POV-Ray : Newsgroups : povray.off-topic : On the topic of databases... Server Time
11 Oct 2024 05:19:17 EDT (-0400)
  On the topic of databases... (Message 1 to 4 of 4)
Subject: On the topic of databases...
Date: 16 Dec 2007 13:15:05
Message: <47656b29$1@news.povray.org>
I've never built a system where the database privs are the primary
access control mechanism. Indeed, I've never really build an application
(yet) where there's more than one completely independent application
accessing the database. (At which point I'd imagine database-level privs
would be more important.)
What's a good way to regularize the database privs with (say) what you
show on the screen?
For example, I worked in one company where we had, essentially, a B2B
store. Some employees could help customers, some could add inventory to
the store, some could run reports, etc. Each of these groups got a
different set of links on the main screen to take them to different
functionality. The list of who could access what stored procedures was
enforced in the application, not the database itself. Maintaining that
list multiple times (who can see what on the screen, who can run which
stored procedures, which tables each stored procedure can access) would
have been very tedious and error-prone. (Plus, it started out all
enforced by the app when I got there, only poorly, so it would have been
difficult to cut it all over at once, given that it took a few weeks
just to put all the inline SQL into stored procedures to start with.)
Anyway, what's a good way of synchronizing what a role can do at the
application level, what stored procedures a roll can access, and what
tables a role can access?  Is there anything unobvious and clever that
doesn't require (say) parsing the stored procedure code to figure out
what it does with which tables?
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: On the topic of databases...
Date: 28 Dec 2007 13:09:02
Message: <47753bbe@news.povray.org>
> show on the screen?
As dirty as it sounds (and is), most systems I've seen handle the actual
db with full access (or at least with permissions that are "enough") and
the frontend takes care of the permissions.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 31 Dec 2007 22:52:20
Message: <4779b8f4$1@news.povray.org>
That's what I've usually done, but I've so far written systems where
only one application accesses the DB.
I saw a lecture about a tool set one person built (Wyatt Erp or some
such name) (in Tcl) that let you build enterprise-level systems. One
application took orders, another did the accounting, one did the
scheduling, one sent the parts list to the assembly automation, and so
on. So you really wouldn't want the guy running the application that ran
the machine tools to have access to the same stuff the guy running the
sales management software to have.
I just haven't figured out an especially clean way of separating it out.
Maybe I need to look at the Wyatt Erp source code. :-)
Date: 1 Jan 2008 07:42:25
Message: <477a3531$1@news.povray.org>
Actually so have I. OTOH, I usually haven't done actually finished
frontends to write the data to db, just to access it (darn, it's clearly
too easy to login to the db and write pure SQL to push data at home db's
:p).
Actually I know couple of systems, where different applications and
users deal with different things and via one application one user can do
different things than another user. I'm not sure if I can say enterprise
-level, but pretty major systems for one firm.
And yet even these systems do exactly as I told - full access to db,
limited access to frontends. As I said, dirty :/.
Eero "Aero" Ahonen
   http://www.zbxt.net
