POV-Ray : Newsgroups : povray.off-topic : Physical puzzle Server Time
5 Jun 2026 18:02:45 EDT (-0400)
  Physical puzzle (Message 37 to 46 of 66)
Subject: Re: Physical puzzle
Date: 5 Jan 2008 13:52:01
Message: <477fd1d1@news.povray.org>
pan <pan### [at] syixcom> wrote:
> This could only be true if the trains and the track are uncoupled.
> They are not, so any contraction of trains will apply equally to
> the
> track.
  Nope. The trains are moving at a different speed than the track and
thus the trains compress more.
Date: 5 Jan 2008 19:12:17
Message: <47801ce1$1@news.povray.org>
More specifically, from the POV of one train, the other train is moving
faster than the track is.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 7 Jan 2008 04:48:59
Message: <op.t4jz3ic8c3xi7v@news.povray.org>
And lo on Fri, 04 Jan 2008 19:19:43 -0000, Darren New <dne### [at] sanrrcom>
did spake, saying:
> Phil Cook wrote:
>> Though won't the double track also seem foreshortened?
> Yes, but the oncoming train will seem *more* foreshortened.
>> travelling so fast it'll just sail straight over the gap without
>> falling far enough to get stuck.
> Not ... exactly. The problem isn't that he doesn't fall far enough. The
> problem is that the bottom of the train starts falling before the top
> does, kind of.
> And in that case, there are only two speeds involved (the track and the
> train), rather than the three in Warp's original problem.
 From an outside observer's pov both trains are shorter then the double
track so should pass without problem; I was trying to reconcile it with
the traindrivers' view. The oncoming train is shorter, but so is the
double track; so they should still collide?
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 7 Jan 2008 06:44:23
Message: <47821097@news.povray.org>
  From the POV of one of the trains the other train is shortened *more*
than the track.
Date: 7 Jan 2008 07:21:46
Message: <op.t4j67x1sc3xi7v@news.povray.org>
And lo on Mon, 07 Jan 2008 11:44:23 -0000, Warp <war### [at] tagpovrayorg> did
spake, saying:
> than the track.
If they were travelling at the same speed I'd have thought that the
shortening of both track and train would be proportional from the view of
the other train?
Phil Cook
Date: 7 Jan 2008 07:38:14
Message: <47821d36@news.povray.org>
> the other train?
  The trains travel at the same speed (in relation to the track) but in
opposite directions. Thus from the POV of one of the trains the other
train is approaching faster than the double track.
Date: 7 Jan 2008 10:03:50
Message: <op.t4kepdxoc3xi7v@news.povray.org>
And lo on Mon, 07 Jan 2008 12:38:14 -0000, Warp <war### [at] tagpovrayorg> did
spake, saying:
>> of
>> the other train?
Okay I'm the driver of one train and you're the driver of the other.
I see that your train is shorter then the double section of track and that
you're travelling faster then I am, therefore you hit the double section
before I do. But my train is still the same length as the double track (or
longer), so although I can clear the section without hitting the end of
your train (because you're shorter) I would expect you to hit the end of
my train (because you're faster).
I mean I can it understand how it works from Darren's perspective sitting
by the track, just not from the drivers.
Phil Cook
Date: 7 Jan 2008 10:14:55
Message: <op.t4ke7qsac3xi7v@news.povray.org>
And lo on Mon, 07 Jan 2008 15:01:51 -0000, Phil Cook
<phi### [at] nospamrocainfreeservecouk> did spake, saying:
> did spake, saying:
>>> of
>>> the other train?
> that you're travelling faster then I am, therefore you hit the double
> section before I do. But my train is still the same length as the double
> track (or longer), so although I can clear the section without hitting
> the end of your train (because you're shorter) I would expect you to hit
> the end of my train (because you're faster).
> sitting by the track, just not from the drivers.
Ah got it I think. Although both trains hit the double track at the same
time from my train you haven't reached it yet, so if I see you as 1/4 of
the length of the section I can be halfway along the double track before
you've even got on it. So I'll reach my end when you're clear and you
won't reach your end (despite being faster) until I've cleared your end
(my start).
Ouch yeah that works, we each perceive the other as reaching the double
section after ourselves.
Phil Cook
Date: 7 Jan 2008 12:32:20
Message: <47826224@news.povray.org>
> did spake, saying:
>> The problem is that the bottom of the train starts falling before the
>> top does, kind of.
>> the train), rather than the three in Warp's original problem.
No, because the oncoming westbound train is coming at the eastbound
train faster than the tracks are coming at the eastbound train, so the
westbound train appears to be smaller than the siding as seen from the
eastbound train.
Date: 7 Jan 2008 20:48:51
Message: <4782d683@news.povray.org>
news:477fd1d1@news.povray.org...
>> uncoupled.
>> the
>> track.
> and
>                                                          - Warp
Train wheels gripping track exponentially gets looser
the greater the speed of the train. At c or near c the
track will have to move almost the entire speed of the
train; else the instability will overwhelm your system.
ergo: the track and train muts be coupled, else you
would be asking about trains and tracks on separate
unique vectors. (Unpredictable vectors btw)
unless of course your train wheels and track rails are
made of unobtanium held together in the grip of
stick-but-slick-enough-to-let-the-wheels-move goop.
Think dentures under a lot of strain.
