POV-Ray : Newsgroups : povray.off-topic : Nvidia acquires Mental Images (mental ray) Server Time
9 Jun 2026 12:43:32 EDT (-0400)
  Nvidia acquires Mental Images (mental ray) (Message 11 to 13 of 13)
Subject: Re: Nvidia acquires Mental Images (mental ray)
Date: 14 Dec 2007 07:03:38
Message: <4762711a$1@news.povray.org>
scott wrote:
>>> Erm yeh, Gelato is meant to be run on a Quadro card...
>> Gelato? Or Gelato Pro?
> Both.  Gelato and Gelato Pro were both designed to run on a Quadro
> card.  If you try to run it on a non-Quadro card, it might work but it's
> certainly not going to be able to make use of all the GPU features a
> Quadro card has.  I suspect it is using CPU emulation for the GPU
> features that are missing...
The information I was is that Gelato Pro *won't work* with a GeForce
card, but vanilla Gelato will. This suggests to me that they designed it
to work properly in that configuration.
[I'm no expert, but the nVidia document I saw seemed to suggest that the
Quadro cards are more geared to 2D optimisation than 3D. Not sure how
that would help here...]
http://blog.orphi.me.uk/
Date: 14 Dec 2007 08:49:31
Message: <476289eb$1@news.povray.org>
> The information I was is that Gelato Pro *won't work* with a GeForce card,
> but vanilla Gelato will. This suggests to me that they designed it to work
Oh I'm sure it works properly, but whether it works as quickly on a GeForce
compared to a Quadro...
> Quadro cards are more geared to 2D optimisation than 3D. Not sure how that
> would help here...]
You mean this document:
http://www.nvidia.com/object/quadro_geforce.html
Just looks to me like there is more flexibility built into the card, which
is exactly what you need when you're trying to off-load as much CPU work
onto the GPU as possible... (for example being able to have all pixel shader
IO in 32-bit per channel format looks useful from a general GPU programming
point of view)
Date: 14 Dec 2007 13:29:33
Message: <4762cb8d$1@news.povray.org>
>> the Quadro cards are more geared to 2D optimisation than 3D. Not sure
>> how that would help here...]
> which is exactly what you need when you're trying to off-load as much
> CPU work onto the GPU as possible... (for example being able to have all
> pixel shader IO in 32-bit per channel format looks useful from a general
> GPU programming point of view)
I was under the impression that in the GeForce 8 series they radically
redesigned the whole GPU to make GPGPU much more flexible with less
jumping through hoops. I'm not a super-expert in this direction though,
so maybe Quadro does offer something particular that the GeForce 8 is
lacking...
