POV-Ray : Newsgroups : povray.off-topic : Microsoft may have done something right... Server Time
16 May 2026 23:05:04 EDT (-0400)
  Microsoft may have done something right... (Message 11 to 20 of 44)
Subject: Re: Microsoft may have done something right...
Date: 22 Mar 2008 15:22:56
Message: <47e56aa0$1@news.povray.org>
Warp wrote:
>   I have no idea about the principles used in C#, but if it's anything like
> Java, the biggest problem is not so much speed as memory usage. In Java
> I don't think there's any way around the problem that you cannot create
> a data container where each element takes as much memory as the total size
> of the members of the object, nothing more. The smaller the object is, the
> worse the memory usage overhead relative to this size.
Wasn't it John Carmack who said that Java is a great way of doing things
at 1/10th the speed they should be done at? :)
Anyway, one of the first things I noticed in looking over C# is the
difference in structs and classes.  Basically, a Class is the same as a
C++ struct / class, with the indirection et al, allocated on the heap.
A struct, on the other hand, has no member functions, and is a simple
collection of the base data types all allocated on the stack.  Very
sparse memory usage, and very fast, either as individual instances or in
collections.
...Ben Chambers
www.pacificwebguy.com
Date: 22 Mar 2008 15:25:41
Message: <47e56b45$1@news.povray.org>
Warp wrote:
> Chambers <ben### [at] pacificwebguycom> wrote:
>> 2) Resource manage is *incredibly* easy.  In the "Solution Explorer",
>> simply bring up the context menu and choose "Add Existing" or "Add New",
>> give it a name (and select the file if it aleady exists), and it's
>> imported into the correct directory.
>   Does it have any support for creating a (possibly encrypted) package
> from all the resources so that you don't have to distribute a bare version
> of your resources directory structure, but instead you can simply distribute
> this single package file with your program?
It does have support for packaging your projects, but I don't believe it
has encryption.  It's compiled into a bytecode, so it's very easy to
decompile into the original sources.  If you encrypted it, then the same
key which allows it to execute would allow it to be decompiled.
Of course, you could use an obfuscator, and there are commercial
packages available that integrate nicely with VS to do this
automagically for you when you build your project.
...Ben Chambers
Date: 22 Mar 2008 17:29:18
Message: <47e5883e$1@news.povray.org>
Chambers wrote:
> C++ struct / class, with the indirection et al, allocated on the heap. A
Woops, this is wrong.  Structs *can* have member functions.
Also, structs are passed by value whereas classes are passed by reference.
...Ben Chambers
Date: 23 Mar 2008 05:10:56
Message: <47e62cb0@news.povray.org>
  Hmm, that's not really what I asked...
Date: 23 Mar 2008 12:59:55
Message: <47e69a9b@news.povray.org>
Sorry, you're right.  I was thinking of encrypting the sources, you were
thinking of encrypting the data.
Anyway, as I said, it does support packaging your project.  And, to
clarify, that includes the resources.
...Ben Chambers
Date: 23 Mar 2008 14:17:36
Message: <47e6acd0@news.povray.org>
  To avoid any misunderstanding: By "packaging" I don't mean "create an
installer file which you can distribute and which will install the program
in the user's computer".
  What I mean is that if it supports creating one single file which has
the data inside it, and then at runtime it reads the data directly from
that file instead of unpackaging it to the disk first (thus restoring
the original directory structure and files inside it).
  In other words, can you do so that your program consists of two files:
An executable file and a data file, and the program runs with just those
two files and doesn't create any additional files?
  Moreover, can some light encryption be applied to this data file (to
make unpackaging it slightly harder)?
Date: 23 Mar 2008 15:14:44
Message: <47e6ba34$1@news.povray.org>
To clarify: I understand :)  That is indeed what I am trying to say that
it does.  At least, as far as I understand it.
Hmm... I'll go try it right now to make sure it works...
...Ben Chambers
Date: 23 Mar 2008 21:42:12
Message: <47e71504@news.povray.org>
Slight problem: The install file created repeated crashes.  I'll have to
investigate this further, but I'm done playing with it for today.
...Ben Chambers
Date: 24 Mar 2008 17:46:46
Message: <47e82f56@news.povray.org>
> Darren New <dne### [at] sanrrcom> wrote:
>> nemesis wrote:
>>> *Anything* compiles extremely quickly compared to C++.  Just don't perform the
>>> same.
>> With JIT compilers and such, I'm not sure how you can be so sure. :-)
> Look for the top:
http://shootout.alioth.debian.org/gp4/benchmark.php?test=all&lang=all&calc=Calculate&xfullcpu=1&xmem=0&xloc=0&binarytre
es=1&chameneosredux=1&fannkuch=1&fasta=1&knucleotide=1&mandelbrot=1&meteor=0&nbody=1&nsieve=1&nsievebits=1&partialsums=
1&pidigits=1&recursive=1&regexdna=1&revcomp=1&spectralnorm=1&hello=0&sumcol=1&threadring=1
> with memory performance taken into consideration as well, it only gets worse:
http://shootout.alioth.debian.org/gp4/benchmark.php?test=all&lang=all&calc=Calculate&xfullcpu=1&xmem=1&xloc=0&binarytre
www.tinyurl.com for next time...
Date: 24 Mar 2008 17:47:56
Message: <47e82f9c$1@news.povray.org>
Agreed. I hate how I can't make arrays of objects in Java. Only arrays
of references to objects.
