POV-Ray : Newsgroups : povray.off-topic : Smart little programming tricks, where to find ? Server Time
28 Jun 2026 21:04:19 EDT (-0400)
  Smart little programming tricks, where to find ? (Message 31 to 40 of 51)
Subject: Re: Smart little programming tricks, where to find ?
Date: 19 Mar 2008 18:24:48
Message: <47e1a0c0$1@news.povray.org>
Warp escribió:
> Nicolas Alvarez <nic### [at] gmailisthebestcom> wrote:
>> Ahh, then I can say I did figure out both.
>   Ok, if you want a harder puzzle, here's a curious quirk about C++ (not
> related to memory leaks, though):
> #include <map>
> struct A { int i; };
> struct Comp
> { bool operator()(const A& a1, const A& a2) const { return a1.i < a2.i; }
> int main()
>     std::map<A, int, Comp> theMap(Comp());
>     A a = { 1 };
>     theMap[a] = 5;
Hrm, I never used map myself. I think I'll go search documentation on
what the template parameters are.
> a) This doesn't compile. Without using a compiler, can you tell where
>    is the problem and what is the exact reason why it doesn't compile?
> b) If you can't see it, try it with a compiler. I bet you still can't see
>    the problem... :P
> c) In the erroneous line, can you tell me exactly what that line means?
> d) What is the easiest way (smallest amount of extra code) to make it
>    compile and work as expected?
Oh I think I know. I took a while without noticing anything wrong, but
now I remember having read about it in C++ FAQ Lite. theMap(Comp())
*declares a function* instead of instantiating an object. Good to know
all the time I wast^H^H^H^H spent reading that website was actually useful.
Okay, *after* remembering that and writing that paragraph, I went and
searched for what I remembered having read. Maybe that counts as
cheating... I wouldn't have searched if I had read question D before, so
I could try figuring out the solution myself :)
http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.2
The solution is:
std::map<A, int, Comp> theMap = Comp();
Date: 19 Mar 2008 18:52:53
Message: <47e1a755$1@news.povray.org>
Say I wrote
int** foo = NULL;
int nx = 22, ny = 17;
void matrixfunc(){
  foo = new int*[nx];
  for (int x = 0; x < nx; x++)
   foo[x] = new int[ny];
and called matrixfunc();, but before I could delete it
  delete[] foo[x];
  delete[] foo;
  foo = NULL;
the code crashed. Do I have a memory leak?
Sam
Date: 19 Mar 2008 19:10:55
Message: <op.t8af4hfr7bxctx@e6600>
On Thu, 20 Mar 2008 00:52:55 +0100, stbenge <stb### [at] hotmailcom> wrote:
> Say I wrote
> int** foo = NULL;
> void matrixfunc(){
>   foo = new int*[nx];
Much better to use std::vector instead. Avoid raw pointers like the
plague; it will save you many headaches.
>   delete[] foo[x];
>   delete[] foo;
>   foo = NULL;
If by "crash" you mean unexpected program termination, then not really
(not because of the crash anyway). Any modern desktop OS will reclaim th
e
resources held by a program when said program terminates.
FE
Date: 19 Mar 2008 22:02:36
Message: <47e1d3cc@news.povray.org>
Warp wrote:
>   (OTOH, one could argue that understanding "0 < money" becomes easy when
> you use it a lot...)
Yes, it takes practice.
>   The form you suggest becomes a bit counter-productive when the expression
> is not a pure "between x and y", like for example:
> if(10 < money*money && money*12 < 100)
>   Now it becomes much harder to understand quickly what's going on.
If money squared is more than ten or money times twelve is less than a
hundred.  Makes sense to me. :-)  But then, I'm used to it.
I've noticed since this came up that I'll even do things like
   if (i > 0^H^H^H^H^H0 < i) ....
>   In most cases the compiler will issue a warning anyways if you make
> the mistake. Never been a problem to me.
It depends on the language, and the compiler.  A lot of embedded
compilers aren't too smart, and a lot of languages that adopted C syntax
(PHP, Java, etc) aren't too smart about that too.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 19 Mar 2008 22:07:01
Message: <47e1d4d5$1@news.povray.org>
Invisible wrote:
>>> But alas, it's not purely functional,
>> Yeah. I don't think you could get a real distributed language with
>> everything being truly functional, could you?
> Um... why?
Because it's nondeterministic? It's I/O driven? It's asynchronous?
I mean, to the extent that you think a tail-recursive function accepting
asynchronous messages and sending asynchronous messages in return can be
"functional," then it looks like Erlang is functional.
>> I mean, what's the functional equivalent of "the machine running the
>> calculation just burst into flames"? :-)
> Throwing an exception, as a guess. Like a division by zero error, but
> less deterministic. (??!?!) ;-)
Who throws the exception? The machine running the calculation isn't in
any shape to do so.
>> What's the functional equivalent of "we've just released a new version
>> of this function"?
> Now that's an interesting question...
Let me know when you figure it out. ;-)
>>> and the general style just seemed untidy and complicated. It's just
>>> not my cup of tea...
>> Yep. Altho the language itself seems pretty simple and straightforward,
> If by "simple and straight forward" you mean "assumes referential
> transparency but doesn't actually enforce it or make any attempt to
> check that it's there", then sure. Go knock yourself out. ;-)
Where do you think it doesn't assume referential transparency?
By "simple and straightforward" I meant in the sense that there are
relatively few types and primitives and interactions between them. More
like Tcl or C than Ada or C++.
> Gotta love documentation where you can't figure out what order to read
> it in...
It's not unusual. It's how I learned most of the languages I know. But
then, most of the languages I learned that way didn't have 1500+ pages
of documentation for the libraries. :-)  A two-pass read of the library
docs is going to take a while.
Date: 19 Mar 2008 22:09:38
Message: <47e1d572@news.povray.org>
>> What's wrong with C++?
>   Some people don't like the fact that memory management requires great care.
My understanding is that there are piles and piles of gotchas you have
to learn about before you can make reliable programs, even if you stay
within the definition of the language and don't start doing threads or
dynamic code loading or things like that.
With C, for example, there are only a handful of gotchas you have to
learn about. Stuff like "don't run off allocated memory", "don't fail to
declare types of function arguments and returns", "make sure your
definitions match your declarations", "put parens around your macros", etc.
Date: 20 Mar 2008 03:41:51
Message: <47e2234f@news.povray.org>
Vincent Le Chevalier <gal### [at] libertyallsurfspamfr> wrote:
> Replacing
> with
>      Comp c; std::map<A, int, Comp> theMap(c);
  That's not the shortest possible solution.
> A trouble with references or some such ? That prevents the full
> instanciation of the map template ?
  No.
Date: 20 Mar 2008 03:45:39
Message: <47e22433@news.povray.org>
  But why? Doesn't "Comp()" create an object? How can you declare a function
with an object (instead of a type)?
  What kind of function? What does it return? Does it take parameters?
What is the type of those parameters?
> The solution is:
  Alternatively you can do:
std::map<A, int, Comp> theMap((Comp()));
(which would be necessary if the map constructor took more than one such
parameter...)
Date: 20 Mar 2008 03:48:12
Message: <47e224cc@news.povray.org>
> > Say I wrote
> > int** foo = NULL;
> > void matrixfunc(){
> >   foo = new int*[nx];
  Yeah. You can do that with a one-liner:
std::vector<std::vector<int> > foo(nx, std::vector<int>(ny));
  And you don't have to delete anything.
Date: 20 Mar 2008 05:29:15
Message: <47e23c7b$1@news.povray.org>
>> Um... why?
Haskell supports random number generators. And I/O. And asynchronous
exceptions. It just cleanly seperates what *is* deterministic from what
is *not*, that's all. ;-)
> any shape to do so.
I would presume the exception is just thrown to whoever is waiting for
the answer?
>>> version of this function"?
To be honest, I'm not really seeing a clean way to handle this in *any*
language, but I haven't thought about it for that long yet.
Please reparse my sentence. I said it *does* assume referential
transparency yet does nothing to *enforce* or even *check* for it.
In other words, if you're not careful, you can easily cause the system
to massively malfunction with a few incautiously chosen commands.
I consider Haskell to be quite simple in this respect too. Until you
start digging things up out of the standard libraries, the language
itself gives you lists, tuples, integers, reals, booleans, characters,
and that's more or less it. And the language is nearly devoid of
keywords. (Decide for yourself if that's good or bad.)
>> it in...
I'm looking at you, Oracle. Trying to figure out where to start reading
to actually comprehend this stuff is *far* too hard!
It's not that Oracle is hard to understand - just that the [multiple]
manuals explain it quite poorly.
http://blog.orphi.me.uk/
