POV-Ray : Newsgroups : povray.off-topic : USB Input device disabling Windows power management Server Time
2 Mar 2026 05:57:02 EST (-0500)
  USB Input device disabling Windows power management (Message 1 to 10 of 12)
Subject: USB Input device disabling Windows power management
Date: 9 Mar 2008 01:45:07
Message: <47d38773$1@news.povray.org>
Long title, but it pretty much says it all.
I have a USB input device, a game controller.  When this is plugged in,
my monitor never gets turned off by the Windows power management (the
hard drives, however, spin down as they should, so the problem is only
limited to the display).
Unplugging the device (inconvenient, as I only have rear USB ports)
makes everything work as it should.
This is a major inconvenience, as I often leave my computer on for long
periods of time, and I like having my monitor turn itself off to save power.
Does anyone have an idea of how to get around this?
...Ben Chambers
www.pacificwebguy.com
PS Yes, I've tried Google.  Nothing came up that looked useful (mostly
just reviews for the game controller I'm using).
PPS Yes, I know that I can unplug the controller.  I'm looking for a
method of making the Windows power management behave as it should, not a
way to work around it.
PPPS Yes, I know I can manually turn the monitor on and off.  See PPS,
above.
Subject: Re: USB Input device disabling Windows power management
Date: 9 Mar 2008 03:32:06
Message: <n287t3hohqo115ufume79itp2qbme9pu14@4ax.com>
On Sat, 08 Mar 2008 22:44:54 -0800, Chambers <ben### [at] pacificwebguycom> wrote:
Press the power button on the monitor when you go away
Regards
Date: 9 Mar 2008 04:13:49
Message: <47d3aa4d@news.povray.org>
Have you tried reconfiguring the power saving settings while the
controller is connected?
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 9 Mar 2008 04:39:02
Message: <op.t7qs3dbs7bxctx@e6600.bredbandsbolaget.se>
On Sun, 09 Mar 2008 07:44:54 +0100, Chambers <ben### [at] pacificwebguycom> wrote:
It is possible that the device prevents the system from entering a reduced
power state, in which case the problem is not limited to just the display.
Note that the hard drives are controlled by separate timers.
One thing to try is updating to newer drivers (if available), both for the
device itself and for the USB controller (i.e. chipset drivers).
If on Vista, make sure to enable "USB selective suspend" in the power
management options.
If on XP, there is a hotfix that may or may not help.
http://support.microsoft.com/kb/918005
FE
Date: 9 Mar 2008 05:27:44
Message: <47d3bb9f@news.povray.org>
> ...Ben Chambers
> above.
  It's a bad idea to put relevant information *after* your signature.
  Many newsreaders will color signatures differently from the rest of
the post, and this causes natural signature blindness to people, and
they will miss your relevant info.
Date: 9 Mar 2008 11:35:57
Message: <47d411ed$1@news.povray.org>
That saves much more power than letting it turn off automatically.
However, see PPPS on his post.
Date: 9 Mar 2008 13:00:06
Message: <47d425a6@news.povray.org>
 > I'm looking for a method of making the Windows
 > power management behave as it should, not a way
 > to work around it.
If you find a way to make anything in Windows behave the way it should,
come back to us.  Inquiring minds want to know.
John
Date: 9 Mar 2008 13:56:34
Message: <47d432e2$1@news.povray.org>
>> in, my monitor never gets turned off by the Windows power management
>> (the hard drives, however, spin down as they should, so the problem is
>> only limited to the display).
> reduced power state, in which case the problem is not limited to just
> the display. Note that the hard drives are controlled by separate timers.
> the device itself and for the USB controller (i.e. chipset drivers).
> management options.
I tried the hotfix, and no go - it still won't sleep.  Thanks for the
tip, though.
...Ben Chambers
Date: 10 Mar 2008 06:50:43
Message: <op.t7stvwtwc3xi7v@news.povray.org>
And lo on Sun, 09 Mar 2008 06:44:54 -0000, Chambers
<ben### [at] pacificwebguycom> did spake, saying:
> power.
If you're using Vista there's a known problem with some wireless USB
devices disabling the screensaver (and by extension perhaps the power
saving) http://support.microsoft.com/kb/911895 had the same thing happen
on a laptop and after a couple of reboots seems to be working properly
now. Might be worth a try. Oh and the device needs to be plugged in before
it shows up in the Update screen.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 11 Mar 2008 14:58:40
Message: <47d6e470@news.povray.org>
It is behaving as it should. The game controller device driver is
telling Windows not to stop supplying power to it. So Windows does what
it should.
Now, if the game controller doesn't have problems with going into
low-power mode, then it should let Windows do that. Blame the controller.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
