POV-Ray : Newsgroups : povray.off-topic : photos Server Time
17 May 2026 05:22:24 EDT (-0400)
  photos (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: photos
Date: 4 Jan 2008 10:18:25
Message: <477e4e41$1@news.povray.org>
Jim Charter wrote:
> In a Windows environment,
> say I have a bunch of photographs stored on directories...
> suppose I want to store the photos and give them attributes such that
> I could retreive subsets of them using different filters on those
> attributes in a flexible, 'relational' way...
product. This enables you to store each image in a row of a big table,
and you can then cross-reference any kind of metadata you desire in the
product that will enable you to build a HTML interface to query all this
data in a flexible way.
...I mean, if you're looking for the most OTT solution available, this
has got to be fairly close. ;-)
On a slightly *less* insane note, you could probably build some kind of
PHP thing where you submit photos, it gives each one a unique name, puts
it in a folder somewhere, and stores some metadata about it in a MySQL
database and gives you a web interface to query it. In fact, heck,
somebody has probably already made such a thing somewhere...
http://blog.orphi.me.uk/
Subject: Re: photos
Date: 4 Jan 2008 14:28:50
Message: <477e88f2$1@news.povray.org>
Jim Charter wrote:
> Darren New wrote:
>> Nicolas Alvarez wrote:
>>> I'm about to write a database-based application for the family
>>> holiday pics. Maybe even something web-based on the LAN so that my
>>> sister can add the tags when she's bored.
>> I did one (a while ago) that stored the information in parallel
>> ".info" files, and from which you could generate a whole web site to
>> put on a CD. You're welcome to it, if you want. :-)
> Not sure what you are saying but it sounds closer to my purpose.
> Parallel .info files?
vacation/mexico/MomAndDad.jpg will have it's tagging information stored
in vacation/mexico/MomAndData.info
It's a bit clunky, but not too bad, and has the advantage that you can
go and reuse the information elsewhere, since it's a trivial format.
Plus, it has features like "keep this image, but don't include it in the
index pages" and so on.  Sorts by date and by name (IIRC), and things
like that.
Also used by a server I built that basically did what Flickr does, only
on a small scale. Lets you upload images, comment on them, etc.
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: photos
Date: 4 Jan 2008 14:54:16
Message: <477e8ee8$1@news.povray.org>
> is there currently any solution | method | common practice for doing
> this?
> assume I know nothing
> -Jim
google picasa is what I use to keep my photos...  but I don't know if it
is what youa re after.
Tom
Subject: Re: photos
Date: 4 Jan 2008 21:07:02
Message: <477ee646@news.povray.org>
Suppose I don't mind populating the MySQL database with the metadata
independent of the 'importing' or 'submitting' or 'photo acquiring'
process whatever it might be.  What pieces would be needed to query the
database and return path names as hyperlinks.  This would require PHP?
Subject: Re: photos
Date: 4 Jan 2008 21:11:58
Message: <477ee76e$1@news.povray.org>
> like that.
Sounds interesting.  I have been playing with Picasa and I think I will
use it for some things I want to do.  But I have other situations I am
not sure yet it could handle.  Like zipping and unzipping folders.  It
seems like once the folder goes away, so does the metadata.  I am
thinking there are was in which 'clunky' is better.
Subject: Re: photos
Date: 5 Jan 2008 00:14:43
Message: <477f1243$1@news.povray.org>
Jim Charter wrote:
> Sounds interesting.
http://s3.amazonaws.com/darren/PicEdit.zip
It's a 32K chunk of Tcl and a 700K chunk of jpeg handling binary
executable for Windows. If you have Tcl and TclLib installed, it should
just do its thing if you install the image extension.
I'm pretty sure it should work under Linux too.
You might have to futz with the source to configure some of the stuff.
Run the program without any arguments for help.
Subject: Re: photos
Date: 5 Jan 2008 06:20:03
Message: <477f67e3@news.povray.org>
Jim Charter wrote:
>> of PHP thing where you submit photos, it gives each one a unique name,
>> puts it in a folder somewhere, and stores some metadata about it in a
>> MySQL database and gives you a web interface to query it.
You could do that in a web-based way using essentially any server-side
scripting technique you like (PHP, ASP, Perl, Haskell CGI...)
Alternatively, MySQL might have tools that allow you to do this more
easily; I'm not aware of any, but I haven't looked for one either.
Subject: Re: photos
Date: 5 Jan 2008 06:47:26
Message: <477f6e4e$1@news.povray.org>
Yes. You also could push the images to the MySQL db, but is there any point?
Or, like Andrew said, any other server-side scripting language. Plus's
for PHP are that it's easy and that it has native support for talking
with MySQL. Minus for PHP is that it's also easy to create serious,
potential security holes.
Eero "Aero" Ahonen
   http://www.zbxt.net
Subject: Re: photos
Date: 5 Jan 2008 16:57:39
Message: <477ffd53$1@news.povray.org>
Darren New wrote:
> Jim Charter wrote:
>> Sounds interesting.
Thanks!  Off to install Tcl
Subject: Re: photos
Date: 5 Jan 2008 19:14:37
Message: <47801d6d@news.povray.org>
BTW, apparently Tcl 8.5.0.0 was *just* released by ActiveState. In
contrast to all earlier versions, this comes as a minimal install along
with an automated mechanism for accessing the Teapot (the Tcl equivalent
of CPAN).
You might want to start with 8.4.mumble from ActiveState, which includes
pretty much everything except the image extension.
