POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
26 Jun 2026 05:23:03 EDT (-0400)
  Adventures with digital painting (Message 8 to 17 of 197)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Adventures with digital painting
Date: 4 Mar 2008 08:05:56
Message: <89iqs3haj78uccp3k2evnl2e4l869939d4@4ax.com>
On Tue, 04 Mar 2008 12:52:30 +0000, Invisible <voi### [at] devnull> wrote:
>Um... how do you fill in a shape if it's in another layer?
You can create a mask from the layer that you use as a reference, save it and
import it into the fill layer. Masks are good tools as well they limit the
drawing area for you.
Regards
Date: 4 Mar 2008 11:15:18
Message: <47cd7596@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47cd1a79$1@news.povray.org...
> The problem basically seems to boil down to the fact that it is
> virtually impossible to draw with a mouse. Drawing with the GIMP, all
> the lines come out horribly wobbly. PhotoShop seems to smooth the mouse
> input somewhat, so lines come out less wiggly.
> But even so, no matter what software I use, if you move the mouse in a
> circle, it draws a square with rounded corners. It seems the mouse is
> very keen to move in the horizontal and vertical directions, and resists
> moving in any other directions. Very irritating...
Get a better mouse. I can draw reasonably well with mine (Logitach laser
mouse), though I still prefer the tablet if I'm doing anything more than a
couple minutes fiddle.
Date: 4 Mar 2008 14:52:21
Message: <47cda875$1@news.povray.org>
>> resists moving in any other directions. Very irritating...
> Try turning off mouse pointer acceleration in control panel (I think
> it's called "Enhance Pointer Precision" now) - the algorithms used in
> Windows are quite complex to make the mouse move around in a "natural"
> way, but are useless if you're trying to draw something carefully.
> Turning off acceleration makes it a linear relation between mouse
> movement and pointer movement.
Thanks for the tip. Doing this does result in a small increase in
controllability, but not very much. It's still infuriatingly hard to
draw anything half-decent. (And it makes the mouse rather slow and
unresponsive when you're just trying to work Windoze. So I'll probably
leave it how it was.)
It seems clear to me now that I need a decent input device if I'm
remotely serious about this course of action.
http://blog.orphi.me.uk/
Date: 4 Mar 2008 16:18:20
Message: <47cdbc9c$1@news.povray.org>
Gilles Tran wrote:
> The "You suck at Photoshop" series is both useful and funny (and sad...).
Phaaahahahahahaaaaaa...! WTF?!
Date: 5 Mar 2008 02:00:52
Message: <47ce4524@news.povray.org>
Invisible wrote:
> I didn't get very far with the GIMP. The extreme uncontrollability of
> the lines made me give up rather quickly. PhotoShop seems much better in
> this regard, although I still couldn't get decent curves out of the
> cheap optical mouse.
I know a way to smooth jagged lines in the GIMP.
1) Draw your line in black and white.
2) Apply gaussian blur with a largish radius (10-40).
3) Choose 'curves' from Layer>Colors>Curves and squeeze the black near
the white to constrain the curve (but keep each at their respective y
positions).
You should be left with much smoother lines, but intersecting areas will
appear slightly 'blobbed'.
I know a way to fill antialiased areas with perfect fills and paints.
1) Select an area to fill with the magic wand tool.
2) Go to Select>Grow and grow selection by 1 or 2 pixels.
3) If
   3.1) Area is white:
     Select blending mode 'multiply' for your paint tool
   3.2) Area is colored:
     Select blending mode (edit) 'Overlay' for your paint tool and choose
white for your color. Paint until the area is white again.
Sam
Date: 5 Mar 2008 03:04:02
Message: <47ce53f2@news.povray.org>
stbenge <stb### [at] hotmailcom> wrote:
> 3) If
>    3.1) Area is white:
  Of you could simply use the selection in a lower layer and flood-fill
the selection there.
Date: 6 Mar 2008 05:54:43
Message: <47cfcd73@news.povray.org>
Wanna hear something really random? I just checked out Adobe's online store.
So... wait... it's *cheaper* to buy Elements and upgrade to CS than to
just purchase CS??
Also, it turns out there's a CS3 Extended. (Has some extra 3D stuff.
Apparently.)
[The other random thing is that if you look on Apple's online store,
everything is more expensive than from any other source. Which makes no
sense at all. On the other hand, prices on the Adobe online store seem
to be quite a bit lower than anywhere else, so...]
Date: 6 Mar 2008 06:05:48
Message: <47cfd00c@news.povray.org>
> On the other hand, prices on the Adobe online store seem to be quite a bit
You're just not looking in the right places...
Date: 6 Mar 2008 06:32:10
Message: <47cfd63a$1@news.povray.org>
from Adobe appears to be quite a bit cheaper. ;-)
Date: 6 Mar 2008 06:52:02
Message: <47cfdae2@news.povray.org>
  Maybe you should try cheaper software first, to get experience and to
see that you indeed are interested in that kind of hobby, before spending
such vast amounts of money on software you will not use.
  It's not like CS3 will somehow magically make drawing easier. It still
requires experience and hard work.
