POV-Ray : Newsgroups : povray.off-topic : Differential equations FTW! Server Time
17 May 2026 08:03:49 EDT (-0400)
  Differential equations FTW! (Message 2 to 11 of 31)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Differential equations FTW!
Date: 8 Jan 2008 05:07:06
Message: <47834b4a@news.povray.org>
Mmm, apparently I'm the only person retarded enough to actually be
amused by these.
Then again, when I was a child, I used to sit for hours watching the
washing machine. [Remember that when I was a child, "TV" was only
available for a few hours a day...]
Does anybody know how either of these simulations actually work?
http://blog.orphi.me.uk/
Date: 8 Jan 2008 09:01:17
Message: <4783822d$1@news.povray.org>
Actually I used to watch both TV *and* the washing machine. Imagine my
despair when my parents bought a washing machine without the glass
window at the front ;-)
I suspect they solve the differential equations in question :-D
Vincent
Date: 8 Jan 2008 09:43:30
Message: <47838c12@news.povray.org>
That's just cruel...
No... really? :-P
Date: 8 Jan 2008 09:54:31
Message: <47838ea7@news.povray.org>
> amused by these.
Not at all.
Cellula Automata - Each cell (pixel) follows some simple rules based on
its current state and that of its neighbours to determine its state in
the next generation.
This particular example looks like it implements some equations that
model the reaction of chemicals in 2D.  There are real mixtures that
exhibit the pulsating and alternating patterns that some settings reproduce.
Fiddling around with the parameters gives some behaviours that are
interesting and some that quickly lead to all dead, all alive or
something else.
The number of possible combinations of the parameters is huge but there
are typically a small number of interesting classes of behaviour on the
boundaries between boring and chaotic.
Some behaviours strike us as biological which I think sheds light on how
  complex life can emerge from simple chemical and physical rules.
You probably know already that this is known as 'emergent behaviour' -
When a system exhibits some behaviour often at a large scale that you
can't really predict from the rules.
I found a couple of nice settings.  Not sure if anything similar is in
their presets:
			Bees	Spaceships
Rate (Agent)		1500	982
Rate (Inhibitor)	6190	12853
Speed (Agent)		230	50
Speed (Inhibitor)	85	41
Scale (Agent)		15	15
Scale (Inhibitor)	15	14
For 'Bees' start a small pattern in the middle.  One or more individuals
proliferate by binary division and quickly fill the available space.
Then they start to pulsate in some not quite discernible way.
Occasionally an individual dies but the surrounding cells quickly split
and fill the available space to repair the colony.
'Spaceships' is like the similarly named constructs in Conway's Life.  A
bit larger and you can imagine a plasma drive towards the rear.  Start
with a bit more random stuff and you get lots of spaceships cruising
around.  Occasionally they meet and one or both are destroyed.  Some
'self-repair' after close encounters.  Interesting thing is to vary the
Speed (Inhibitor) around 41.  Take it down and the ships reduce in size.
  At 37 they suffer spontaneous explosions after a time and are all
destroyed.  From around 43 upwards the trailing edges continually break
off to form new ships and it becomes too chaotic.
Fun stuff.  Thanks for the link.
Date: 8 Jan 2008 10:03:15
Message: <478390b3$1@news.povray.org>
> No... really? :-P
Really.
The wave tank one is easy, for every "pixel" it simply solves the wave
equation.
http://en.wikipedia.org/wiki/Wave_equation
It may look scary if you don't recognise the symbols, but the maths is
actually quite trivial.  All the wave equation says is that the 2nd
derivative wrt to time (ie acceleration) of the value of each pixel is
proportional to the 2nd derivative of the value wrt to distance summed over
every axis.
It's easy to code, you can just take the difference between neighbouring
pixel values twice to work out the 2nd derivative in the x and y direction
and hence the acceleration.  Then the acceleration can be used to work out
the velocity and new value using Euler integration.
Date: 8 Jan 2008 10:05:17
Message: <4783912d$1@news.povray.org>
I thought a cellula automaton is where each cell has a *finite* number
of possible states? In this example, we have (conceptually) continuous
rather than discrete states.
> reproduce.
Indeed. That's how I found the link. ;-) I saw a TV program mention that
the patterns of animal skins can be described by a single mathematical
formula. Searching for this formula, I came across a document claiming
it's due to reaction diffusion - and hence the second link, which is a
simulation of the reaction diffusion differential equation.
Now, if I could figure out what the equation is and how it works, I
might be able to simulate it...
> something else.
Indeed, this is the case with a lot of fractals. A simple set of rules,
iterated a sufficient number of times, gives rise to complicated and
unpredictable behaviour, which is often quite pretty to look at. :-)
It's not quite as much fun, but do a search for "boids" to see some
interesting flocking behaviour...
Date: 8 Jan 2008 10:06:55
Message: <4783918f$1@news.povray.org>
>> No... really? :-P
> Really.
> equation.
> over every axis.
> direction and hence the acceleration.  Then the acceleration can be used
> to work out the velocity and new value using Euler integration.
So... acceleration = surface curvature?
How does that change when you have things like walls? Do you have to do
anything special at those edges?
Date: 8 Jan 2008 10:20:14
Message: <478394ae$1@news.povray.org>
> equation.
The 2nd partial derrivative of u with respect to t (time?) is equal to
the square of the wave velocity multiplied by the Laplacian of u.
What the heck is a Laplacian when it's at home?
Oh, wait - it's a second-order differential operator in the N-dimenional
Euclidian space defined as the divergence of the gradient. Obviously.
._.
Ouch.
Wikipedia - a great reference source, a rubbish way to learn brand new
concepts. (Indeed, I've seen articles marked for revision *because*
"Wikipedia is not a how-to". Hmm, what *is* Wikipedia then?)
Date: 8 Jan 2008 10:54:23
Message: <47839caf$1@news.povray.org>
> The 2nd partial derrivative of u with respect to t (time?) is equal to the
> ._.
> Ouch.
Well I'm sure you know what the gradient is.  But how is it defined in more
than one dimension?  And the divergence function?  It's all taught in vector
calculus...
Wikipedia is a reference, not a website full of tutorials.  Still, they
should link at the bottom of the "vector calculus" page to some good online
tutorial as it's really not very hard if you have a basic understanding of
normal calculus.
Date: 8 Jan 2008 11:00:51
Message: <47839e33$1@news.povray.org>
>> Ouch.
> more than one dimension?  And the divergence function?  It's all taught
> in vector calculus...
Try to remember: I have never taken any course in any mathematical
subject of any description. I have a GCSE in mathematics (grade C), but
that only covers addition, subtraction, multiplication, division and a
few other bits and pieces. Everything else I know is what I have managed
to figure out from reading books and surfing the net. ;-)
It's a wonder I know anything about mathematics at all... heh.
> online tutorial as it's really not very hard if you have a basic
> understanding of normal calculus.
I agree there.
Certainly the page on digital filters makes them seem like an utterly
incomprehensible topic. But a short read of a good book reveals that
it's all actually quite simple. [Assuming you want linear,
time-invariant filters of course.]
Ah well, never mind.
