POV-Ray : Newsgroups : povray.off-topic : A question of pure mathematics Server Time
31 May 2026 12:59:28 EDT (-0400)
  A question of pure mathematics (Message 21 to 25 of 25)
Subject: Re: A question of pure mathematics
Date: 20 Nov 2007 15:22:52
Message: <4743421c$1@news.povray.org>
Invisible wrote:
> O RLY?
> My DSP textbook says the Fourier transform of the delta function yields
> an amplitude of 1 for all frequencies. (Whereas the Fourier transform of
> a zero signal would be a zero signal.)
As has been mentioned, a function which is zero everywhere except for
f(0)=1 is not what is meant by a delta function in this context.  The
critical property of the delta function which your book is talking about
is that it has an integral of 1 over any interval containing the
`spike', whereas the function I described has an integral of zero
everywhere.
There's another argument that can lead you to the same conclusion that
you can't approximate any function over the reals with a Fourier
transform, and that's to note that the cardinality of the number of
possible Fourier representations is smaller than the cardinality of the
number of possible functions on the reals, so there have to be some
functions that you can't represent.
Date: 20 Nov 2007 15:25:33
Message: <474342bd$1@news.povray.org>
Sure. For example, you might have a partial function that isn't defined
at certain points.
None of this really interests me that much, because in the specific
instance I'm looking at [processing digital audio and video] there
aren't any such functions to worry about.
Date: 20 Nov 2007 15:47:36
Message: <474347E8.9080302@u.washington.edu>
> at certain points.
Even if you restrict yourself to functions which are defined everywhere
and are periodic with some given period the argument still applies.  For
example, consider a really nasty function, like one which has a value of
one at all rational points and zero everywhere else.
Agreed.  I hope that you find some interesting things with the audio and
video processing stuff!  Is your goal to find some techniques which
improve on current methods or to fiddle around with some of the current
methods and understand them on a deeper level?
Date: 20 Nov 2007 17:28:25
Message: <47435f89$1@news.povray.org>
>>> [We casually overlook the fact that JPEG doesn't work in the RGB colour
>>> space, it works in some weird custom space to better accomodate the
>>> peculiarities of the human eye.
>>   It's not a "custom space". It's the YCbCr color space, which has been
>> used in television and video for like 50 years.
> OK, I rephrase: It looks pretty exotic to me. ;-)
Essentially the entire JPEG compression happens after an image
is split into grayscale channels though. The color space conversion
isn't used to increase compression.
The way I understand (wavelet?) compression, like that
in JPEG2000, is that it takes a somewhat recursive approach.
I think this part involves the wavelets... (digital wavelets being
somewhat different from analog wavelets with all the
complicated math)
The algorithm goes something like this...
1. Load the image to be compressed to memory
2. Produce an image that is the difference between
the current pixel and an average of the last few...
with a few small variations, like you can't use the pixel
above the current pixel on the top line, but you can elsewhere.
For most images this is similar to edge-detect, the resulting
image is mostly black, so highly compressible.
3. Save the difference image
4. Produce an image that is the error between the image constructed
in step 2 (when reconstructed) and the image in memory
5. replace the image in memory with the error image
6. reduce the size of the image in memory, resize,
by some fixed ratio
7. if the image in memory is larger than some size then repeat steps 2-7
8. perform some standardish compression on the saved images and
produce a file.
Date: 21 Nov 2007 02:55:44
Message: <4743e480$1@news.povray.org>
Yes it is.  Usually, in the new colour space, two of the channels are scaled
by 50% as a first step that vastly decreases the file size.  You would never
be able to get this much compression with RGB without the result looking
much worse.
