POV-Ray : Newsgroups : povray.off-topic : A small project Server Time
2 Jul 2026 13:46:39 EDT (-0400)
  A small project (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: A small project
Date: 4 Mar 2008 09:24:53
Message: <47cd5bb5@news.povray.org>
Mike Raiford wrote:
> This, too if you'd prefer to use VB or C#:
> http://msdn2.microsoft.com/en-us/library/system.windows.forms.notifyicon.aspx
Dang, you beat me to it!
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 4 Mar 2008 09:27:30
Message: <47cd5c52$1@news.povray.org>
Sherry Shaw wrote:
> (I'm using Visual Studio 2005 Pro...don't know if there's any difference
> in the Express version or not.)
AFAIK, Pro and Express are identical in this regard.
Date: 4 Mar 2008 16:34:21
Message: <47cdc05d@news.povray.org>
Invisible wrote:
> I want to write a small program that will display a status icon in the
> system tray and pop up small messages in the corner of the screen. [It
> is critical that these do *not* take the input focus. Can you imagine
> how *annoying* that would be?]
Unfortunately, it is difficult to write a Windows program that is not
annoying.
John
Date: 4 Mar 2008 22:55:37
Message: <47ce19b9@news.povray.org>
Invisible wrote:
> Any suggestions as to how to pull this off? Personally I don't know of a
> programming language that makes it easy to do this kind of thing.
Tcl.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 4 Mar 2008 23:47:16
Message: <47ce25d4$1@news.povray.org>
Tcl. More specifically....
http://tktable.sourceforge.net/winico/winico.html
Date: 19 Mar 2008 08:56:24
Message: <47e11b88$1@news.povray.org>
I had a feeling you'd say that.
It looks like I can use this to put an icon with a tooltip in the
taskbar. I was kind of hoping to be able to pop up small messages as
well, but I guess that isn't critical.
Apparently the latest version of Freewrap includes this extension, and
it does seem to work. I'm not very confortable with using an unreliable
language like Tcl, but there doesn't appear to be a lot of option...
http://blog.orphi.me.uk/
Date: 19 Mar 2008 10:41:25
Message: <47e13425$1@news.povray.org>
Hey, Tcl does just about everything. That's why I like it.
You can do that. You don't need this extension for it. Use "wm
OVERRIDE_REDIRECT" or some such on your window, and you won't get a
border or close buttons, so you just position it in the corner and draw
into it.
What's unreliable about it? I've very rarely had a problem with anything
not working as specified. Indeed, I've been using it for 13 years and
only found two rather obscure bugs.
If you mean "it doesn't work as I expect" (e.g., things complaining
about malformed lists), post your code and I'm happy to show you how to
do it reliably.
Date: 19 Mar 2008 11:56:45
Message: <47e145cd$1@news.povray.org>
Well, it does a few things that are useful. (E.g., it's one of the few
portable languages that lets you access Windoze-specific file attributes.)
> into it.
And how the heck do I figure out *where* the corner of the screen is?
(And, for that matter, avoid stealing the input focus when the window
opens?)
> do it reliably.
It's a scripting language. It doesn't really "do" error-handling. If
something goes wrong, the script tends to just choke in an unpredictable
way.
Many of the Tcl scripts I run seem to leak memory pretty badly. I did
have a Tcl script that did something every 5 minutes - but I discovered
that the longer it runs, the more RAM it eats. I now rerun the script
every 5 minutes using an external tool.
There are many, *many* things that work unexpectedly in Tcl. But then,
the language isn't really set up for making production-grade
applications, it's designed for quickly throwing things together that
work on the day you test them.
The list goes on...
Date: 19 Mar 2008 21:03:45
Message: <47e1c601$1@news.povray.org>
I would ask for the coords of the window in the system tray and go from
there? I haven't done it, but it can't be all that hard. I'm almost
certain you can get the screen size in pixels from Tcl.
Now, that's assuming you only have one screen.
To answer your question precisely, "winfo screenheight" and "winfo
screenwidth" are what you're looking for, I think. "winfo" and "wm"
control all that sort of stuff. (WM referring to the window manager, so
it controls borders and focus and such. The documentation doesn't
clarify for me how to avoid taking focus when you create a window.)
> opens?)
I think Windows prevents this from happening in the first place in
general, but that's a good question.
> way.
No. You're thinking of C. Tcl chokes in very predictable ways. Indeed,
at work, I use a Tcl monitoring process to restart all the craptastic
C++ stuff that dumps core about once a week.  (Not that C++ is
necessarily craptastic, but this stuff is.)
Between [catch] and [bgerror], Tcl should never do something
unpredictable. Maybe you don't know how Tcl behaves, but it really is
well-defined.
I have Tcl programs that run literally months without being touched. If
you're leaking memory, it's because you're storing stuff in globals and
not cleaning up after yourself.
Granted, there is occasionally a leak in Tcl's memory handling described
in the bug tracker. But it's rare, and they're all high priority to get
fixed because people build real systems with Tcl.
Tcl doesn't always dispose of the maximum amount of memory it can, but
if you free something up after allocating it, that memory does get reused.
I disagree. I've written all kinds of server stuff in Tcl that runs for
months without being touched, that automatically recovers from my
mistakes, and so on. If you can't get it to work for you, it's because
you don't know how, methinks.
Date: 20 Mar 2008 05:59:10
Message: <47e2437e$1@news.povray.org>
Right. And now how do I figure out how big the system tray is? (You
realise it's resizable, right?)
That's a safe assumption for the purposes of this project. ;-)
I find the documentation for Tcl/Tk to be especially difficult to
follow. For example, I *still* can't figure out the correct way to
specify a font name. The page that's meant to tell you just rambles on
about a bunch of C functions... WTF?
>> opens?)
I'll check later...
>> unpredictable way.
Right. So when the server runs out of disk space, my Tcl script
unceremoniously halts, and rather than the interpretter shutting down,
it just *sits* there. And since it's a background task, I have *no way*
of discovering what the hell went wrong, and no way of shutting it down
other than forcably killing the interpretter. Cool. Is that what the
spec says?
> well-defined.
Frobbing bgerror is just painful. catch looks more useful...
>> discovered that the longer it runs, the more RAM it eats. I now rerun
>> the script every 5 minutes using an external tool.
No, not really. Just recursing over some directories. Memory usage
starts at about 2 MB, and grows linearly by about 50 KB every second.
Usually the script finishes before it actually reaches more than 8 MB,
but on occasion it doesn't.
How would I know about that? I downloaded Freewrap a few years back and
have been using it ever since. Still on the same version number.
So... you're saying that my particular Tcl interpretter just has a
memory bug in it?
The whole "hey, let's not bother with datatypes and stuff, let's just
store everything as flat strings and reparse them every time we need to
touch something" concept simply *wreaks* of quick and dirty prototyping.
No sane person would design production-grade software this way, with no
safety checks or anything.
