POV-Ray : Newsgroups : povray.off-topic : C++ structuring help.... Server Time
10 Oct 2024 19:24:12 EDT (-0400)
  C++ structuring help.... (Message 1 to 10 of 19)
Subject: C++ structuring help....
Date: 20 Mar 2008 18:21:03
Message: <47e2f15f@news.povray.org>
As I progress in my understanding of C++, I come closer to the
inevitable conclusion that in order to make my code more efficient and
easy to alter, I need to learn more about classes and structs. Simple
concepts, but the problem comes with implementing said features.
A simple (tile based) level editor is my current project. Already, I
have about two dozen global variables. It's getting messy, and I'm
having to rewrite code to handle, say, foreground tile editing as
opposed to background tile editing.
Does anyone have a link to some good tutorials to help me manage this
ever-growing pile of data? I need to encapsulate everything. I'd like to
rid myself of global variables entirely, if that's possible. Thanks~
Sam
Subject: Re: C++ structuring help....
Date: 20 Mar 2008 19:00:03
Message: <47e2fa83@news.povray.org>
  High-quality object-oriented design is far, far from trivial to do.
It requires years of OOD and OO programming experience, and even then
it usually requires several iterations of design-use-redesign.
  Making a good, encapsulated, abstract, flexible and reusable graphical
editor is a rather difficult tasks of OOD in general (regardless of the
programming language used) and C++ programming in particular. I know this
because I have been working on exactly such a thing as my payjob.
  You are on the right track, though: Global variables should and can
be avoided (there are very few exceptions to this rule, of which eg.
std::cout is a good example (I consider std::cout to be a "global" variable
even though it's inside a namespace), where practicality compensates
globality more than enough), and clean abstract designs should be preferred.
Date: 20 Mar 2008 20:46:57
Message: <47e31391$1@news.povray.org>
OOC, do you consider static members to be global? They're not tied to an
instance of an object, but are generally available throughout the
program (if made public)
Date: 21 Mar 2008 00:33:12
Message: <47e34898@news.povray.org>
Thanks, I feel both better and worse.
I'll just have to take baby steps and see what I learn. Thanks!
Sam
Date: 21 Mar 2008 12:43:11
Message: <47e3f3af$1@news.povray.org>
> be avoided
While generally true, I find that if the *meaning* of a variable is
truly global, it can be made a global harmlessly.
FILE * resourcefule;
   // The handle to the resource file if it's open, or NULL if not.
Stuff like that. If there's ever an instant where the definition of the
variable doesn't match its content, then it isn't global, it's just a
backdoor to pass parameters between functions.
Of course, with OO more than procedural code, you're more likely to pull
a class into some other framework where it wasn't expected to be, so
there's less good use for globally-visible variables. (Unless, of
course, your language treats classes as globals, rather than as second
class objects.)
But I've never regretted making a global that was truly global in that
sense, so anyone could reference it.  "Bad" globals are ones that don't
have a meaningful value for the entire duration of the program, from the
first line to the last, methinks.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 21 Mar 2008 16:56:21
Message: <47e42f05@news.povray.org>
stbenge wrote:
> Hi,
The easiest way to get rid of the globals is to declare a class which
has some static members in it:
appdata.h:
class AppData {
     static int AppDataInt;
appdata.cpp:
#include "appdata.h"
int AppData::AppDataInt=0; // or whatever
Everytime you want to use your formerly global data, you include
appdata.h in the file and make sure you use the scope resolution to
access it.
One benefit of this is that you can now borrow code from another project
that uses globals without worrying about those globals conflicting with
your ex-globals.
Additionally, you can make make the static members of AppData private
members, and access them through member functions of AppData, to enforce
sanity checks on the changes you make to the data.
I've been doing C++ since '02, and most of the hands-on involves my
modeling application; it was originally written in C starting in 1999,
and much of the code base remains a product of non-OOP C thinking.
John
Date: 22 Mar 2008 13:47:54
Message: <47e5545a@news.povray.org>
  Not really because they don't garbage the global namespace and, most
importantly, they cannot be pulled out of the class, unlike things inside
namespaces can.
Date: 22 Mar 2008 13:50:26
Message: <47e554f2@news.povray.org>
  There are a few cases where a global instance may be more practical than
harmful. In C++ in particular, though, I still prefer putting those inside
a namespace.
  As I mentioned, I think std::cout is a good example.
Date: 22 Mar 2008 13:58:11
Message: <47e556c0@news.povray.org>
  IMO that only masks the problem, it doesn't solve it.
  If you find yourself using tons of global variables that's usually a
sign of an overall design flaw in your program. Moving the globals inside
a namespace or a class doesn't really solve the underlying design problem.
  As I have already mentioned, not all global variables are bad, and it's
not like you would have to avoid them like the plague. However, usually
the vast majority of global variables, especially if you find yourself
writing tons of them, are a sign of bad design.
  It's usually a sign that you are not using proper encapsulation and
proper abstraction, which are key concepts in creating high-quality reusable
and flexible code.
  Note that the problem with global variables is *not* exclusively that
the garbage the global namespace. That's actually the smallest of the
problems involved. That's why simply masking this one problem isn't really
the answer to the bigger design problems.
  With small projects good OOD doesn't really matter. However, the larger
the project, the more it becomes really useful.
Date: 22 Mar 2008 14:25:19
Message: <47e55d1f$1@news.povray.org>
> harmful.
Yeah. Kind of like "goto". :-)
> a namespace.
Certainly if you can give it a name that groups it appropriately, that's
an improvement.  I just call anything whose lifetime and scope are both
"the entire execution of the program" a global, regardless of how the
name is qualified.  I don't think putting it inside a namespace prevents
too many of the traditional problems associated with globals.
Exactly. It means one thing, and it means that thing throughout the
entire lifetime of the program. Unlike, say, "errno", whose semantics
are poor due to not meaning anything obvious if the immediately
preceding system call didn't fail - i.e., there are far too many caveats
on when errno is "valid" for it to count as a good use of globals. It's
more a kludge due to C not being able to return multiple values.
Of course, throw in threads and everything gets more confusing. :-)
