POV-Ray : Newsgroups : povray.off-topic : Need for speed Server Time
10 Oct 2024 07:49:27 EDT (-0400)
  Need for speed (Message 1 to 10 of 168)
Subject: Need for speed
Date: 13 Jul 2008 04:52:13
Message: <4879c23d$1@news.povray.org>
Can somebody find out the typical MIPS and FLOPS for the following:
- Commodore 64 (6510 @ ~1 MHz)
- ZX Spectrum (Z80 @ 3.5 MHz)
- Pentium I @ 66 MHz
- Pentium II @ 233 MHz
- Pentium III @ 500 MHz
- Pentium IV @ 4.0 GHz
- Intel Core 2 Quad @ 3.0 GHz
Surprisingly, Google fails to yield any useful data. I can find out the
*clock speed*, FSB speed, cache size, and numerous other details of
these CPUs, plus various benchmark results, but not MIPS and FLOPS counts...
http://blog.orphi.me.uk/
Subject: Re: Need for speed
Date: 13 Jul 2008 05:22:04
Message: <4879C975.1040409@hotmail.com>
> counts...
Neither the 6510 nor the Z80 had a floating point processor. Floating
point was in software. FLOPS is not really defined because it depends on
what operation is performed.
Both had a variable instruction set that took a variable amount of
cycles to execute and therefor the number of instruction processed
depended on the program and especially on the addressing modes used. I'd
say that although the MIPS rate is not very well defined, on average it
may be in the order of 1/3rd of the clock speed for 65xx and 1/5th-1/4th
for Z80. Some info at:
http://e-tradition.net/bytes/6502/6502_instruction_set.html
http://wikiti.denglend.net/index.php?title=Z80_Instruction_Set
Date: 13 Jul 2008 05:33:13
Message: <4879cbd9$1@news.povray.org>
That's true. But assuming we want, say, a normal "double precision"
floating point number, how many clock cycles would you estimate it takes
to operation on? A dozen? A hundred?
I thought this was true for *all* processors?
(Of course, unlike modern processors, cache effects are not present.)
> for Z80.
Sounds roughly right. (For the 65xx anyway - I have a manual somewhere
that lists all the opcodes and addressing modes...)
So that gives us, very approximately,
- C64 = 1.0 MHz / 3 = 0.333 MIPS.
- ZX Spectrum = 3.5 MHz / 4 = 0.875 MIPS.
So each is giving us probably a few hundred thousand complete opcodes
executed every second.
Now, anybody have any clue "how big" the numbers are for less ancient CPUs?
Date: 13 Jul 2008 05:55:44
Message: <4879d11f@news.povray.org>
  A lot. I don't believe *any* existing program for those processors
does double precision floating point calculations.
  As he said, I don't think the term FLOPS even applies if floating point
calculations are done in software instead of in hardware.
  No. The idea with RISC processors is that each opcode has the same size
and takes exactly 1 clock cycle to execute. (Ok, granted, practical RISC
processors do have some opcodes which take more than 1 clock cycle to
execute because it would simply be a physical impossibility to perform
the operation in 1, but the vast majority are executed in 1.)
  For Intel processors it depends a lot on the executed program and the
processor. With the 486 you might get something close if you divide the
clockrate with 1.5 (or something like that). With the Pentium and newer
it becomes very complicated (because the newer Pentiums have whacky things
like parallel pipelines and out-of-order execution).
Date: 13 Jul 2008 06:04:36
Message: <4879D36C.4020304@hotmail.com>
My estimate would be that adding 2 floating points would be around 50
and multiplication more 100-150, but I could be an order of magnitude wrong.
not for RISC and only partial for state of the art processors.
>> although the MIPS rate is not very well defined, on average it may be
>> in the order of 1/3rd of the clock speed for 65xx and 1/5th-1/4th for
>> Z80.
please don't use 3 significant digits.
http://en.wikipedia.org/wiki/Million_instructions_per_second
Date: 13 Jul 2008 07:10:06
Message: <4879e28e$1@news.povray.org>
You're probably right about that. (Just moving 8 bytes around has to
take a minimum of 8 instructions, before you *do* anything to those
bytes.) Just wanted to make it a like-for-like comparison. ;-)
Floating-point operations per second. Does it matter *how* it does them?
Surely the important point is how many of 'em it can do.
Interesting. I was under the impression that processors such as the
Pentium can execute multiple instructions in parallel, and therefore
several instructions can reach the "completed" stage in a single given
clock cycle, but that each individual instruction still takes multiple
cycles from start to finish.
I'm only trying to figure out "how many zeros" are in the number, if you
see what I mean...
Is it 10 MIPS? 100? 1,000? 1,000,000??
Date: 13 Jul 2008 07:11:54
Message: <4879e2fa@news.povray.org>
>> takes to operation on? A dozen? A hundred?
> wrong.
Right. Suddenly integer-only algorithms seem like a Big Deal. ;-)
But my very next statement is
Ah. Now this looks like the kind of data I'm after...
Date: 13 Jul 2008 07:36:18
Message: <4879e8b1@news.povray.org>
  Actually the Z80 has 16-bit registers, 16-bit memory addressing and
a 16-bit ALU (don't believe wikipedia's lies about calling the Z80 an
"8-bit processor"). But anyways.
  I think it becomes a bit fuzzy if it's done in software, because then
it becomes a question of how optimized that software is. One software
might calculate floating point operations twice as fast as another because
of better optimizations, but that doesn't tell anything about the FLOPS
of the *processor architecture*. Calculating the theoretical and practical
maximum software FLOPS for a given non-FPU processor could be next to
impossible.
  When calculating MIPS it doesn't matter how many clock cycles it takes
for one opcode to be fetched and passed through the entire pipeline and
executed. What matters is the throughput. In other words, as the very
acronym says, how many instructions the processor can execute per second
(not how long it takes for one single instruction to be completely processed).
  The throughput of most RISC processors is, at least theoretically, 1 clock
cycle per instruction (except for the few instructions which require more).
> see what I mean...
  The wikipedia article about the subject has some numbers.
Date: 13 Jul 2008 07:43:36
Message: <4879EAA1.7090008@hotmail.com>
8 cycles to read, 8 to write and some more to fetch all the read and
write opcodes plus some overhead.
It does. Multiplication is much slower than addition. Some operation's
timing also depend on the specific bit patterns and overflows
encountered during the processing. Best case and worst case could easily
differ by a factor of 2 or more for one operation. So what time are you
going to use?
yes? The number of FLOPS are given by the producer for the optimal case
of completely filled pipelines so effectively 1 operation finished per
cycle per core (for an arbitrary value of core). In benchmarks they use
a more typical case yet still the pipelines will make a good contribution.
Date: 13 Jul 2008 07:59:48
Message: <4879ee34$1@news.povray.org>
OK. Well I was actually thinking more about the 6502. I don't know much
about the Z80...
Well OK. But you would have thought that various "best case" numbers
wouldn't differ by huge factors. (Now, if you wanted a *precise*
number... no, that would be rather arbitrary.)
> executed.
This is true. I was just making a side-comment that I didn't think that
*any* processor could complete one entire instruction in just 1 clock
cycle...
>> see what I mean...
Apparently, yes. (I'm damn *sure* I checked that article and didn't find
any numbers... But they're there now.)
