricky one - but it shouldn't be *vastly*
> difficult I think. The question is whether the histograms will fit into
> the limited RAM on the card...
I'd think that memory wouldn't be a problem here, as 256MB is enough to
store a reasonably large histogram.
