POV-Ray : Newsgroups : povray.off-topic : Electric sheep Server Time
9 Jun 2026 12:43:32 EDT (-0400)
  Electric sheep (Message 21 to 30 of 65)
Subject: Re: More sheep
Date: 10 Jan 2008 11:36:29
Message: <4786498d$1@news.povray.org>
Invisible escribió:
> Nicolas Alvarez wrote:
 > > Note that morphs cannot be played backwards and make sense.
 > Yes they can. But MPEG-2 doesn't make that real easy...
I know MPEG doesn't make it easy, but they wouldn't make sense anyway-
Try it. Make a video of A, A, B->A backwards, B, B. See if the morph
looks OK.
>> A->B and B->A videos are different, so both are needed if you wanted
>> all possible combinations.
> They *can* be different, but no mathematical law that says they must be.
> (However, ES seems to implement it this way.)
In the way ES works, the loop is "rotating". The morph is interpolating
sheep A to sheep B and *also* rotating. If you play it backwards, it
would be rotating backwards, and the sudden jump in "direction" is
really noticeable.
Date: 10 Jan 2008 11:37:59
Message: <478649e7@news.povray.org>
> looks OK.
Actually, don't. I'll try to do it for you.
Date: 10 Jan 2008 11:38:23
Message: <478649ff$1@news.povray.org>
>> be. (However, ES seems to implement it this way.)
> really noticeable.
I see. So there's a discontinuity in the 1st derivative then? ;-)
http://blog.orphi.me.uk/
Subject: Re: Electric sheep
Date: 10 Jan 2008 11:41:36
Message: <47864ac0$1@news.povray.org>
> I used to, but stopped because the MPEG video showing at fullscreen
> (plus the fact that you may end up rendering frames for them) needs some
> CPU time.
<I'm old>
I can remember when decoding MPEG-1 in realtime required specialised
hardware - and encoding required a very high-end computer system!
And today, my PC is decoding MPEG-2 in realtime using idle CPU cycles...
How times have changed!
</I'm old>
Date: 10 Jan 2008 11:42:20
Message: <47864aec@news.povray.org>
On the What?
o_0
Date: 10 Jan 2008 11:55:46
Message: <47864e12$1@news.povray.org>
> On the What?
> o_0
Speed is the first derivating of position with respect to time.
In other words, the consecutive frames match, but the movement does not.
Date: 10 Jan 2008 13:24:12
Message: <478662cc$1@news.povray.org>
>> looks OK.
Isn't as noticeable as I expected (maybe it's because of the morph I
picked) but definitely there is a jump.
http://www.wikifortio.com/798356/test.mpg.zip (10MB)
Date: 10 Jan 2008 14:07:26
Message: <47866cee@news.povray.org>
Bah. I was out of grad school and people were still building and selling
hardware JPEG cards, let alone MPEG. :-)
The 6 minutes of mpeg we had to demo the system took 14 weeks to encode
at a service beureau.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 10 Jan 2008 14:29:09
Message: <47867205@news.povray.org>
"Invisible" <voi### [at] devnull> wrote:
> Rune wrote:
>> "Invisible" <voi### [at] devnull> wrote?
>>> Now, if I could make it download some more sheep... (You'd think 350
>>> would be enough. However, it seems to be more like 15 actual images,
>>> plus 15! morphs between them. Which isn't so interesting.)
>> Why 15! ?
>> For X images, wouldn't the necassary morphs between them be only
>> X*(X-1)/2 and not X! ?
> Hmm. Your knowledge of combinatorics clearly exceeds mine considerably...
Sounds odd, given that I don't understand most of the math you normally post
about here...
Anyway, since both forward and backwards morphs are needed, as well as the
loops themselves, that would be exactly X^2 animations if all loops should
be connected to all other loops (X loops and X*(X-1) transitions between
them).
Rune
http://runevision.com
Date: 10 Jan 2008 16:56:24
Message: <47869488@news.povray.org>
Ooo... LOL!
ADVANCED!!
[Hmm, POV-Ray service beureau, anyone?]
