POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
31 May 2026 23:30:41 EDT (-0400)
  Adventures with digital painting (Message 161 to 170 of 197)
Subject: Re: Adventures with digital painting
Date: 13 Mar 2008 04:28:04
Message: <47d8f3a4$1@news.povray.org>
>> Tcl encodes all data types as strings. I've been bitten by this
>> before... You write a Tcl script, it works fine, and then it encounters
>> some input that happens to contain a curly-bracket or a dollar sign and
>> Weird Crap happens...
> That's one of the potential pitfalls with most scripting languages.
Now you know why I dislike scripting languages in general. ;-)
http://blog.orphi.me.uk/
Date: 13 Mar 2008 09:39:51
Message: <47d93cb7@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Autoconf doesn't make C portable
  It only makes the C program to compile and work in a multitude of
different architectures. Yeah, it doesn't make it portable, only portable.
Date: 13 Mar 2008 14:48:17
Message: <47d98501$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:47d6ca98@news.povray.org...
> Again, I tend to work with tens of thousands of files at once.
      Tens of THOUSANDS?? I'm not that shocked at what a programmer can do,
but fair play for handling that.
       ~Steve~
>   Darren New / San Diego, CA, USA (PST)
>     "That's pretty. Where's that?"
>          "It's the Age of Channelwood."
>     "We should go there on vacation some time."
Date: 13 Mar 2008 16:32:38
Message: <47d99d76$1@news.povray.org>
Yeah. A couple weeks of raw audio, in 20-second chunks. Sadly, we throw
most of it away. :-)
Date: 13 Mar 2008 16:34:43
Message: <47d99df3$1@news.povray.org>
Invisible wrote:
> I'm pretty sure I remember several occasions where if a certain
> expression happened to return only 1 item, it tried to interpret the
> item as a list. IOW, when the expression finds multiple matches,
> everything works fine, but when it finds exactly 1 match it malfunctions
> horribly. Took me ages to figure out why...
You would need to either return a list, or return one item. If you want
to return either, you need to return a list of one item. Otherwise, yes,
if you sometimes return a list, and sometimes return one item that looks
like a malformed list, then you're going to confuse yourself.
if {$count > 1} {return $a}
if {$count == 1} {return [list $singleton]}
# Wrong:
# if {$count == 1} {return $singleton}
Date: 13 Mar 2008 16:35:45
Message: <47d99e31@news.povray.org>
> Eero Ahonen wrote:
>> Well ok, after that you wrote about chopping the file, which
>> practically is what split does, but it should be able to work without
>> creating millions of (temp)files in the middle of the process.
> The problem is the size of the file. If I split it after the fact, I now
> have *two* files, the original and the new one. So now instead of half
> an hour of deleting directory entries, I have three hours of copying
> data, followed by five minutes of deleting one directory entry.
> Split doesn't split a file. It writes new files, each of which contain
> pieces of the previous file.
With dd you could copy any section of the file into a new one.
Date: 13 Mar 2008 16:48:30
Message: <47d9a12e$1@news.povray.org>
>> malfunctions horribly. Took me ages to figure out why...
If was more that I was processing a list, filtering out some of its
content, and if it turned out that the result was exactly 1 element the
script behaved in a different way than it did when the filtering yielded
several elements.
But anyway, why worry? Just stop using Tcl. ;-)
Date: 13 Mar 2008 16:54:38
Message: <47d9a29e@news.povray.org>
For some reason that reminded me of...
<FarSide> i had a guide that told u to put the 1.1.3 firmware file on
the touch
<Brethil> It will be way faster even if you decrypt it on your computer
and put the decrypted.dmg file on your iPod (should work, but I'm not
100% sure
<FarSide> then run the upgrade
<PovAddict> FarSide: I did that to save myself from a hour-long download
<PovAddict> but the iPod still did decryption, extraction, patching, etc
<FarSide> i chose the ron popeal method...set it and forget it
<FarSide> i just went to bed
<FarSide> lol
<PovAddict> okay, time to try this again
<PovAddict> ah wait... to copy the firmware I need ssh
<PovAddict> to install ssh I need BSD subsystem
<PovAddict> BSD subsystem messes with Cydia (which I haven't installed yet)
<FarSide> yup
<PovAddict> or, I could install Cydia and get saurik's ssh
<Brethil> you can also use iPHUC
<Brethil> to copy over usb
<FarSide> i just suggest suicide
<FarSide> a lot easier
<FarSide> lol
Date: 13 Mar 2008 17:45:16
Message: <47d9ae7c@news.povray.org>
But again, it would take a long time to copy that.  The point is to not
slog a half a terabyte of data from one disk to another in order to do
the processing.
It works out OK. It just takes surprisingly long. :-)  It's automated at
this point, unless I specifically take it off automation, so it's not
like I'm waiting for it. It just kind of surprised me that deleting a
big file could take over a minute. Must be the ext3 journaling or
something going on. Ext was never really optimized for big files.
Date: 13 Mar 2008 18:05:28
Message: <47d9b338$1@news.povray.org>
> the processing.
What do you do with the small section once you cut it? Can't you use
pipes to avoid so many temporary files?
