POV-Ray : Newsgroups : povray.off-topic : Small CSS question Server Time
17 May 2026 09:34:29 EDT (-0400)
  Small CSS question (Message 21 to 30 of 38)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Small CSS question
Date: 7 Nov 2007 10:53:58
Message: <4731df96@news.povray.org>
Phil Cook wrote:
> And lo on Wed, 07 Nov 2007 12:34:50 -0000, Invisible <voi### [at] devnull> did
> spake, saying:
>> What I *could* do is this:
>>    style {padding: 1em;}
>>    style style {padding: 2em;}
>>    style style style {padding: 3em;}
>>    etc.
>> But that still seems a crying shame...
> Wrong way round.
Gah. o_O
Date: 9 Nov 2007 03:16:44
Message: <slrnfj85rc.j3c.bisqwit@bisqwit.iki.fi>
On Tue, 06 Nov 2007 18:21:42 +0000, Orchid XP v7 wrote:
> (This is basically for printing out expressions containing insane
> numbers of brackets. I want to use borders to help untangle the mess in
> some kind of visually-sane way...)
Try MathML. It helps greatly at least if your formula contains divisions.
 <math xmlns="http://www.w3.org/1998/Math/MathML">
  <mrow>
   <mn>log</mn>
   <mo>(</mo>
     <mfrac>
     <mrow>
       <mn>sqrt</mn>
       <mo>(</mo>
       <mn>5</mn>
       <mo>)</mo>
     </mrow>
     <mrow>10</mrow>
     </mfrac>
   <mo>)</mo>
  </mrow>
 </math>
MathML can be embedded in XHTML, but you need to pass
the right Content-type header (xhtml+xml).
Joel Yliluoma - http://bisqwit.iki.fi/
: comprehension = 1 / (2 ^ precision)
Date: 9 Nov 2007 04:54:58
Message: <47342e72$1@news.povray.org>
>   <mrow>
>    <mn>log</mn>
>    <mo>(</mo>
>      <mfrac>
>      <mrow>
>        <mn>sqrt</mn>
>        <mo>(</mo>
>        <mn>5</mn>
>        <mo>)</mo>
>      </mrow>
>      <mrow>10</mrow>
>      </mfrac>
>    <mo>)</mo>
>   </mrow>
>  </math>
OK, let's see the MathML for the following expression:
S(S(KS)K)(S(S(KS)K)I)(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)I)))(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)I))))
Care to tell me where one subexpression ends and the next one begins? ;-)
Date: 9 Nov 2007 09:20:19
Message: <op.t1i3d1rsc3xi7v@news.povray.org>
And lo on Fri, 09 Nov 2007 09:54:59 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>>> in some kind of visually-sane way...)
>> divisions.
>>   <mrow>
>>    <mn>log</mn>    <mo>(</mo>
>>      <mfrac>
>>      <mrow>
>>        <mn>sqrt</mn>
>>        <mo>(</mo>
>>        <mn>5</mn>
>>        <mo>)</mo>      </mrow>
>>      <mrow>10</mrow>
>>      </mfrac>
>>    <mo>)</mo>
>>   </mrow>
>>  </math>
Just for fun with spans
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<style>
html {margin:20px;}
div {height:40px;}
span {padding:20px; border: red 1px solid;}
span span {padding:18px; border: orange 1px solid;}
span span span {padding:16px; border: yellow 1px solid;}
span span span span {padding:14px; border: green 1px solid;}
span span span span span {padding:12px; border: blue 1px solid;}
span span span span span span {padding:10px; border: red 1px dotted;}
span span span span span span span {padding:8px; border: orange 1px
dotted;}
span span span span span span span span {padding:6px; border: yellow 1px
dotted;}
span span span span span span span span span {padding:4px; border: green
1px dotted;}
span span span span span span span span span span {padding:2px; border:
blue 1px dotted;}
span span span span span span span span span span span {padding:0px;
border: black 1px dotted;}
</style>
<div>S(S(KS)K)(S(S(KS)K)I)(S(S(KS)K)(S(S(KS)K)(S(S(KS)K)I)))(S(S(KS)K)(S
(S(KS)K)(S(S(KS)K)(S(S(KS)K)I))))</div>
<div>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</span>K</span
>I</span><span>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</sp
an>K</span><span>S<span>S<span>KS</span>K</span>I</span></span></span><s
pan>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</span>K</span>
<span>S<span>S<span>KS</span>K</span><span>S<span>S<span>KS</span>K</spa
n>I</span></span></span></span></div>
</html>
that's using a simple find replace on () for <span></span>
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 9 Nov 2007 09:40:17
Message: <47347151$1@news.povray.org>
> spake, saying:
Looks good! (Although possibly the spacing is a little *too* generous.)
Certainly a lot easier to find subexpressions than in the raw text
above. Just a pitty it takes so many miles of CSS...
Date: 9 Nov 2007 09:46:02
Message: <op.t1i4jqugc3xi7v@news.povray.org>
And lo on Fri, 09 Nov 2007 14:40:17 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> did spake, saying:
Well it's allowing for 11 levels with enough of a gap so that lines don't
blend, but it's adjustable.
Well the CSS is fixed so just dump it into a separate file and all you'll
have is the spans
Phil Cook
Date: 9 Nov 2007 10:03:57
Message: <473476dd$1@news.povray.org>
> spake, saying:
> you'll have is the spans
True.
I'm wondering if I could do something weird with inheritance and
percentage units...
Date: 9 Nov 2007 10:09:04
Message: <47347810$1@news.povray.org>
>> did spake, saying:
> True.
> percentage units...
All you need is server-side scripting. Count the parentheses levels and
generate the CSS with that many levels. But a pure CSS method would be nice.
Still, you should really use MathML. That's what it's made for...
Date: 9 Nov 2007 10:20:43
Message: <47347acb@news.povray.org>
> nice.
Nah; just generate a file with 20 levels of nesting. If there's more
than that, you won't be able to disentangle it visually anyway. (And
it's not like the program will crash; it'll just show less clean output.)
What, drawing pretty lines around bits of text?
Date: 9 Nov 2007 10:59:18
Message: <op.t1i7untmc3xi7v@news.povray.org>
And lo on Fri, 09 Nov 2007 15:08:59 -0000, Nicolas Alvarez
<nic### [at] gmailisthebestcom> did spake, saying:
>>> did spake, saying:
>>  True.
>> percentage units...
Which was my first suggestion :-)
But little use unless you can serve it as application/xhtm+xml whereas
html is always served as text/html without the need for a dedicated server
component.
Phil Cook
