POV-Ray : Newsgroups : povray.off-topic : missing disk space on server, need help Server Time
4 Aug 2026 10:11:47 EDT (-0400)
  missing disk space on server, need help (Message 9 to 18 of 58)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: missing disk space on server, need help
Date: 9 Nov 2007 12:01:49
Message: <op.t1janufec3xi7v@news.povray.org>
And lo on Fri, 09 Nov 2007 16:10:20 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> Phil Cook wrote:
>> Asking the obvious I'm assuming that the swap file isn't on the same
>> partition?
> Even if it is, that would show up as a "file" and would be counted with
> all the other files in the "40 GB" number. (Although presumably not the
> backup size.)
Depends how you're counting. If it's sitting on its hidden lonesome in
root and you just total the folders. Wouldn't show up on a file size
search either unless you specifically include hidden system files.
> Also, the swap file doesn't just change size of its own accord.
Well no it changes when it needs to.
> Certainly not by 60 GB. ;-)
Why not unless you've set a maximum limit.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 9 Nov 2007 12:52:19
Message: <47349e53$1@news.povray.org>
Kyle schrieb:
> Have you tried to do a search for large files?  I'd start there.
nice tool to get an overview:
http://w3.win.tue.nl/nl/onderzoek/onderzoek_informatica/visualization/sequoiaview//
but it won't help, if those 60GB are no files at all, as Fabien suggests...
kk
Date: 9 Nov 2007 13:00:15
Message: <4734a02f$1@news.povray.org>
Le 09.11.2007 14:35, Fa3ien nous fit lire :
> Our server got a 120 Gb disk.
> Data files are stored on a 100 Gb partition of it.
> That partition is NTFS, cluster size 4 Kb.
> The files in that partition sums up to 40 Gb (which,
> not surprisingly, is also the size of the nightly
> backup)
> Today, someone had a problem to save a file, and I've
> been horrified to see that Windows Server 2003 tells
> me there's only 2 Mb left on the partition !
> I've run a defrag, which freed 250 Mb.
> WHERE IS THE REST ? (there should be 60 Gb free !)
You need admin right to see all the files... (and more to see
more-than-hidden-resource-forks...)
Now, the defrag tools should display a nice analysis of the filled
space.
From memory, Red is fragmented, Blue is continuous and Green is
System. (grey is free space ???)
Have a look.
> What could it be ? I don't know what to do...
Ask Microsoft a 60% refund ?
> Fabien.
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 9 Nov 2007 14:29:23
Message: <4734b513@news.povray.org>
> spake, saying:
>>> partition?
>> with all the other files in the "40 GB" number. (Although presumably
>> not the backup size.)
True.
I thought it was standard practise to set minsize = maxsize to prevent
fragmentation...
What do you mean "unless"? ;-)
Subject: Re: missing disk space on server, need help (SOLVED with chkdsk)
Date: 9 Nov 2007 15:01:03
Message: <4734bc7f$1@news.povray.org>
Sorry for getting back so late after the event, but
I had urgent work to do PM.
In short, a good'ol chkdsk /f solved the problem.
I didn't knew that so much empty space could be
erroneously marked as allocated... (and didn't think
if chkdsk at first because I haven't used it in years).
Thanks to everyone who tried to help :-)
Fabien.
Date: 9 Nov 2007 15:02:04
Message: <4734bcbc$1@news.povray.org>
> Some of it could conceivably be "slack space". (A file can only be an
> integer number of blocks long. The remaining space isn't shown in the
> "file size", yet cannot be used for any other data because a block can
> only belong to one file. If you look at file properties, you will see a
> "file size" and a larger "disk on disk", which includes the slack space.)
I thought of that at first, but, no.  With 4 Kb clusters, the maximum
amount of lost space is rather small (say we got 100 000 files, which
isn't even the case, it would take 400 Mb at worst).
> Do you have that Previous Versions option switched on?
No.  That partition contains only data files, nothing system-related.
It was just clusters erroneously marked as allocated, chkdsk fixed it !
Thanks anyway.
Fabien.
Date: 9 Nov 2007 15:02:45
Message: <4734bce5@news.povray.org>
Woah! o_O
That's one unhappy filesystem... heh. Glad it's all fixed now though.
(Although you probably ought to find out *why* it did this in the first
place...)
Date: 9 Nov 2007 15:04:16
Message: <4734bd40$1@news.povray.org>
> Defrags free disk space??
Theorically, it shouldn't, I'm surprised too.  The fact
is that Windows seen more free space after defrag.
chkdsk freed the rest !
Fabien.
Date: 9 Nov 2007 15:06:28
Message: <4734bdc4$1@news.povray.org>
Most likely defrag partially corrected some mis-allocated space as a
side-effect of frobnicating the low-level FS data...
Date: 9 Nov 2007 15:14:15
Message: <4734bf97@news.povray.org>
> Woah! o_O
> place...)
I'll check regularly to see if it happens again... Maybe it's related
to the problems I had with Raid in may. I currently run the server
without Raid1, because the bad experience showed me that no raid (with
a daily backup, anyway) is less of a potential hassle than shitty SIS
software Raid (which is more insecure because it doesn't inform you
correctly of the real array state).
Fabien.
