POV-Ray : Newsgroups : povray.off-topic : Quotable Server Time
2 Jul 2026 22:24:30 EDT (-0400)
  Quotable (Message 101 to 110 of 179)
Subject: Re: Quotable
Date: 2 Jun 2008 16:27:30
Message: <484457b2$1@news.povray.org>
Warp wrote:
>   Assuming the particle *is* at some specific location at any given time
> instead of being distributed in space.
That too. Note that's why I specified "when you look". It's easy to tell
whether an electron is in a particular place at a particular time when
you look. It's called, for example "Dynamic RAM."  It's more difficult
to tell when you're not looking.
>> Yes, it can actually hit the other side of the Earth. It can also hit a
>> week before you shoot it. Very unlikely, but possible.
>   I don't believe in the time travelling.
You're mistaken. Happens all the time (on a sufficiently small scale).
QED doesn't work if you don't take it into account. Plus, most (or all)
of QED is time-reversable. I.e., an electron going forward in time looks
just like a positron going backwards in time.
Indeed, given a photon travels at the speed of light, time must be
stopped. Yet, we know events happen during the lifetime of a photon. If
time is stopped (by Lorenz contraction), why would a photon ever
spontaneously change into something else?
> As for the location, I assume
> the probability of it hitting the other side of the Earth is so small that
> some physical constant prevents it.
Good to know. Your opinion has been noted and filed appropriately. ;-)
Seriously, there are (reputable) people who believe electrons are
fungible because it's all the same electron moving around in time and space.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 2 Jun 2008 16:33:57
Message: <48445935$1@news.povray.org>
Warp wrote:
>   Actually "quantum physics" means that everything is quantified.
Nobody has figured out for sure if space or time are quantified. Lots of
speculation, but nothing concrete, last I heard.
> there's a minimum amount of everything (for example electric charge and
> mass),
Nope. Electric charge, yes, but not mass. Photons will have mass
proportional to their frequency, and frequency isn't apparently quantified.
> and everything is an integer multiple of that amount. You just can't
> have eg. half of the electric charge of an electron, for example.
Uh, yeah, you can, but that's because they found smaller things like
quarks. I'll grant that nobody has found something with half the charge
of a quark. :-)
>   Waves are also quantified for the same reason: There's a minimum amount
> of amplitude, for example, and all amplitudes are integer multiples of
> that amount.
Well, if you're talking about frequency, as far as I understand, this
isn't true. There's no lower limit to the frequency of a photon, nor any
quantum levels thereof. Indeed, if you believe in General Relativity,
that'll tell you there's no quantum of frequency - look at a photon
climbing out of a gravity well.
Photons are quantified, but not frequencies. There's a minimum amount of
energy a collection of photons of a specific frequency can have, and
it's an integer multiple of the energy of one photon, but there's no
quantification between photons of different frequencies.
>   These "quants" behave oddly. Sometimes they behave like particles,
> sometimes they behave like waves, and sometimes they behave like both
> at the same time. Different measurements of the exact same quant can
> show wildly different behavior in this respect. (One experiment will
> clearly show that light behaves like a wave and not like a stream of
> particles, while another experiment will show the exact opposite.)
You are out of date by several decades, I believe. That's how the math
works out, because the probabilities are two-dimensional. But you never
wind up measuring waves as such. Just probabilities of certain events
happening.
Date: 2 Jun 2008 16:35:10
Message: <4844597e$1@news.povray.org>
Mueen Nawaz wrote:
>     I question the assertion that it's been disproven. I think only a
> certain class of hidden variables have been shown not to exist. (Local
> vs non-local?)
I believe you're correct. I overgeneralized.
There are no hidden variables whose state is transported slower than the
speed of light. Certainly if general relativity is wrong, there might be
hidden quantum variables.
Date: 2 Jun 2008 16:40:42
Message: <48445aca$1@news.povray.org>
Warp wrote:
>   So why does it interfere with itself when there are two slits but not
> when there is only one?
Here's another conceivable answer, btw:
The electron you shoot out second? It's the same electron you shot out
the first time. Since it knows whether the slit was open or not last
time, it knows whether to follow the probability distribution of a
1-slit or 2-slit experiment. Since either is random, the fact there's a
one-electron delay between the two cases isn't visible.
Now, why is that sillier than "it knows whether you're going to measure
which slit it went through after it has already gone through them"? :-)
Date: 2 Jun 2008 17:39:59
Message: <484468af$1@news.povray.org>
	Define mass.
The next war will determine not what is right, but what is left.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 2 Jun 2008 17:53:47
Message: <48446beb@news.povray.org>
>> quantified.
>     Define mass.
E=mc^2?  Isn't mass measured in electron-volts?
Why? What's your point?  (This isn't sarcastic. I don't know enough to
know why someone who knows more would point out that I didn't define
mass, or that my naive understanding of it isn't correct.)
Maybe mass is quantified at the quantum level, since mass seems to be
related to gravity (as in, inertial mass seems to always equal
gravitational mass) and gravity hasn't found a quantum theory yet, sure.
But frequency isn't "and everything is an integer multiple of that
amount" kind of thing, as far as I know, right?
Date: 2 Jun 2008 17:57:20
Message: <48446cc0$1@news.povray.org>
 > at the same time.
Actually, you might be confused because you're not being precise enough.
The way I think you want to think about it is this:
"Sometimes they behave like particles" means "in some experiments, we
get results whose mathematical formulation is isomorphic to the
whatever-they-ares being particles."
"Sometimes they behave like waves" means "in other experiments, we get
results whose mathematical formulation is isomorphic to the the behavior
of waves."
In particular, the times you see "behavior like waves" is when you stop
*measuring* "does it behave like a particle?"  The times you see
"behavior like a particle" is when you stop *measuring* whether it
behaves like waves. But in each case, you're explicitly excluding some
of the behavior and not too unsurprisingly seeing the other behavior.
In other words, when you do the math, sometimes the results you get for
electrons are the same results as those you get for waves. That doesn't
mean electrons *are* waves, any more than it means that light behaving
like a wave needs a medium to "wave" in order to travel.
Sort of like a PRNG. Some experiments you do, it looks random. That
doesn't mean it's random. It just means you haven't seen the real thing,
and you haven't measured whether it's deterministic or not. But every
time you *do* measure whether it's deterministic, it looks like it is.
Every time you take a (good) PRNG and measure its statistical
properties, it looks random. Every time you start a (good) PRNG from the
same seed, you get the same values. That doesn't mean sometimes the PRNG
is deterministic and sometimes it isn't.
Sort of like General Relativity. You can predict which way a satellite
in outer space will go by assuming gravity is a force like muscular
exertion is a force. That doesn't mean gravity *is* a force - it just
has the same equations (modulo Lorenz contraction, of course).
"Exact same"? I didn't know you could tell electrons apart.
Yes. That doesn't mean sometimes it *is* a wave and sometimes it *is* a
particle. It means that sometimes the particle behaves in a way that can
be predicted with the same mathematical formulas that predict the
behavior of waves.
Plus, as I understand it, light as such doesn't have a specific
"frequency". The light source does, but not the photons themselves. But
I'll admit I'm probably very confused on this one. I.e., a photon isn't
"waving" as such while it travels, but you can tell frequency by looking
at the probability vectors of photons over time coming out of a source.
If there's anyone who can actually explain that better to a layman, I'd
love to hear it. :-)
Note that a single electron does *not* interfere with itself in the same
way a wave does. If it did, it would cancel itself out sometimes, and
that doesn't happen. You can set up a detector behind the two slits
that's too imprecise to tell you *which* slit the electron went through,
but can tell you it went through, and the two sets of detectors will
count approximately the same number of events. Hence, electrons don't
interfere with themselves in a wave-like manner. They just change the
probabilities of where they'll land, and the formula for that is the
same as the formula for a wave, and for the same reason - they're both
multiplications (and hence convolutions) of cyclic 2-dimensional values.
(Oh, and as for "half the charge of an electron", the one that boggles
my mind is spin-2 particles. A particle that's not symmetric when you
turn it 360 degrees, but is when you turn it 720?)
Date: 2 Jun 2008 18:24:14
Message: <4844733C.8080700@hotmail.com>
Darren New wrote:
> Mueen Nawaz wrote:
Though quarks are supposed to have fractional charge.
>>> quantified.
>>     Define mass.
Also not sure what Mueen means, but the m in E=mc^2 is the m that was
used by einstein. IIRC the current definition would require a division
by sqrt(1-v^2/c^2). The old definition was certainly not quantified for
arbitrary velocities.
I have still not heard if the experiment to do gravitational experiments
with anti-hydrogen (anti-proton with positron) did succeed, but I left
the field some time ago.
Date: 2 Jun 2008 19:16:52
Message: <48447f64@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> >   Because time travel doesn't exist?
> At the quantum level, it most certainly does.
  That would create paradoxes.
Date: 2 Jun 2008 19:26:25
Message: <484481a1@news.povray.org>
Mueen Nawaz <m.n### [at] ieeeorg> wrote:
> One could simply explain this by saying
> that the presence of two slits causes the electron to act in a
> probabilistic manner - resulting in an interference pattern.
  That's not an explanation. You are not telling what exactly is it
with the two slits that causes the interference pattern, you are just
telling that when there are two slits, there is an interference pattern.
Thus you are not explaining anything, you are simply stating the result
of the experiment.
>         And, AFAIK, that's the best explanation there is.
  Except that it's not an explanation at all. It's simply stating the
result of the experiment.
>         And detecting which slit an electron passes through is also evidence
> that it isn't passing through both slits.
  It's only evidence that measurements mess up with the electron. It
doesn't explain the reason for the interference pattern.
