POV-Ray : Newsgroups : povray.off-topic : Backup Server Time
9 Jun 2026 05:00:39 EDT (-0400)
  Backup (Message 11 to 20 of 58)
Subject: Re: Backup
Date: 19 Mar 2008 04:57:35
Message: <47e0e38f$1@news.povray.org>
>> DDS only goes up to a maximum of 80 GB. My server holds 103 GB.
> Sorry. Something looks wrong in these numbers. 103 GB? You don't mean
> 103T?  I can't even go to the store and buy a hard drive that small,
> unless it's a laptop hard drive. You could mirror the whole drive every
> day of the week for about $500.
Yes, 103 GB. That's 4 drives holding 36 GB each in a RAID-5 array.
Hence, effectively 3 x 36 GB. (Windoze reports it as 103 GB. I guess the
drives aren't exactly 36.0 GB or something.)
Given that we have 103 GB and it's about 20% full so far, what in the
name of God would we need 103,000 GB for? And last time I checked, SCSI
drives are [still] damn expensive. Sure, you could probably get a 300 GB
I guess we *could* back up to a hard drive. But I'm not really that keen
on the idea. We would have to shut the server down to connect the drive,
start it back up again, format the drive, copy all the data, somehow
verify the data, shut the server down, disconnect the drive, put it
somewhere safe, and start up the server again. Every single night. No
thanks...
I don't have any hard evidence to back this up, but isn't power-on the
most common time for a HD to fail? (Rather like lightbulbs.) Wouldn't
the constant cycling tend to wear them down? Hmm, mind you, I guess it's
no worse than all the other PCs here that get switched on each morning...
The other small problem is that 30 harddrives presumably take up
slightly more space than 30 DDS tapes. ;-)
http://blog.orphi.me.uk/
Subject: Re: Backup
Date: 19 Mar 2008 04:58:40
Message: <47e0e3d0$1@news.povray.org>
>> What do you use to back up data? I'm not talking about permanent
>> archival, I'm talking about rolling backups so that if a small
>> meteorite hits your server room, you don't loose all the data you're
>> working on.
> At work? LTO-II with robotic library capable of 14 tapes.
Yeah, looks like we'll be getting an LTO-I robotic library (8 tapes?)
I guess I should go look up prices for LTO tapes...
Subject: Re: Backup
Date: 19 Mar 2008 06:10:56
Message: <47e0f4c0$1@news.povray.org>
So your 80GB tapes should be fine for a while yet then???
Subject: Re: Backup
Date: 19 Mar 2008 06:27:56
Message: <47e0f8bc@news.povray.org>
...except that my tapes are 36 GB?
Subject: Re: Backup
Date: 19 Mar 2008 07:14:39
Message: <47e103af$1@news.povray.org>
Oh sorry I thought you meant the maximum size tapes your system could take
was 80 GB.
Even so, if you're using 20GB of data, surely that fits onto a 36 GB tape ok
with plenty of room for expansion over the next months/years?
Subject: Re: Backup
Date: 19 Mar 2008 07:24:19
Message: <47e105f3$1@news.povray.org>
> thanks...
This is a pretty narrow view of what can be done with a HD for a backup.
USB, Firewire, hot-swap bays, hot-swap raid enclosures, etc....
All of which don't present the problem that you describe.
Backing up to a HD is not ideal for most situations.
I'm not going to try to persuade you to do it.
It comes with its own problems that other media doesn't have.
It isn't mainstream.
That depends on your backup strategy.  If it requires 30 separate media,
then yes, storage space can be a premium.  Just tuck one or two near QA
girls desk and say 'hi' each time you get one ;-)
Tom
Subject: Re: Backup
Date: 19 Mar 2008 07:32:10
Message: <47e107ca@news.povray.org>
Right. I'm sold!
Subject: Re: Backup
Date: 19 Mar 2008 07:34:22
Message: <47e1084e$1@news.povray.org>
> take was 80 GB.
Not quite, no. The maximum tape size our system can take is 36 GB. The
next model up will handle 80 GB, and there *is* no higher model after
that. So I think we need to move to another technology.
> tape ok with plenty of room for expansion over the next months/years?
And in other news, I CAN'T DO MENTAL ARITHMETIC! >_<
(I have 59 GB of data to back up. Obviously this doesn't fit on a 36 GB
tape. Although to the system's credit, with the compression it does it
actually *almost* fits... But when we get to the point where we're using
nearly 103 GB of storage, we don't want to be using 36 GB or even 80 GB
tapes, ideally.)
Subject: Re: Backup
Date: 19 Mar 2008 11:13:05
Message: <47e13b91$1@news.povray.org>
USB.  Or, apparently, something called "eSata" now?
Oh, is your machine back in the prehistoric pre-USB era still? So buy a
$200 desktop machine that *does* have USB, put XP on it or something,
and back it up over the network.
Format it once, yes.
> copy all the data, somehow verify the data,
They call that "the backup program".
Once a day is "constant"?  Besides, it's your backup drive. Buy two.
Switch back and forth between them. When one fails, buy another.
Well, yeah, but they also last a lot longer, I expect.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Subject: Re: Backup
Date: 19 Mar 2008 11:33:11
Message: <47e14047$1@news.povray.org>
>> media, then yes, storage space can be a premium.  Just tuck one or two
>> near QA girls desk and say 'hi' each time you get one ;-)
> Right. I'm sold!
you can also do this with the tapes - your shelf just can't hold them all.
