POV-Ray : Newsgroups : povray.off-topic : Using Excel as a 3D engine Server Time
17 May 2026 01:56:50 EDT (-0400)
  Using Excel as a 3D engine (Message 21 to 30 of 45)
Subject: Re: Using Excel as a 3D engine
Date: 12 Mar 2008 06:23:57
Message: <47d7bd4d@news.povray.org>
>>>> in VBA you'd have to write an explicit FOR loop
>>> Not in Excel. What are you smoking? :-)
>> Really? Care to explain that one?
> Off the top of my head:
> =product(range)^(1/count(range))
> ...unless there is some geometric mean function, I didn't search for one.
Ah. In other words, "you don't need to code this because it's already
pre-defined".
Or, to put it another way, I picked a bad example. ;-)
http://blog.orphi.me.uk/
Date: 12 Mar 2008 07:45:08
Message: <47d7d054$1@news.povray.org>
> pre-defined".
Or, a lot of what you might want to do in a spreadsheet is pre-defined :-)
Date: 12 Mar 2008 07:56:47
Message: <47d7d30f$1@news.povray.org>
Or, I use a spreadsheet in a way that's very different to how normal
people use them.
(E.g., Excel doesn't provide a "convolution" function. And it would be
far too hard to implement one in VBA. Not because the algorithm is hard,
but because I'd have to figure out how to access the cells of the
spreadsheet...)
I tend to use Excel as a function plotter - and it's annoying that
things like an FFT are so hard to do.
Date: 12 Mar 2008 08:26:43
Message: <47d7da13@news.povray.org>
47d7d30f$1@news.povray.org...
> I tend to use Excel as a function plotter - and it's annoying that things
The built-in FFT in Excel doesn't work?
In any case, accessing cells with VBA is basic. Just start recording a macro
and put something in a cell to see how it's done.
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer images
- Posters
Date: 12 Mar 2008 08:37:41
Message: <47d7dca5@news.povray.org>
> spreadsheet...)
Oh my God.
Date: 12 Mar 2008 08:50:44
Message: <47d7dfb4$1@news.povray.org>
scott wrote:
>> Not because the algorithm is hard, but because I'd have to figure out
>> how to access the cells of the spreadsheet...)
> Oh my God.
I know...
What can I say? VB isn't exactly the easiest programming language ever.
And this stuff isn't really documented anywhere. (Sure, there's an
online help system that will tell you what function X does. But if you
don't know the name of the function you need... that's not much help.)
Now you see why it took me several hours to write a VB macro that puts
today's date into a particular cell?
Date: 12 Mar 2008 08:52:09
Message: <47d7e009$1@news.povray.org>
Excell has an FFT? Since when? (Or is it in one of the non-default add-ins?)
I didn't realise that uses VB. Oh, wait, I'm thinking about Access...
Date: 12 Mar 2008 09:09:16
Message: <47d7e40c$1@news.povray.org>
Rubbish!
Try looking up "range" or "cells" or "worksheet" in the object browser and
reading the help.  It even gives examples, like (these are from the help on
the "range" keyword, the others are similar):
Worksheets("Sheet1").Range("A5").Value =
Worksheets("Sheet1").Range("A1").Value
Worksheets("Sheet1").Activate
Range("A1:H8").Formula = "=Rand()"    'Range is on the active sheet
Worksheets(1).Cells(1, 1).Value = 24
ActiveSheet.Cells(2, 1).Formula = "=Sum(B1:B5)"
How could it be any more clear what to do?  Or, as Gilles said, record a
macro and then look at the code (and the help related to the code
generated) - a nice trick for learning how to do lots of things in Excel
(like creating charts, changing borders, sorting etc).
Date: 12 Mar 2008 09:31:03
Message: <47d7e927$1@news.povray.org>
47d7e009$1@news.povray.org...
> add-ins?)
It's in the Analysis Toolpak which is not turned on by default (but just a
checkbox away).
http://www.maxim-ic.com/appnotes.cfm/an_pk/3292
It's been there for years I believe (the Analysis Toolpak has been there
since Excel 95 at least, I'm not sure about FFT itself).
I don't understand what you're saying... The entire Office suite uses VBA.
Actually that's one big selling point of Office (for businesses): one can
automate all the Office applications using the same language and have them
interact with each other.
G.
- Posters
Date: 12 Mar 2008 09:38:34
Message: <47d7eaea$1@news.povray.org>
>> add-ins?)
> checkbox away).
Ah, right. I don't think I have that installed... (But as you say,
that's not hard to fix.)
I hope it's less clunky than that hacked-in complex number "support"
Excell has though.
Yes. But Access has an additional "macro language" that only Access
uses. By default it seems to record macros with that.
Heh. I'm *so* not trying that... ;-)
