Orchid XP v8 wrote:
> Small question: The rate at which an object looses heat. Clearly this is
> proportional to how much hotter it is than its surroundings. But is this
> relationship linear?
No. The radiation of energy due to heat is proportional to the fourth
power of the absolute temperature.
John
>> is proportional to how much hotter it is than its surroundings. But is
>> this relationship linear?
And how about the conduction and/or convection of heat as a function of
temparature difference?
http://blog.orphi.me.uk/
Also your item receives radiation from other objects nearby, and of course
the amount depends on the temperature of them.
Conduction is linear with temperature difference, convection is more complex
because it involves fluid flow.
Also, bear in mind that the thermal properties (specific heat, conductivity,
emissivity) will change significantly with temperature, so it is really hard
to give a straightforward function of temperature.
>> Now I simply *must* know if the specific heat capacity of oil is
>> significantly different from water...
> I think it's actually lower than water.
According to Wikipedia (which, obviously, is never wrong), the specific
heat of water is about 4.1 J per g per degree, whereas for parafin wax
(the only organic compound I could find) it's 2.2 - roughly half.
I'd be interested to know what it is for typical animal fat. And also
for sugar, actually.
At this point, I hypothesize that these substances remain hotter than
hot water due to the lack of evatorative cooling...
>> (Every time I make cheese toasties, the cheese inside is hotter than
>> lava! They should fill storage heaters with that stuff or something...)
> They use it for storage heaters and cooling electrical stuff because it
> doesn't boil at 100 degrees and is an insulator.
I would imagine the fact that it doesn't corrode metal is a fact too... ;-)
>>> fourth power of the absolute temperature.
> course the amount depends on the temperature of them.
Which, I presume, means an object at thermal equilibrium emits and
absorbs equal amounts of radiation.
>> of temparature difference?
> complex because it involves fluid flow.
> conductivity, emissivity) will change significantly with temperature, so
> it is really hard to give a straightforward function of temperature.
OK. Well when I did some simple experiments at school, we found that a
glass of boiling water apporaches thermal equilibrium more or less
logarithmically. So I think we can safely conclude that thermal losses
increase at least linearly with temparature - even if the exact function
is hard to pin down.
Actually, 2.5 for parafin wax, 2.2 for ethane, and 2.2 for gasoline. So
the only three organic substances present show a remarkable [and quite
possibly coincidental] correlation.
> Which, I presume, means an object at thermal equilibrium emits and absorbs
Yes, in a vacuum. In air or with some other material contact, you need to
include the conduction of heat too.
Water is very stable thermally, for example it's specific heat varies by
less than 1% from 0 to 100 degrees. Other materials are far more unstable,
and when you have several materials together in a system it is even more
complex. Then add in that your heat source may be generating different
amounts of heat at different temperatures, and things are far from linear
once you get away from simple science experiments.
So long as it's sealed there isn't (any significant) corrosion. I imagine
the heating system you have at home has been working for several years,
probably several decades with water running round it the whole time.
>> too... ;-)
> imagine the heating system you have at home has been working for several
> years, probably several decades with water running round it the whole time.
Actually no, it was fitted about 3 years ago. ;-)
What I *have* observed is that the water inside such systems is always
jet black, and usually stinks like hell...
Soybeans, which was the only usable result google gave me for "specific
heat of oil", have a specific heat of about 1.926 to 2.912 kj/kg-K
according to
http://www.blackwell-synergy.com/doi/abs/10.1111/j.1745-4530.1999.tb00500.x
Sugar, according to
http://209.85.215.104/search?q=cache:B3m5sDbitg0J:www.solexthermal.com/assets/pdf/en/SolexCS_The%2520Solex%2520Heat%2520Exchanger%2520-%2520A%2520Better%2520Way%2520to%2520Cool%2520Sugar%2520Crystals.pdf+%22specific+heat+of+sugar%22&hl=en&ct=clnk&cd=4&gl=us,
kilo calorie is 4.185 Joules).
And, for other chemicals,
http://www.engineeringtoolbox.com/specific-heat-fluids-d_151.html is a
good table.
