POV-Ray : Newsgroups : povray.off-topic : A question about Java generics (not a flame) Server Time
10 Jun 2026 00:19:57 EDT (-0400)
  A question about Java generics (not a flame) (Message 41 to 50 of 63)
Subject: Re: A question about Java generics (not a flame)
Date: 14 May 2008 06:45:17
Message: <482ac2bc@news.povray.org>
Fredrik Eriksson <fe79}--at--{yahoo}--dot--{com> wrote:
> If you change the set of functions that take objects of type T as a
> parameter, the instantiation context changes for a template with T as a
> type parameter, even though the signature of the template remains the same.
  Can you give me a concrete example?
Date: 14 May 2008 12:23:53
Message: <482b1219$1@news.povray.org>
I probably have all the syntax mixed up, and maybe you need to do
something more complicated with friend functions and everything else,
but this is my understanding of what they were talking about in the
paper?  Basically, the environment in which X<T> is expanded is
different, so the xyz.xx(4) would promote 4 to a long in main1 and not
main2.
*** A.h
void X<T>(void);
class A {
   void xx(long i) {
     cout << "Alpha!\n";
*** X.cpp
void X<T>(void) {
   T xyz;
   xyz.xx(4);
*** Main1.cpp
#include <A.h>
void main1(void) {
   X<A>();
*** Main2.cpp
#include <A.h>
void A::xx(int i) {
   cout << "Beta!\n";
void main2(void) {
   X<A>();
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 14 May 2008 15:07:05
Message: <op.ua5rd2kh7bxctx@e6600.bredbandsbolaget.se>
On Wed, 14 May 2008 18:23:54 +0200, Darren New <dne### [at] sanrrcom> wrote:
> *** Main2.cpp
> #include <A.h>
> void A::xx(int i) {
>    cout << "Beta!\n";
This will fail to compile, because you cannot redefine A::xx.
What I had in mind is something like this (untested, for obvious reasons):
// g.hpp
   template <typename T> void g(T t) { /* Do whatever */ }
// end g.hpp
// main.cpp
   export template <typename T> void f();
   int main(){ f<int>(); }
// end main.cpp
// export.cpp
   #include "g.hpp"
   template <typename T> void f(){ g( T() ); }
// end export.cpp
Now make a small change to main.cpp:
// main.cpp
   #include "g.hpp"
   template <> void g(int i) { /* Do something completely different */ }
// end main.cpp
The instantiation context for the exported template changes, because there
is now an additional function participating in name lookup. In this case
the behaviour also changes because the new function is a better match.
Note that the signature of the exported template remains the same.
Note: I think the same should apply even if 'g' was not a template, but
GCC disagrees (tested without 'export' of course). VC does what I expect
though. I wish I knew which is right.
FE
Date: 14 May 2008 16:52:33
Message: <482b5111$1@news.povray.org>
>> *** Main2.cpp
>> #include <A.h>
>> void A::xx(int i) {
>>    cout << "Beta!\n";
I didn't. I created an overloaded version. One takes an int, the other
takes a long.  Am I *completely* clueless about C++?
My intent was to get one match to do a silent upcast from int to long,
and the other to match the more-appropriate int-accepting function.
Date: 14 May 2008 17:01:28
Message: <op.ua5woqdy7bxctx@e6600>
>>> *** Main2.cpp
>>> #include <A.h>
>>> void A::xx(int i) {
>>>    cout << "Beta!\n";
You cannot add overloads to class methods from outside the class. All
overloads must be declared in the class declaration.
FE
Date: 14 May 2008 17:08:28
Message: <482b54cc$1@news.povray.org>
Thanks!
Date: 15 May 2008 08:45:40
Message: <482c3074@news.povray.org>
> *** A.h
> void X<T>(void);
> class A {
>    void xx(long i) {
>      cout << "Alpha!\n";
> #include <A.h>
> void A::xx(int i) {
>    cout << "Beta!\n";
  You are trying to implement a function void A::xx(int) which hasn't
been declared in the class A declaration. It won't compile.
  Note that void A::xx(long) and void A::xx(int) are two different functions,
with different fingerprints. You cannot override one with the other.
Date: 15 May 2008 08:49:55
Message: <482c3173@news.povray.org>
> // main.cpp
>    #include "g.hpp"
> // end main.cpp
  I don't see how this causes a problem described earlier. This simply
requires main.cpp to be recompiled (after all, it's the one which has
been changed), which will result in a new object file which does not
use the export template.
  Why would this cause the need to recompile the export template for
each usage in the program?
Date: 15 May 2008 11:59:34
Message: <482c5de6$1@news.povray.org>
That I didn't know. Will it work if you just make xx(int) and xx(long)
globals?
Well, I was trying to overload, not override as such.
Date: 15 May 2008 12:07:59
Message: <482c5fdf@news.povray.org>
> globals?
  Maybe what you are trying to write is something like this:
foo.cc:
export template<typename T>
void foo(T t) { bar(t); }
a.cc:
void foo(T t);
void bar(int i);
void a() { foo(5); }
b.cc:
void foo(T t);
void bar(long i);
void b() { foo(5); }
  I see how that could make some difference.
