POV-Ray : Newsgroups : povray.off-topic : A small puzzle Server Time
14 Jun 2026 01:38:19 EDT (-0400)
  A small puzzle (Message 39 to 48 of 198)
Subject: Re: A different measure
Date: 19 May 2008 07:52:57
Message: <48316a19@news.povray.org>
Paul Fuller <pgf### [at] optusnetcomau> wrote:
> I find the fact that such a seemingly miniscule amount of fuel can be
> used to propel quite massive vehicles along at such speeds quite
> amazing.
  Once the car is moving it only requires the amount of fuel necessary
to overcome the friction which would otherwise stop the car. Given that
the car has an enormous amount of momentum, the amount of energy needed
to keep it against such small things as air friction isn't all that large.
  Compare it to the amount of fuel needed to get the car from 0 to 100 km/h
in a relatively short amount of time.
Date: 19 May 2008 08:15:04
Message: <48316f48$1@news.povray.org>
At 75 mph air friction isn't small.  A lot of small cars give up not much
faster than this because their engine cannot generate enough power to
overcome the air friction.
Much less than getting to 100 km/h in a long time...
IMO, the surprise at the small amount of fuel needed comes from the fact
that the energy density of petrol is so high.  We hear figues like 6 litres
per 100 km, but 6 litres of petrol equals around 200 MJ of energy, enough to
lift a 747 plane 100 metres in the air!
Date: 19 May 2008 08:28:17
Message: <48317261$1@news.povray.org>
Orchid XP v8 wrote:
> Still, you'd think it would be possible to somehow take plants living
> today and transform their tissues into some kind of highly flammable
> hydrocardon with reasonably efficiency. This would seem the obvious
> sustainable solution.
They do something of the sort - Biodiesel
But that's what politicians are blaming on the food shortages and price
increases.  Go figure....
Tom
Date: 19 May 2008 08:29:52
Message: <483172c0$1@news.povray.org>
And for screwing up engines.
Subject: Re: A small puzzle
Date: 19 May 2008 08:55:42
Message: <483178cc@news.povray.org>
How about this classical physics problem:
  You drop a rock into a water well. Then you hear the splash. Exactly
10 seconds pass between you letting go of the rock and when you hear the
splash. How deep is the well?
  We can assume that air friction is negligible, that g = 9.81 m/s^2,
and that the speed of sound is 340 m/s.
  Don't just give the answer, also write your whole reasoning.
Date: 19 May 2008 10:02:46
Message: <48318886@news.povray.org>
Hmm, takes me back to school.
10 = t(sound) + t(rockfall)
t(sound) = x/340 where x is the well depth
x = 1/2 * g * t(rockfall)^2
so
t(rockfall) = sqrt(2x/g)
substituting back in,
10 = x/340 + sqrt(2x/g)
sub y = sqrt(x), rearrange
(1/340)*y^2 + sqrt(2/g)*y - 10 = 0
solve quadratic for positive y, square y to get x
I get x = 393.25m, sounds about right but my arithmetic might be wonky.
Date: 19 May 2008 10:17:20
Message: <48318bf0$1@news.povray.org>
Hmm, the object has an initial velocity v0 = 0 m/s.
Assuming zero air resistence, the object as infinite terminal velocity
and accelerates uniformly at 9.81 m/s^2. This yields
   vt = 9.81 t
The integral of this would be the object's position:
   pt = 9.81/2 t^2 = 4.905 t^2
We hear the splash at t=10. Assuming that sound is initiated at time t=K
and it propogates towards the observer at 340 m/s, we have
   K = 10 - d/340
where d is the distance to the bottom of the well.
So, we know that d must obey
   K = 10 - d/340   and   4.905 K^2 = d
Rearranging, we have
   K - 10 = -d/340
   340 (K - 10) = -d
   340 K - 3,400 = -d
   -340 K + 3,400 = d
So d = -340 K + 3,400 = 4.905 K^2.
At this point, I have insufficient knowledge of algebra to deduce a
solution, although obviously one exists.
http://blog.orphi.me.uk/
Date: 19 May 2008 10:27:26
Message: <48318e4e$1@news.povray.org>
You should learn how to calculate the solution to equations like this, they
come up everywhere:
http://en.wikipedia.org/wiki/Quadratic_equation
Date: 19 May 2008 10:42:04
Message: <483191bc$1@news.povray.org>
> they come up everywhere:
Solving a single quadratic equation is trivial. Solving a pair of linear
equations is trivial. But I have no idea how to solve a pair of
equations where one is linear and the other isn't.
[Actually, I can still remember sitting down and deriving the quadratic
formula from first principles. It's quite instructive! Whoever it was
that figured out that A*B - 4*(A+B) = A-B is some kind of genius if you
ask me... The next day I tried to do the same with a cubic, but... uh...
failed.]
Date: 19 May 2008 10:45:10
Message: <48319276$1@news.povray.org>
What do you call that equation you got at the top there?
