POV-Ray : Newsgroups : povray.off-topic : VS Express editions? Server Time
9 Jun 2026 11:17:12 EDT (-0400)
  VS Express editions? (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: VS Express editions?
Date: 30 Jan 2008 14:17:28
Message: <47a0cd48@news.povray.org>
> Anybody played with them. I realize there are relatively few on here who
> actually like MS products, but I want to hear other peoples opinions of
> MS's free versions of their dev tools.
I once tried it. Couldn't do anything useful with it during a whole
hour. I uninstalled it. Of course, despite recommendations made by
Microsoft itself to other developers, the uninstaller didn't remove
everything that was installed. I was months with lots of filetypes (like
.c) still associated to VS express.
I use gvim and a bash shell (yes, in Windows) for all my development
needs. Except for POV-Ray, where I use the internal editor, and for
Java, where I use Eclipse. MinGW as C compiler.
Date: 30 Jan 2008 14:18:46
Message: <47a0cd96@news.povray.org>
> Has some nice features. I sort of got forced into writing something for
> VC# express because a library supplied by a vendor was using generics,
> and we're still using ancient VS.NET. (Which is quite bug-ridden)
Ah, .not. I stay away from that. Even though some things look tempting.
But hey, Vista screenshots with Aero are tempting too (that's the whole
idea of marketing), and no way in hell I'll downgrade to it.
Date: 30 Jan 2008 14:32:49
Message: <47a0d0e1@news.povray.org>
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:47a0c3a7$1@news.povray.org...
I've used SQL Express, VS Express C# and web. They're fine for small
development projects. I wouldn't use them in a massive team on a large
commercial project, but for playing around or for smaller things, they're
fine.
Date: 30 Jan 2008 17:02:41
Message: <47a0f401@news.povray.org>
I installed VS C++ 2005, and immediately found that I could not set it
to assume that all strings were ASCII strings; I had to specifically
call the API function that is decorated with 'A' to specify that;
Bloodshed and OpenWatcom allow you to specify the string type with one
compiler setting, and the compiler automagically decorates them for you.
After editing all of the sources to put in what the compiler will not
let me assume, it then failed to recognize another API call during the
link phase.
I already have two C++ compilers that work just fine (Bloodshed and
OpenWatcom), so getting MS to work is just too much trouble.
John
Date: 30 Jan 2008 22:34:38
Message: <47a141ce@news.povray.org>
I used to like it, until I had a chance to see the professional version
in action.  For whatever reason, the free version is crippled beyond
belief, speed-wise.  It would literally take more than ten times as long
to open, load projects, or compile them.  The output would be identical,
though, so if you're OK with the wait, go for it.
...Ben Chambers
www.pacificwebguy.com
Date: 31 Jan 2008 00:40:15
Message: <47a15f3f$1@news.povray.org>
> fine.
What she said.  If it's a one-person project, it's sufficient.  Once you
start wanting source code control, automatic testing, etc., you'll want
the for-fee version. (Which, really, isn't that expensive. If your
employer can't afford a half-day of your pay to get you the tools you
need, you should be shopping your resume around.)
     On what day did God create the body thetans?
Date: 31 Jan 2008 04:34:36
Message: <47a1962c@news.povray.org>
  Really? There's a setting in the project properties for this.
Date: 31 Jan 2008 04:37:33
Message: <47a196dd@news.povray.org>
  Strange. I haven't noticed this. I have used both the express version
and the commercial one of VS 2005.
Date: 31 Jan 2008 04:45:58
Message: <47a198d6@news.povray.org>
  I have used it and it seems ok.
  Perhaps a bit strangely at least the express version is not a
"download, install, use" package. Besides downloading and installing
the express version, you have to separately download and install the
Windows Platform SDK and manually configure VS to use it (there doesn't
seem to be any way to make it automatically detect that you have the SDK
installed and to use it properly). If you do anything that needs DirectX,
you need to download and install the DirectX SDK and manually configure
VS to use it (again, it doesn't seem to detect this automatically). All
this can be a real pain, especially since it doesn't seem to be documented
anywhere. Without precise instructions on how to do this, it can be next
to impossible to figure it out.
  (I have only experience with VS 2005 Express. I don't know if they
have improved this with VS 2008.)
  Once you have succeeded in installing and configuring everything,
it seem to work ok, though.
Date: 31 Jan 2008 06:04:53
Message: <47a1ab55$1@news.povray.org>
I found this a little odd also. And a little frustrating, because my
experience with dev tools like this is *very* limited (i.e., this and
XCode), so I wasn't even sure if I was doing the right thing. In light
of Nicolas' post, this process took me rather longer than one hour, and
I hadn't even managed to compile anything yet. But, as you say, once
it's working, seems to be OK.
