POV-Ray : Newsgroups : povray.off-topic : Project Euler Server Time
4 Jul 2026 08:16:41 EDT (-0400)
  Project Euler (Message 32 to 41 of 51)
Subject: Re: Project Euler metadiscussion
Date: 29 Nov 2007 05:02:28
Message: <474e8e34$1@news.povray.org>
Mueen Nawaz wrote:
> Invisible wrote:
>> Currently for each problem, you either get the answer right or you get
>> it wrong. I think it would be nice if you could check intermediate parts
>> of the calculation. (E.g., is 103 a prime number? Is 187 an abundant
>> number? etc.)
> 	Well, for all but one of the problems I've worked on, the definitions
> in the problem statements are fairly unambiguous.
Well, for "find the millionth prime number" or something, there's not
much to check. But when the problem is "sum all the primes below 1
million", it might be nice to know, for example, how many primes there
are. (Or rather, be able to ask "are there 722 primes?" and get a yes/no
answer.)
[BTW, I'm damn-well *sure* there used to be a site that tells you
whether a number is prime, and what the Nth prime number is, and how
many primes there are below N. Google can no longer find it though...]
>> On the other hand, I suppose they don't want to give too much data away,
>> otherwise you could just "solve" the problem by asking the Project Euler
>> website a sufficient number of questions. ;-)
> 	True - almost. If you submit too many answers in a short period of
> time, the Web site blocks you for a while.
I know what *would* be nice - if the site would keep a list of the
answers you've already tried which turned out to be wrong! (So many
off-by-one bugs...)
>> I'd kinda like to make my own website like Project Euler. However, I had
>> a look, and to get hosting that gives you server-side scripting and a
>> database is 5x the price of what I'm currently paying. :-S I can't
>> really afford that kind of money...
> 	The weakened Dollar may help you there.<G>
> 	What price are you talking about. You definitely can get it for under
> $10/mo, and if your needs aren't too stringent, probably $5/mo is not
> hard to find.
> 	The tricky part is making the problems interesting enough for people to
> come. A number of problems on the Project Euler site *may* lead you into
> some interesting number theory topics...
I don't know - almost all of the problems seem to be a case of "write
this brute-force search algorithm so it doesn't take all day". Very few
problems appear to possess an elegant mathematical solution. For example:
- Find the 10,001st prime number. Well, sure, there's only one possible
way to do that. You can't know whether a given prime is the 10,001st or
not without finding all 10,000 primes below it! Brute-force search,
plain and simple.
- Take this file full of data, generate some numbers from it, find the
highest one. Well, again, no mathematics involved. It's a trivial search
problems. Just gotta write a program fast enough.
- Find a number having some highly obscure property. Well you can
probably use elegant mathematics to elimatine a few classes of
possibilities, but it still comes down to a simple search in the end.
A few of the problems admit an elegant mathematical solution. The thing
with Pythagorean triples, or finding the sum of numbers or the number of
combinations or something. Slightly more involve some actual maths
somewhere. But most seem to just involve blindly searching as fast as
possible. It's not very interesting, but I like seeing my score
increase. :^)
Date: 29 Nov 2007 07:14:26
Message: <474ead22$1@news.povray.org>
> possible. It's not very interesting, but I like seeing my score increase.
Oh I think it is pretty interesting.  In real life you often need to get
results as quickly as possible.  Part of the skill is being able to decide
quickly whether it's better to spend 1 minute coding and waiting 10 minutes,
or spending 10 minutes doing some math and then only having to wait 1 second
for the answer.
And then another skill is being able to decide *what* to use to get the
answer (C++, Excel, Haskell, calculator, pencil etc).
There should be a timer that starts the moment you open the problem for the
first time, and that is stopped when you submit the correct answer.  Not
sure how you would stop people cheating though.
Date: 29 Nov 2007 07:50:11
Message: <474eb583$1@news.povray.org>
> the first time, and that is stopped when you submit the correct answer.
> Not sure how you would stop people cheating though.
Or a counter for the number of incorrect results you submitted. ;-)
Date: 29 Nov 2007 18:49:32
Message: <474f500c@news.povray.org>
> [BTW, I'm damn-well *sure* there used to be a site that tells you whether
> a number is prime, and what the Nth prime number is, and how many primes
The Prime Pages probably has something like that.
http://primes.utm.edu/index.html
You can get the first 15 million primes in files.
There's also an open challenge from the EFF to
calculate a billion digit prime number, with a prize
of $250,000.
http://w2.eff.org/awards/coop.php
Date: 30 Nov 2007 02:26:40
Message: <474fbb30$1@news.povray.org>
> answer.)
	That'd make it easier to solve, though.
	That's an interesting currency conversion you have there...
	Unless you have a good reason to stick with them, simply dump them and
ask around for recommendations of cheaper and better hosts. I'm
currently paying a bit less than you are (albeit that's because I paid
in advance), and I get probably much more than what you want.
(I use Dreamhost - often maligned, but more than satisfies my needs and
wants and I can't find similarly priced alternatives that do).
> plain and simple.
	I'm assuming that these two are just prepping you up for more difficult
(but related) problems later on. Certainly if someone has trouble
generating 10001 primes, he won't get too far.
	That's sort of the point. Take Problem 43:
"The number, 1406357289, is a 0 to 9 pandigital number because it is
made up of each of the digits 0 to 9 in some order, but it also has a
rather interesting sub-string divisibility property.
Let d1 be the 1st digit, d2 be the 2nd digit, and so on. In this way, we
note the following:
    * d2d3d4=406 is divisible by 2
    * d3d4d5=063 is divisible by 3
    * d4d5d6=635 is divisible by 5
    * d5d6d7=357 is divisible by 7
    * d6d7d8=572 is divisible by 11
    * d7d8d9=728 is divisible by 13
    * d8d9d10=289 is divisible by 17
Find the sum of all 0 to 9 pandigital numbers with this property."
	A REAL brute force solution is simple to write, but do you really want
to check over a billion numbers? (I'm guessing anyone who got this far
would not even realize the search space is that big - they'll
automatically optimize).
	Now with some thought you can bring that number down to something very
manageable. You could then code it and be happy, or think more and try
to reduce the search space even more. The more you do this, the more
"painful" it is to code. So then you take on the challenge of writing
the code in a "nicer" way so that it doesn't look like an ugly hack.
	I just went halfway and coded it. I felt bad about that after looking
at the solutions. There were some really simple ways to reduce the
search space _much_ further - on the other hand I did a simplification
few thought of - but the ones I missed negated the need for mine.
	Now some people simply solved this on paper (some of those did use a
calculator to help, though).
	The point of the problems is not to solve it _entirely_ mathematically
(although if you can, that's wonderful). It's to use math to make the
problem more tractable (even if it _can_ be done under a minute via
brute force). And for me, it's also a challenge to write the code
somewhat nicely.
	The last problem I worked on (in the 40's) was somewhat brute force and
took over 40 minutes. Haven't had time to think about it much since
then, but I look forward to bringing that down. I have a few ideas on
making the algorithm faster which may suffice, but before I had obtained
the solution, I noticed some mathematical properties which I suspected
held true in general (but couldn't prove it). After computing the
solution, I find the answer does satisfy my hypothesis, and now I don't
want to simply speed up the algorithm, but rather explore my hypothesis
and "speed" it up that way.
	Which is why I enjoy a number of the problems...
> increase. :^)
	I assume that it'll demand more math thought as you get higher. Many
(most?) have not impressed me as much in that regard thus far. But heck,
it was fun anyway!
As a child my family's menu consisted of two choices: "Take it, or leave
it."
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 30 Nov 2007 04:25:48
Message: <474fd71c$1@news.povray.org>
>> answer.)
Well yes - but do you have any idea how frustrating it is to spend hours
trying to make your program work when you don't even know what part is
broken? Knowing which part is broken doesn't tell you how to fix it, it
just tells you which part needs fixing...
(Also, a number of questions give insufficient detail to figure out what
the correct answer is.)
other...
I've asked many times. Nobody ever recommends anything.
My current host (1&1) charges quite a low price for serving just static
HTML, which is mainly what I want. However, if you decide you want CGI,
they suddenly want to charge a lot more.
(I hate Perl, and PHP would probably be the same. I'd probably want to
do my CGI scripting in Haskell - and by the looks of it, the only way to
do *that* is to go for a virtual server package rather than a simple web
hosting package. That's A LOT of extra complexity, and it's expensive.)
[BTW, I find it interesting that all hosting packages offer MySQL or SQL
Server, but none offer PostgreSQL...]
> I'm
Well, I'll have a look...
True, I guess.
Actually I didn't - mainly because I don't know what "pandigital" means.
I did see one problem that was solved by a human with pen and paper in
under 30 seconds. Just move some algebra around and it tells you the
answer. But most seem to require a machine.
(Many involve prime numbers - and as we all know, it is impossible to
know anything about prime numbers. You just gotta compute them all the
long way...)
> somewhat nicely.
Personally, I find that as you come up with better algorithms it gets
*easier* to code, not harder. ;-) Maybe that's just because I use
Haskell... The Mathematica solutions are similarly easy.
>> increase. :^)
> it was fun anyway!
Well, it's a challenge I guess. I doubt I'll ever reach 100% though...
Date: 30 Nov 2007 05:59:19
Message: <474fed07@news.povray.org>
A friend of mine uses http://www.ipowerweb.com/ and recommended me to use if
I ever needed a website.  A quick look shows that they offer 300 GB with
Perl/MySQL/PHP/CGI-BIN/etc for $4.95 / month if you get the 12 month
package.
Date: 30 Nov 2007 06:28:44
Message: <474ff3ec@news.povray.org>
> use if I ever needed a website.  A quick look shows that they offer 300
> GB with Perl/MySQL/PHP/CGI-BIN/etc for $4.95 / month if you get the 12
> month package.
TY. I'll check it out later...
Date: 30 Nov 2007 14:12:07
Message: <47506087@news.povray.org>
Find a Haskell interpreter written in PHP or Perl.
Date: 30 Nov 2007 14:18:44
Message: <47506214$1@news.povray.org>
Good luck with that idea. ;-)
(Small hint: Aside from research projects and experimental
implementations, there are only 2 working Haskell compilers in the
world... and only 1 of those isn't written in Haskell.)
You would probably write a program that fakes it convincingly though...
