POV-Ray : Newsgroups : povray.off-topic : A question about Java generics (not a flame) Server Time
7 Apr 2026 15:29:59 EDT (-0400)
  A question about Java generics (not a flame) (Message 44 to 53 of 63)
Subject: Re: A question about Java generics (not a flame)
Date: 14 May 2008 16:52:33
Message: <482b5111$1@news.povray.org>
Fredrik Eriksson wrote:
> On Wed, 14 May 2008 18:23:54 +0200, Darren New <dne### [at] sanrrcom> wrote:
>> *** Main2.cpp
>> #include <A.h>
>> void A::xx(int i) {
>>    cout << "Beta!\n";
> This will fail to compile, because you cannot redefine A::xx.
I didn't. I created an overloaded version. One takes an int, the other
takes a long.  Am I *completely* clueless about C++?
My intent was to get one match to do a silent upcast from int to long,
and the other to match the more-appropriate int-accepting function.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 14 May 2008 17:01:28
Message: <op.ua5woqdy7bxctx@e6600>
>>> *** Main2.cpp
>>> #include <A.h>
>>> void A::xx(int i) {
>>>    cout << "Beta!\n";
You cannot add overloads to class methods from outside the class. All
overloads must be declared in the class declaration.
FE
Date: 14 May 2008 17:08:28
Message: <482b54cc$1@news.povray.org>
Thanks!
Date: 15 May 2008 08:45:40
Message: <482c3074@news.povray.org>
> *** A.h
> void X<T>(void);
> class A {
>    void xx(long i) {
>      cout << "Alpha!\n";
> #include <A.h>
> void A::xx(int i) {
>    cout << "Beta!\n";
  You are trying to implement a function void A::xx(int) which hasn't
been declared in the class A declaration. It won't compile.
  Note that void A::xx(long) and void A::xx(int) are two different functions,
with different fingerprints. You cannot override one with the other.
Date: 15 May 2008 08:49:55
Message: <482c3173@news.povray.org>
Fredrik Eriksson <fe79}--at--{yahoo}--dot--{com> wrote:
> Now make a small change to main.cpp:
> // main.cpp
>    export template <typename T> void f();
>    #include "g.hpp"
>    template <> void g(int i) { /* Do something completely different */ }
>    int main(){ f<int>(); }
> // end main.cpp
  I don't see how this causes a problem described earlier. This simply
requires main.cpp to be recompiled (after all, it's the one which has
been changed), which will result in a new object file which does not
use the export template.
  Why would this cause the need to recompile the export template for
each usage in the program?
Date: 15 May 2008 11:59:34
Message: <482c5de6$1@news.povray.org>
That I didn't know. Will it work if you just make xx(int) and xx(long)
globals?
Well, I was trying to overload, not override as such.
Date: 15 May 2008 12:07:59
Message: <482c5fdf@news.povray.org>
> globals?
  Maybe what you are trying to write is something like this:
foo.cc:
export template<typename T>
void foo(T t) { bar(t); }
a.cc:
void foo(T t);
void bar(int i);
void a() { foo(5); }
b.cc:
void foo(T t);
void bar(long i);
void b() { foo(5); }
  I see how that could make some difference.
Date: 15 May 2008 12:12:17
Message: <482c60e1@news.povray.org>
> foo.cc:
  OTOH, thinking about it: There's no function named 'bar' defined anywhere
in the scope of foo.cc, so why should that even compile?
  I have to admit I don't know if the C++ standard requires the environment
of the instantation of the template when compiling the template function or
not. Personally I wouldn't find it illogical if foo.cc above would cause
a compiler error because, after all, there's no 'bar()' function defined
there.
Date: 15 May 2008 12:33:29
Message: <482c65d9$1@news.povray.org>
Something like that, yeah. Something where the overload resolution in
the expanded template requires it to be calling different functions
depending on declarations that came in the main program before the
instantiation of the template.
Date: 15 May 2008 12:35:19
Message: <482c6647@news.povray.org>
Move the declaration of bar(long) into foo.cc? Then if there's a
bar(int) in scope, it should be preferred over bar(long), if I follow
the overloading rules properly?
