POV-Ray : Newsgroups : povray.off-topic : Question for SQLers out there Server Time
4 Jul 2026 06:41:50 EDT (-0400)
  Question for SQLers out there (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Question for SQLers out there
Date: 12 Feb 2008 11:03:23
Message: <47b1c34b@news.povray.org>
"Dan Byers" <goofygraffix_at_geemail_dot_com> wrote in message
news:web.47b1b9a1e388923da8d0b25a0@news.povray.org...
> Mike Raiford <mra### [at] hotmailcom> wrote:
> > But, frowned upon in the general sense?
> Actually, it's frowned upon where outer joins are concerned.  This is from
the
> online manual (SQL Server 2000 - I haven't checked SQL Server 2005 yet):
The older outer join syntax doesn't work at all in SQL 2005. Dunno about the
other DB engines.
(Does Oracle know what a join is yet?) <g>
This works in SQL 2005
SELECT tbl1.Col1, tbl2.col2 from tbl1 LEFT OUTER JOIN tbl2 on tbl1.Col1 =
tbl2.Col1
This doesn't
SELECT tbl1.Col1, tbl2.col2 from tbl1, tbl2 WHERE tbl1.Col1 *= tbl2.Col1
Date: 12 Feb 2008 11:07:33
Message: <47b1c445@news.povray.org>
> other DB engines.
I should probably poke you for that. :-P
Considering that I was playing with the different join types in an old
version of Oracle 6 years ago when I was still at uni, I think we can
safely say it knows about joins...
http://blog.orphi.me.uk/
Date: 12 Feb 2008 11:25:26
Message: <47b1c876$1@news.povray.org>
Gail Shaw wrote:
> This doesn't
Thank goodness they dropped the *= and =* operators.
Date: 12 Feb 2008 11:30:00
Message: <web.47b1c8f8e388923da8d0b25a0@news.povray.org>
> tbl2.Col1
> This doesn't
I remember the Delphi programmers here at work squawking about that.  They have
a lot of embedded SQL in their Delphi code that uses the old latter syntax, and
they had to go thru and fix it all.  I guess that's why they get paid the big
programmer bucks :)
Dan
GoofyGraffix.com
Date: 12 Feb 2008 11:42:59
Message: <47b1cc93$1@news.povray.org>
Tom Austin wrote:
> Should a JOIN be used here?
> Does it matter?
As I understand it, on any half-decent DB engine there shouldn't be any
performance difference. (The two are equivilent under the relational
algebra.) As for readability... well that's a whole other matter. You
might well argue that using the JOIN keyword makes the intent clearer.
It's a while since I've looked at this stuff seriously.
Date: 12 Feb 2008 11:55:09
Message: <47b1cf6d@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47b1c445@news.povray.org...
the
> > other DB engines.
Last time I used Oracle, it don't know what the JOIN keyword was. Sure, it
could do joins, but in the where clause.
A very quick google tells me that INNER JOIN/LEFT OUTER JOIN/RIGHT OUTER
JOIN became available in oracle in version 9i
In versions previous to that, joins had to be done in the where clause and
outer joins were specified using the *= or =* syntax.
Ref:
(http://www.kingtraining.com/confdownloads/downloads/Oracle9iJoin_paper.pdf)
Date: 12 Feb 2008 11:55:41
Message: <47b1cf8d@news.povray.org>
news:web.47b1c8f8e388923da8d0b25a0@news.povray.org...
have
syntax, and
big
> programmer bucks :)
Shame. I feel for them (not)
That's what they get for not using stored procedures.
Date: 12 Feb 2008 12:35:00
Message: <web.47b1d8a8e388923da8d0b25a0@news.povray.org>
In their defense, a lot of the code is for generating SQL on-the-fly for viewing
certain windows, screens, whatever, based on the user selecting certain options
in whichever screen they're using.  BTW we're talking about a telco billing
application with over 300 tables and a huge number of windows, screens,
dropdowns, etc., used to manage customers, billing, delinquencies, switch
activation, trouble tickets, external plant management (all the cables and
telephone poles -- the physical components that carry the phone/cable/internet
service to a house/business).  They do use a large number of stored procs for
the real heavy-lifting (I counted almost 700).
Dan
GoofyGraffix.com
Date: 12 Feb 2008 15:02:02
Message: <47b1fb3a$1@news.povray.org>
Gilles Tran wrote:
> 47b1a492$1@news.povray.org...
>> OK, I've heard a lot about inner joins and outer joins but don't really
>> know them or how to use them.
>> I've actually been using SQL for 10 years now, but never managed to
>> completely figure this out.
>> Lets say I have (2) tables - (2) column each
>> Person Limbs
>> Index Name PersonIndex Type
> I'd do it a little differently ;)
> Table:Persons
> Person_code
> Person_name
> Table:Limbs
> Limb_code
> Limb_type
> Table:Person_limbs
> Person_code
> Limb_code
> The Person_limbs table make it possible to give a person a variable list of
> limb types.
> Now you want to list the names of persons who have limbs of the type "legs"
> SELECT Person.Person_name
> FROM (Limbs INNER JOIN Person_limbs ON Limbs.Limb_code =
> Person_limbs.Limb_code) INNER JOIN Person ON Person_limbs.Person_code =
> Person.Person_code
> WHERE (((Limbs.Limb_name)="legs"));
> G.
Yes, you are right.
My example was not thought out to that degree.
It was only to get information on the JOIN functionality.
Thanks
Tom
Date: 12 Feb 2008 15:18:09
Message: <47b1ff01$1@news.povray.org>
> the
> other DB engines.
> tbl2.Col1
> This doesn't
will it work if you remove the '*'?
SELECT tbl1.Col1, tbl2.col2 from tbl1, tbl2 WHERE tbl1.Col1 = tbl2.Col1
Tom
