POV-Ray : Newsgroups : povray.off-topic : Need for speed Server Time
30 Jul 2026 04:36:08 EDT (-0400)
  Need for speed (Message 151 to 160 of 168)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Ah, history
Date: 18 Jul 2008 11:03:57
Message: <4880b0dd$1@news.povray.org>
>  Game engines implement an ample variety of techniques to reduce the
> amount
> of polygons sent to the graphics card.
True, but you very rarely need to keep a copy of the actual meshes used to
render.  Usually for the sort of algorithms you mean, you never go down to
the polygon level because it's just faster to let the GPU handle that.
You'll usually be working with bounding boxes of meshes, not the actual mesh
data.
And as for the textures, I don't think you need them at all in CPU RAM
during the game.
> The optimal situation is that only
> those polygons which are visible in the current frame are sent to the
> graphics card to be rendered.
Maybe that was optimal 15 years ago, but today the GPU is way faster than
the CPU at culling polygons.  Especially when you consider the overhead of
having to transfer all the mesh data per-frame to the GPU - that is slow and
nobody does it.  The optimal approach nowadays is to have as much mesh and
texture data loaded in the GPU as possible, and per-frame the CPU can just
tell the GPU which meshes to render, based on some algorithm.
>  Also in most modern games the scene to be rendered is seldom static,
> but changes all the time. For example dynamic shadows, at least if
> implemented using shadow volumes, require new shadow polygons to be
> created at each frame and sent to the graphics card.
No they don't, you can do it that way but it's slow.  You usually make a
simplified version of your mesh, replace each edge with a quad compressed
down to that edge and then load it to the GPU.  THen, per-frame, a vertex
shader running on the GPU decides if the edge is a silhouette edge, and
expands out the polygon as necessary in the direction away from the light.
Character animation and other dynamic effects (eg trees moving in the wind)
are usually done in the vertex shader too.
Date: 18 Jul 2008 12:00:00
Message: <4880be00@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:487f8231$1@news.povray.org...
> The Word MVP website has an entire *section* dedicated to this
> particular issue:
> http://word.mvps.org/FAQs/Numbering/WordsNumberingExplained.htm
Ok, so the numbering's strange. At leat it's understandable once the
explaination is given (like so many things).
I assume you foung that link a while back and didn't go searching for it
just for me.
Since you now understand why the lists sometimes go strange, you can explain
it to the users. You'll probably end up their hero for saving them so much
time in fixing the lists.
Date: 18 Jul 2008 12:10:13
Message: <4880c065@news.povray.org>
scott wrote:
> you, you *always* get that little icon that gives you the chance to
> "don't ever do what you just did again" or "ok undo what you just did,
> but do it again later if you want".  Very handy.
I like how this works in OpenOffice, where it pops up the little
lightbulb that says "Hey, I just changed stuff. If you want to learn how
to change it back, here's what the subject to search for in the help
file is..." ;-)
Not that it'll put it back, or let you turn it off right there, or
anything like that.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 18 Jul 2008 12:19:43
Message: <4880c29f@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4880c065@news.povray.org...
> anything like that.
That would be too easy and it would deprive you of an opportunity to see the
outstanding quality of the help file. </tongue in cheek>
Date: 18 Jul 2008 12:58:17
Message: <4880cba8@news.povray.org>
  Many games seem to disagree with you.
  For example HL2 and sequels actually drop meshes and use lower-resolution
meshes for scenery which can only be seen from far away, but if you go
to that scenery, it will load objects and higher-resolution versions of
other objects.
  For example in HL2:Lost Coast you can use objects to climb over barriers
which would normally stop you from getting back to previous parts of the
level. If you do that, those parts are very ascetic compared to what they
were previously (when you played through them normally).
  Other games, such as for example Oblivion, generate terrain details
dynamically based on distance: Closer terrain will be more detailed than
terrain farther away. Other games, such as Call of Juarez, also do this
(and this one does it even better than Oblivion), which allows huge visible
landscapes to be rendered.
  The amount of polygons to render matters even today. That's because
today polygons are much heavier to render compared to 15 years ago.
15 years ago you had bilinearly-filtered perspective-correct texture
mapping, light mapping, and little else. Today you have all kinds of
pixel shaders, bump mapping and whatnot.
  Also some polygons need to be rendered from farther to closer, most
prominently polygons with transparencies, or else the Z buffer won't
work properly. I don't know if any graphics card supports sorting of
polygons (especially since there's no generic algorithm for sorting
polygons, not even triangles, without polygon splitting).
Date: 19 Jul 2008 12:40:06
Message: <488218e6@news.povray.org>
Warp wrote:
<snip about graphics>
And that's not even the game, just the stuff needed to show it on screen!
SimCity 4 came out what, 7 years ago?  It's still one of the most CPU
demanding games I have (once you get a large city, that is :) ).
The Sims is also notoriously slow on high end computers.  When you get a
house with decent decorations, that game can slow to a crawl (of course,
we've got more than 8 GB of downloaded stuff for it).
The point is, there are *lots* of things you need CPU and RAM for other
than graphics.
...Chambers
Date: 20 Jul 2008 18:11:59
Message: <4883b82e@news.povray.org>
Orchid XP v8 wrote:
> I'm also 98% sure none
> of the Word power users know about styles.
<CoderForLife> 83% of all statistics are made up on-the-fly 76% of the time
<CoderForLife> 4 out of 5 dentists agree
<efc> Thats 62% bull($#@, CFL
Date: 20 Jul 2008 18:13:36
Message: <4883b890@news.povray.org>
scott wrote:
> Googling "VBA in Word" gives 5460000 results, seems like a lot of people
> have something to say about it.
Googling "Excel database" gives lots of results of people showing you how to
create excel databases too. Took me long to find the link I was looking
for: a blog post about "I can't believe people use excel as a database"
Date: 20 Jul 2008 18:17:43
Message: <4883b986@news.povray.org>
scott wrote:
> I think it says more about the mentality of the user if they don't seek to
> find more efficient ways to work.  Not just in using software, but in
> other things too.
People nowadays get used to things not working, and work around them.
My sister's computer has FlashBlock installed on Firefox. I once saw her
load a particularly flash-heavy website and very quickly move the mouse
around activating all of the different Flash components in the page. She
has probably done that a hundred times for that website already...
I expected she'd have complained to me about it before, and I'd have shown
her how to easily add a website to the whitelist.
Date: 20 Jul 2008 18:22:24
Message: <4883baa0@news.povray.org>
Orchid XP v8 wrote:
> From that point on, I wrote every single assignment in HTML instead.
I would always do it if I could choose.
To my mind, there is something fundamentally wrong with WYSIWYG editors.
Type "hello world". Make "hello" bold. If you put the cursor after the 'o'
in 'hello', and type a space and another word, will it be bold or not?
Type "hello world". Make "world" bold. Delete "world". Now nothing seems to
be bold, but if you type something else, will it be bold or not? Maybe
there is the equivalent of <b></b> leftover in the document.
In HTML, I always know if the cursor is before or after a tag :)
