POV-Ray : Newsgroups : povray.off-topic : C++ structuring help.... Server Time
4 Jul 2026 05:00:42 EDT (-0400)
  C++ structuring help.... (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: C++ structuring help....
Date: 22 Mar 2008 14:25:19
Message: <47e55d1f$1@news.povray.org>
Warp wrote:
>   There are a few cases where a global instance may be more practical than
> harmful.
Yeah. Kind of like "goto". :-)
> In C++ in particular, though, I still prefer putting those inside
> a namespace.
Certainly if you can give it a name that groups it appropriately, that's
an improvement.  I just call anything whose lifetime and scope are both
"the entire execution of the program" a global, regardless of how the
name is qualified.  I don't think putting it inside a namespace prevents
too many of the traditional problems associated with globals.
>   As I mentioned, I think std::cout is a good example.
Exactly. It means one thing, and it means that thing throughout the
entire lifetime of the program. Unlike, say, "errno", whose semantics
are poor due to not meaning anything obvious if the immediately
preceding system call didn't fail - i.e., there are far too many caveats
on when errno is "valid" for it to count as a good use of globals. It's
more a kludge due to C not being able to return multiple values.
Of course, throw in threads and everything gets more confusing. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 22 Mar 2008 14:31:18
Message: <47e55e85@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> > harmful.
  I disagree. I have been writing C++ for hobby and professionally for
over 10 years, and the total amount of C++ I have written is probably
closer to 100k lines of code. I don't remember *ever* writing even a
single "goto".
  It's not like I avoid it. I just don't need it. (Usually good basic
encapsulation takes automatically care of anything that would be an
"acceptable use of goto" otherwise.)
  Global variables (inside namespaces or not) is not something I have used
a lot, but I have a few times. I believe I can rationally argue for the
rationality of each one.
Date: 22 Mar 2008 14:36:45
Message: <47e55fcd$1@news.povray.org>
> single "goto".
Note that calling "return" in the middle of a function is equivalent to
"goto". :-)  Arguably "continue" and "break" and exceptions as well.
Those are all non-structured constructs.
And, of course, depending on your language, "goto" may be more or less
common.  Take break and continue out of your loops, take try/finally out
of your exception handling, and suddenly there's places where "goto" is
cleaner.
Admittedly, not a lot. Indeed, Tcl doesn't even have a goto. For a
language where it's pretty trivial to implement your own control
structures, I think I'd have a hard time implementing "goto" in Tcl.
Agreed.  I was just trying to say that there are people who think "goto"
is inherently evil, and that globals are inherently evil, because that's
what they've been taught, but that's really just lies-to-children until
they have enough experience to learn the few places where it really does
make more sense.
And then as programming languages evolve, they incorporate the good
places to use a goto into the syntax of the language and call it
something else, like "try/catch" or "return".
Go back to Pascal with no break, no early return, no exceptions, and
you'll realize where you miss your "return". :-)
Yep.
Date: 22 Mar 2008 14:42:48
Message: <47e56138@news.povray.org>
> > single "goto".
  I really think that when Dijkstra wrote "goto considered harmful" he
really meant "goto", as in "jump to a label", and not other control
structures (such as returns, loops and conditionals).
  The idea is that "goto" (ie "jump to a label") makes the code more
obfuscated than other control structures, and usually needlessly so.
> make more sense.
  I don't think goto is inherently evil. I think it's inherently unnecessary,
and overusing it is a bad idea. In the vast majority of cases there are
better alternatives.
  At least those state more clearly their intention and are not so easy
to misuse.
Date: 22 Mar 2008 18:40:04
Message: <47e598d4$1@news.povray.org>
I think when he wrote it, he was primarily addressing a generation of
FORTRAN programmers. :-)  The people he was talking to generally didn't
have things like "if/then/else" in the language they came from.
Right. Structured programming is where each statement has an entrance
and an exit. That's what (IIRC) Dijkstra was talking about.
Returning from the middle of a function also *can* make code more
obfuscated. Certainly it isn't structured. Maintaining a function with
internal returns when you need to put something at the end is as bad as
making a function work that can throw exceptions when you have no
"finally" type of functionality.
Take a look at something like Eiffel, where there's no goto, no return,
no break or continue, and exceptions either abort your function or start
over at the beginning of it, depending on whether you catch them or not.
I can imagine situations where a goto might be handy in such a language.
"break" and "continue" and "return" and "catch" are all just limited
versions of "goto" that give you the way to do the good stuff with
"goto" without giving you the way of doing the "bad" stuff with goto.
Agreed. But again, it depends on the language. Something like the
original version of Pascal? Not uncommonly the best way to get out of a
nested loop, or to have several bits of code all clean up in a "finally"
kind of way.  Something like the original BASIC?  Unquestionably
necessary as it was the only way to build a while loop.
Much of the control structure research in "normal" languages
(single-threaded etc) consists of better ways of expressing "goto". :-)
> to misuse.
Exactly. And take them out of the language (like when Dijkstra was
writing) and he's talking about using "goto" in good ways, namely in
structured ways.
Date: 22 Mar 2008 19:48:45
Message: <47e5a8ed@news.povray.org>
  Dijkstra advocated structured programming as a replacement for the
heavily "goto-based" programming of the time. Structured programming
introduced concepts which are common in most current languages. The
more the reason to not to use goto...
Date: 22 Mar 2008 19:58:44
Message: <47e5ab44$1@news.povray.org>
Exactly. And the structured programming he introduced also eschewed
early returns, break, continue, etc. That's all I'm trying to say. :-)
If your language has *no* unstructured control-flow statements (such as
early returns, break, continue, etc) then you probably wind up using
goto about as much as you wind up using globals.
Date: 22 Mar 2008 21:28:43
Message: <47e5c05b$1@news.povray.org>
Actually, this discussion lead to an interesting insight (for which I
thank you).
The real problem with "goto" is not so much the "goto" as the "come
from". I.e. you see a label, and anything in scope of that label might
branch there. In something like COBOL or (dartmouth) BASIC, anywhere in
the entire program might branch to any label in the entire program.
If you refactor a program to take some commonality out of a handful of
functions, and that commonality doesn't really stand on its own, you
haven't really structured it. You've just used a function as a goto.
I have a bit of program that takes an audio sample and tries to find a
match. It does some stuff up front, and then depending where it looks
for it, it makes different decisions to see if it "matches". It may or
may not take timezones into account. It may or may not take time into
account at all. It may or may not take the character set of the returned
metadata into account, or the source of the metadata.  Depending what we
match it again, there's four or five or six (depending on how you count)
matching routines. I remember at one point wishing I had the FORTRAN
"entry" declaration available. :-)
In any case, when I refactored the part that actually ran on *that*
particular sort of computer, I actually wound up with a routine that's
pretty much meaningless outside that matching mechanism, and which gets
a whole bunch of variables that used to be local and don't make any
sense as independent parameters (e.g., the logging information so far
onto which I append more heuristic results so I can tell why it does or
doesn't work after the fact, which of the fault-tolerance servers were
queried and whether the first one worked or not, which column of the
database to pull character set information out of, etc.) Stuff going in
and out which you'd never have put in there had you not ripped the
routine out of three copy-and-paste(*) functions and modularized it.
That's really not structured programming. That's three functions all
using "goto" to go to the start of that function and passing any locals
it uses in and out as parameters.  It's just another way of writing a
goto, and it really doesn't clarify the code any as you might otherwise
expect from "lifting common functionality into a subroutine."
Interesting.
(*) That's maybe the fourth or fifth time here I've changed
"cut-and-paste" to "copy-and-paste" on this forum. I'm not sure whether
to thank Warp for correcting me or be annoyed at him. ;-)
Date: 24 Mar 2008 18:21:24
Message: <47e83774@news.povray.org>
> make more sense.
C++ FAQ Lite:
One size does not fit all. Stop. Right now, take out a fine-point marker
and write on the inside of your glasses: Software Development Is
Decision Making. "Think" is not a four-letter word. There are very few
[and from another FAQ:]
It really bothers me when people think they know what's best for your
problem even though they've never seen your problem!! How can anybody
possibly know that multiple inheritance won't help you accomplish your
goals without knowing your goals?!?!?!?!!!
Date: 25 Mar 2008 06:51:36
Message: <47e8e748@news.povray.org>
> if any "never..." and "always..." rules in software ??? rules that you can
> apply without thinking ??? rules that always work in all situations in all
> markets ??? one-size-fits-all rules.
  Maybe "never use goto" is wrong, but "in the over 10 years I have programmed
I have never needed goto" is right. I think it's rather telling.
  I completely disagree with anyone who says that multiple inheritance
is a bad thing.
  Sure, multiple inheritance can be misused. But so can regular inheritance.
So can variable and function naming. *Anything* can be misused.
